Question about Royal Scrittore Portable Manual Typewriter
Keys not hitting the platen hard enough
I have to press the keys down really hard to get the ink dark enough to read on the paper... What can I do to fix this?
  • 453 Answers
Try striking the keys not just pressing them a quick stroke and lifting motion like touching something hot
Posted on Dec 06, 2014
  • Royal Master
  • 15,746 Answers
Try a new ribbon first.
Posted on Apr 16, 2014
When typing the letters pile up on each other
Most likely it needs lubrication. WD40 is a wonderful thing. Make sure that you put rags under the typewriter to catch the mess. As you press keys and the space bar, spray under the platen as it moves. You want to lube the escapement and the rails. When finished, use denatured alcohol to clean the platen and rollers. (But try really hard NOT to get WD40 on the rollers or the platen. The rollers can be hard to get to). DO NOT do this if this is an electric. They have a rolling platen under the typewriter to provide movement to the keys, etc. If the roller gets oil on it, it will stop working! You can keep cleaning the roller, but as the oil keeps dripping on the roller, all the movements will slip. Eventually you might get it clean, but it is a pain.
Apr 17, 2014 | Smith Corona Sterling Vintage 1940s Type...
The screen is really dark
Locate the Fn (Function) key on your keyboard. It may be on the bottom left side with dark blue letters. Locate the two "brightness" keys near the top of the keyboard. These will be in the "F" keys, possibly if F6 and F7. They should have little sun pictures or something similar to indicate brightness. Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness. Tap F7 repeatedly until you reach the desired brightness. Fn must be held down as you continue to tap. Hope this helps.
Dec 07, 2012 | Intel EasyNote E4 715 Notebook
Key disabled message
The Down Arrow and the View buttons are disabled on the T6050 as default because reverse paper feeding is not recommended on the T6050 printer because they only have one pair of tractors which are mounted above the platen. If the printer tries to reverse feed paper, it could cause a paper jam unless the platen gap is open sufficiently to allow the paper to feed down through the gap unhindered.
You can enable reverse paper feeding if you are sure that a paper jam will not occur. This is done as follows. Set the printer to Offline. Press the Mode key: display will show Offline Normal. Press any Arrow key until display shows Offline Oper. Press the Forms/1 key. Press any Arrow key until display shows Oper Forms. Press the CPI/2 key. Press any Arrow key until display shows Forms RevPap. Press the LPI/3 key. Press any Arrow key until display shows RevPap Enabled. Press the Enter key and reverse feeding will be set. Set the printer to Online. Once the reverse paper function has been enabled this option will need to be saved to prevent the setting being lost when the printer is powered off. To save the Menu Configuration; Put the printer OFFLINE Press the MODE button, then press the DOWN ARROW until CONFIG is displayed Press FORMS/1, then press the DOWN ARROW until PRINTER is displayed Press CPI/2, then press the DOWN ARROW until SAVE is displayed Press LPI/3, and with POWERUP shown in the display, press ENTER.
Mar 05, 2012 | Tally Line Matrix T6050 Printer
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Ink absorber is full.... what will i do.
When you get the warning that the ink absorber tank is full, leave your printer on!, open the front of the printer and the cartridges will move to the centre, at this point look into the printer and down in the far right bottom area you will see(you may need a small torch if in a dark room) two small rectangular sponge pads in a black plastic caddy, this is the "absorber ink tank" all you do is carfully hold a folded sheet of kitchen paper on the two sponges, this will soak up the excess ink, keep doing this until the your paper kitch towel has removed all the ink it can. Now, (with the Canon Pixma mp110 anyway), you need to reset the abs-m level as follows:- with the printer on press MENU-SCAN-COPY-SCAN this will enter the "service menu", click the + or - arrow key until you get to NVRAM ACCESS? then click ok, now click on one of the arrow keys until you get to ABS-M LEVE now click ok and you will see SET ABS-M use the arrow keys to set the level to 0 press ok and turn your printrer off!. Now you can turn your printer back on and all should be fine!. pcdcool.
Nov 15, 2009 | Office Equipment & Supplies
2nd up
To increase the contrast of the screen you press [2nd] key and release it. Then you press and HOLD arrow Up, till screen is dark enough.
To lighten a dark screen you press [2nd] key and release it; you press and hold the down arrow.
Hope it gets your calculator up and running.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
My Canon PIXMA iP 1600 - Waste Ink Absorber Almost Full what do I do?
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Then download this tool unzip it and start it.Select the connected USB port number from USB PORT.Click LOCK RELEASE, and select the applicable model name in SET DESTINATION.In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Oct 14, 2009 | Canon PIXMA iP1600 Printer
How to adjust the screen brightness form dark to bright
ok bottom left hand side of keyboard there is a key with fn on it hold this down along with other blue keys that have like little suns on them this is your brightness keys
Sep 06, 2009 | IBM Lenovo ThinkPad X40 2371 Notebook
Waste ink absorber near full PIXMA MP130
Take paper towel and absorb the excess ink from the tray, including  cleaning of the electricial contacts that she excess ink in tray.
Jan 16, 2009 | Canon PIXMA iP1600 Printer
TI 85 Screen is too dark
Press the 2nd key and the down arrow to lighten the screen.
Oct 06, 2007 | Texas Instruments TI-85 Calculator
Royal Scrittore Portable Manual Typewriter Logo
114 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
