Question about Flojet D1631H5011A Diaphragm Pump Duplex II 115V
Pump won't stay on consistently
My pump doesn't pump consistently. it pumps intermittently. if i disconnect the hose and plug it in it stays on. is the switch bad?
  • 32 Answers
I assume the hose had something on the end of it? Nozzle? The pump has a pressure sensitive switch to protect it.
Posted on May 11, 2014
Bogging
Make sure the fuel pump is kicking on it won't hurt to check the relay but I have never seen one bad yet it could be the plug on the plug on the end of the wires that plugs on the pump this run hot and it burns the ends alot several fuel pumps are replaced because of this make sure you have power at the pump if you can't hear it run it will only stay powered for a few seconds and then kick off. so you might need someone to turn it on while someone checks the power.
Dec 29, 2011 | 2000 Pontiac Grand Am GT
GMC 2000 sierra pick up 1500 sounds like it wants to start but won't turn over. Battery sounds good so I guess battery and alternator are ok. For several years fuel gauge doesn't work and...
It sure could be. But, first...by "won't turn over" you do mean it cranks at normal speed but won't start?
A simple test of the fuel pump is to stand by tank and listen as someone turns key to on. When first turned to on, your pump will activate for 2 or 3 seconds, pressurizing the fuel system, and then shut off if the engine computer doesn't get a cranking signal. Do you hear it come on? If not, then something's not turning your pump on. If you can hear it buzz on briefly, then maybe it's your filter. Another test: Spray a little starting fluid into your intake manifold (remove the big hose going into intake manifold) while someone tries starting it.If it doesn't fire and try to stay running, then it's probably an ignition problem. But if it does fire off, then you know it's a fuel problem-likely your pump or filter. good luck.
Nov 07, 2011 | 2000 GMC Sierra
2005 mustang is overheating and shutting off. Turned the key and it won't stay on. I noticed that the fan might not be turning on. How do I troubleshoot? I put water in the radiator and didn't...
It could be a leak, check your radiator for any leaks, also check upper and lower radiator hoses, water pump, etc. But you said the fan doesn't kick on even when it's reading "hot". So I would look into that more. route the wires and locate the plug, make sure it's plugged in, or reseat the cable by unplugging, and replugging it back in. You could also unplug the negative cable on the battery terminal for a few seconds in attempt to reset the ECU (computer).
Oct 21, 2011 | 2005 Ford Mustang
Doesn't spin fast enough to remove water from tub. makes a steady noise that doesn't get louder or softer just stays steady
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
2002 cavalier. Intermittently won't start. It'll be fine for a week or 2, then suddenly it won't start. When it does start it fires right up. It's got a brand new battery and alternator....
Try looking at the fuel filter, it might be partly clogged or just clogged.Locate the fuel filter, disconnect it and (I know this sounds strange) blow through it, if you get resistance of any kind, then it's bad, if it blows completely through with NO resistance at all, then it's good.
Sep 15, 2017 | 2002 Chevrolet Cavalier Coupe
Need to remove the water pump
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
WATER PUMP REMOVAL
  1. REMOVE RH ENGINE UNDER COVER
  2. DRAIN ENGINE COOLANT
  3. REMOVE GENERATOR (See page CH-8)
91329747
  1. REMOVE INTAKE MANIFOLD STAY
  1. REMOVE WATER INLET PIPE
(a) Disconnect the following hoses: 91329748
(1) Water inlet hose (2) Heater inlet hose (3) Water bypass hose 91329749
(b) Remove the bolt, water inlet pipe and 0-ring.
  1. REMOVE OIL DIPSTICK GUIDE AND GENERATOR ADJUSTING BAR
(a) Remove the oil dipstick. (b) Remove the mounting bolt of the dipstick guide clamp and generator adjusting bar. 91329750
(c) Pull out the dipstick guide. Plug the guide installation hole of the oil pump. (d) Remove the 0-ring from the dipstick guide. 91329751
  1. REMOVE WATER PUMP
    • Remove the bolt, 2 nuts and water pump.
Jan 02, 2011 | 1992 Toyota Tercel
Error code f21, and the door stays locked
Error Code F21 = LONG DRAIN
Most probable cause is a foreign object blocking the filter. Remove the lower front panel. The filter is located in between the pump and tub. remove the filter and clean out foreign material (socks, coins, nails ect..) and reinstall If not check the following items
Press PAUSE/CANCEL two times to clear the display.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump
is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
2000 silverado will start but wont stay running just dies.
I also agree it sounds like a fuel pump issue. Its easiest to remove the box (6 bolts {need impact wrench} disconnect wires at plugs and disconnect gas filler hose) and lift box up. A hoist is easiest but 6 people can lift it easily. The fuel pump can easily then be replaced. Takes about 1 1/2 hrs. to do entire job this way and its so much easier!
Good Luck!
Jun 11, 2009 | 1999 Chevrolet Silverado 1500
GE Profile Harmony Top Load Washer - Won't drain
After more thought, it dawned on me another possible reason. In my case, the washer is draining water, but it keeps cycling the pump on and off, thinking that the pump isn't working properly, and the washer doesn't go into its high-speed spin to eke the last bit of water out. It dawned on me that it could be that the pump is fine, but the sensor is lying, saying there is more water when there isn't.
I looked at the tube for the sensor, and noticed a small blockage of white soft stuff. I disconnected the sensor tube from the tub (in the back), managed to squeeze the blockage out, connected it back up, and now it all works fine (about 5 loads and I haven't seen the pump message)!
So if your pump is draining water successfully, but the washer keeps complaining and refuses to go into the high-speed spin, then perhaps this is your situation as well (or a bad sensor, etc.).
Note that I'm pretty sure the blockage is what ended up ruining my first pump. The blockage matches the color and consistency of the caulk/glue that was used to attach the sensor tube, so my suspicion is that too much was put on at the factory and ended up going into the tube, but not enough to cause problems initially. After several years of use and perhaps a bit of water mineral buildup, it finally became a full clog.
Finally, note that, as you may have guessed from the design of the machine, when you disconnect the hoses at the bottom, there's always a few cups or more of water in the two black hoses and the pump that it can't manage to push all the way to the drain.
Mar 30, 2009 | GE WPGT9360EPL Top Load Washer
Flojet D1631H5011A Diaphragm Pump Duplex II 115V Logo
116 people viewed this question
Top Flojet Plumbing Experts
Andrew Taylor
Andrew Taylor
richie46
Bill Boyd
Are you a Flojet Plumbing Expert? Answer questions, earn points and help others
