Question about Acer Aspire One D257-13473 Netbook
Shuts down on its own when using netbook
No matter what i am doing on the netbook, it shuts itself down. i turn it back on and it will stay on for a minute and then shuts down again.
  • 656 Answers
Possible dead battery, bad a/c adapter or processor.
Posted on Apr 16, 2014
jose_theman
SOURCE: Laptop auto shuts off - will not come back on
have you checked the power coming fine. If you were working on battery mode it cud be coz of battery issue...
remove the battery & switch on the laptop in power mode.
Posted on Dec 03, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: 3rd time, Sorry on the Acer Aspire One Netbook
I own this same computer. It is the mother board Acer is very good at making bad mother boards
Posted on Feb 08, 2009
SOURCE: My netbook deactivates by itself minutes after fully booting up
this is due to static charge accumlated on the motherboard
Just press and hold power button for 45 seconds and release
do not charge the notebook while doing the bove(No power scocket)
Posted on Apr 05, 2009
redlycan
  • 52 Answers
SOURCE: Systems shut down
Sounds like a software error, Try using system restore to set back the pc to an earlier time. Also try starting up in safe mode and uninstall any software that you may have installed.
Posted on Sep 28, 2009
Sebin
  • 712 Answers
SOURCE: shut down when using laptop
Pull the memory stick(s) out of the motherboard and run a single 1x512 in the top slot (under the keyboard) as well as remove the bottom cardslot device as the motherboard had a short causing this on the bottom half (where heat builds up). With these limits (max 512mb and no bottom cardslot usage). It will work great now.
Posted on Feb 03, 2010
My Acer Aspire One netbook shuts down at 38 seconds into booting up... I've timed it a dozen times and no matter I do or don't do (log in, etc) the screen goes balck and it shuts down at 38 seconds. I...
The problem is because your software might have accidentally deleted system files... You can repair your windows using your setup windows disk....(Recommended) OR try starting your laptop in safe mode and try restoring........
Nov 07, 2010 | Acer Aspire One Netbook 8.9" Notebook
Lcd screen stays on when computer shut down
Put the old screen back on to see if it does the same, if it does not, the the new screen may not be the exact replacement. Is the new screen used or brand new? Please post back.
http://s807.photobucket.com/home/budm/allalbums
Apr 29, 2010 | Computers & Internet
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
My HP mini netbook won't reboot.
Press power botton then F8. few option there. select " last known good configuration ...." select & press enter & again enter. Systen start run again. If you found the same error then i suggest formate your OS and reinstalled it.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | HP Mini 1000 Netbook
Systems shut down
Sep 28, 2009 | Acer Aspire One Netbook 8.9" Notebook
Pioneer SD-P62A3 62" shuts off - won't stay on
If this TV turns back only when it is cooled down than it has cold solder joints tha have to be resolderd.
Jul 07, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Acer aspire one won't boot up and turns itself off
Hi there.
Sounds like a generic problem Acer are having at the moment, take the machine back, swap it for a different make laptop or demand your money back if its less than 28 days ago you purchased it.
Thanks for using Fixya!!!
Feb 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computer keeps shutting off
The problem more likely seems with the power supply or the front power button. Donnot try switch on the computer again and again it may cause damage to the motherboard. Use the following link to pin point the problem.
http://tinyurl.com/5bbrxc
Thanks
Proton
Do remmber to rate the solution if it was helpful or fixed your problem.Thanks for using fixya
Jul 05, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Nextvision n5
check your sleep timer settings. they stay on no matter how much you turn your unit on and off.
Oct 29, 2006 | ViewSonic NextVision N5 (n5-2) Video...
Acer Aspire One D257-13473 Netbook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
