Question about HP DeskJet F4280 All In One Printer InkJet
Missing lines and some lines have only half the characters
Document lines - some are just fine, others unreadable or just not there at all
  • 72 Answers
Solution one: Make sure the paper is appropriate for the print job Using the wrong paper for the print job might cause the colors to be faded or dull.
  1. Many papers have printing and non-printing sides. Make sure to load the paper with the print side facing down.
  2. Make sure the paper type is appropriate for the project. Use HP Premium or HP Advanced Photo paper for the best results.
Solution two: Check estimated ink level Use the following steps to check the ink level.
  1. From HP Solution Center, click Settings , and then click Printer Toolbox . The toolbox appears. NOTE: The toolbox can also be opened from the Print Properties dialog box. In the Print Properties dialog box, select Printing Preferences , click the Features tab, and then click Printer Services .
  2. Click the Estimated Ink Level tab.
Solution three: Check the print settings Use the following steps to check and adjust the print settings for the product.
  1. In the software program from which you are printing, click File , and then click Print .
  2. Make sure the product is selected from the drop-down list, and then click Properties or Preferences .
  3. Click the Features tab, and then select the print quality and paper type settings that match the print job.
  4. Click OK to accept the new settings.
  5. Click Print to send the print job.
Solution four: Check for defects using an extended self-test report Extended self-test reports identify specific print quality issues. Use an extended self-test report to determine what is causing the issue. Step one: Print an extended self-test report Use the following steps to print an extended self-test report.
  1. Press and hold the power button (missing lines and some lines have only half the ch - c01346625.gif ), and then press Cancel .
  2. Release both buttons. The extended self-test report print
Posted on Jun 18, 2009
Pdf files garbled
The PDF, or portable document format, file bridges the gaps between many software programs. Someone using one program to create a file need not worry that his intended recipient have that same program, because PDFs just require a free software program to open. On occasion, it may seem like a PDF is just as hard to open as a native file created in that proprietary software, but one of a variety of factors may contribute to the unreadability problem.
Software
One of the most common reasons a PDF is unreadable -- and the easiest to fix -- is that the person trying to open the PDF doesn't have the software to do so. To open a PDF requires the free downloadable program Reader, created and distributed by Adobe, which also makes the PDF-creation software Acrobat. A person who doesn't have Reader installed won't see the familiar red-and-black PDF icon; they'll see a white box symbolizing that the computer doesn't know how to read the file. b> Zoom b> Although it seems quite obvious, a person's screen resolution may have everything to do with why a PDF appears unreadable. Since PDFs are often scans or saved files of standard 8.5-by-11-inch paper, small fonts and occasionally handwriting can get be scaled to tiny dimensions when the sheet is viewed full . Zoomed out, a heavily typed or scrawled PDF may appear as a bunch of jumbled black dots and lines instead of the clear text it would be when zoomed in. Conversion b> Even if you have the Reader software installed, trying to open a PDF in a program that doesn't allow it will cause problems. For example, the Reader software doesn't let you edit a PDF -- you need Acrobat for that -- but you can still use other programs to do things such as redacting, or making black lines to obscure information. You can open a PDF in a program such as Adobe Photoshop and have the PDF be completely readable. On the other hand, if you try to open a PDF in Windows Paint, the operating system's native graphics tool, it will be unreadable because Paint does not accept PDF files. b> Missing Elements b> Something that appears perfectly readable on one person's screen may look entirely unreadable on another, solely because of what's missing from the file. In some cases, a PDF that looks jumbled is a result of missing fonts. While it may seem simple to just create a PDF from whatever document you're working on, if the person who receives your PDF doesn't have those fonts installed, the PDF may be unreadable. You can combat this one of two ways -- try to use universal fonts, such as Helvetica; or take the extra steps to embed the fonts into the PDF. This requires use of Distiller, also an Adobe product. An unreadable PDF may also be missing the password or certificate to render the document readable. Contact the person who created the PDF to inquire whether he locked it with an encryption. Encryption is removable with a key or password. Hope this helps.
Dec 13, 2012 | Computers & Internet
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
Driver for HP Laserjet 6L Pro
Your problem could be either due to the malfunctioning of the driver or you may have installed a wrong printer's driver.
This can be rectified by reinstalling the printer;s driver. Please find the proper driver in the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=21878&prodTypeId=18972&prodSeriesId=27724&swLang=8&taskId=135&swEnvOID=228
~regards,
Jegan
Jun 03, 2009 | HP LaserJet 6L Printer
Canon fax-B840 - Print is "stripey"
No not yet,the problem is the cartridge,sometimes even new cartridges might have a dry printhead
Remove you cartridge,put the printhead side in about 5mm of hot water and keep it there for 5 minutes,take it out and do head cleanning again.
Mar 12, 2009 | Canon FAX-B840 Plain Paper Bubblejet
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
Unreadable characters
check if the file is not currupted.
and the printer is set for RAW printing, probably dont have enough memory, to print the document
try printing like only 10 pages at a time to see if the last 10 print
if it does might want to invest some money in some printer memory
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jul 15, 2008 | Xerox Phaser 8500/DN Printer
Printer seems to be skipping
As the printer is printing fine from word......try to print from notepad and wordpad also.
If it prints fine then it is a problem with internet explorer or it can be also a problem with a particular website.
If you are facing the same problem with all the websites then try reinstalling Internet Explorer.
May 24, 2008 | Dell 922 All-In-One InkJet Printer
Upper half line missing
http://h10032.www1.hp.com/ctg/Manual/c00238458.pdf
manual here in link
sounds like the ink cartridges need to be aligned and cleaned there is an alignment button or in software for this
Apr 17, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Brother MFC-240C
2nd first:
Yes. You should print a alignment test print and follow the instruction which is given on the test print.
I dont understand the first complain:
Do you miss several first squares or do you miss just one?
The latter one is no prob. You can ignore that. The first one (several 1. squares missing) is a serious prob: This indicates that a whole channel is defective!
Did you do a cleaning procedure and check the squares afterwards? If not do so. If you still miss the several 1. squares the ph needs relacement.
Dec 10, 2007 | Brother Multi-Function Center MFC-240C...
Same lines won't print
Sorry, but this is impossible, as a "printer problem". This is clearly a "software/buffer/document" problem.
This can ONLY happen (on two printers, same results) if the DOCUMENT has "exclusive" properties or instruction sets, or "invalid data" for the "missing" lines. For example, you may be printing an HTML document with "DO NOT CACHE" meta tag or java instructions about specific lines or form entries. Many sites (like banks, registration, or encrypted mail/login pages) do this as a security measure to prevent critical data from being inadvertently printed (and ending up outside in trash cans for an ID thief to pilfer). Other possibilities: The lines are NOT text data, they might be IMAGES of text, and saved in a format the printer/buffer does not support. Any of these examples would allow the software to DISPLAY the specific (missing) lines of text -yet NOT print them.
To test my theory (almost a certainty really), simply open the document and select PRINT SCREEN key (or use whatever key commands capture the screen as an image). This copies what YOU see, to the clipboard as a single "image" file (instead of a variety of ASCII characters, images, and code).
Next, open "PAINT" in accessories under MSlop (or any IMAGE editor like Photoshop, Gimp, etc)
Select NEW and agree to the screen size you are using (1024x768, 800x600, 1280x800, etc)
Select PASTE from file menu (or CTRL/V keys). Your document will now appear.
Print the document. The "missing lines" will now show up! If the document is too long for one screen shot, you may have to scroll down, recapture (PRINT SCREEN, etc) and paste one or more images into each other before printing it as a single IMAGE.
Nov 18, 2007 | Canon PIXMA iP90 Mobile Printer
HP DeskJet F4280 All In One Printer InkJet Logo
354 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
