Question about Garden
Do u change oil on a 2 cycle - Garden
    New Friend:
  • 7 Answers
Geez mate what planet r u on?
Two strokes require you to put 2 stroke oil in the fuel and the motor gets its lubrication that way. most r 50-1 meaning 100mls of oil to 5l 0f petrol so no you dont need to change the oil on a 2 stroke as you only need to do that on a four stroke
Posted on Apr 16, 2014
Can I use 2 cycle oil when it says to use synthetic 2 cycle oil
Hi, Jordan synthetic oil is better but non-synthetic will be fine for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Know Your 2 Cycle Motor Oil Most frequently asked questions about...
Two stroke oil Wikipedia the free encyclopedia
http://www.royalpurpleconsumer.com/resources/faqs/2-cycle-engine
Guide to Dirt Bike Oils 2 Stroke 4 Stroke
Synthetic 2 Cycle Oil
Nov 21, 2016 | Motorcycles
How do I change the oil in my 4 cycle engine Craftsman Leaf Blower?
If this is a hand held machine. It doesn't require engine oil changing.!
Although its a 4 cycle engine. its basically a 2 stroke engine with valves. It runs on the same fuel/ oil mix as a normal 2stroke engine. 50:1
Apr 21, 2016 | Craftsman Garden
What makes oil come from exhaust outlet
If your gear case oil is not leaking(check level) and the oil is black, it is probably from the normal combustion. These are 2 cycle and burn oil as the run. It is comes out in the exhaust. If you are premixing oil and gas, you may be a little heavy on the oil. If you are not using J/E oil or another engine manf. oil, Merc, Yamaha 2 cycle, switch to it and see if that helps. I have had problems with other brands of 2 cycle oil (pennzoil, Quaker state, etc.
Oct 12, 2014 | Johnson Evinrude OMC New Lower 75/115HP...
How reset oil change light 2011 charger
Your vehicle is equipped with an engine oil change
indicator system. The "Oil Change Due" message will
flash in the EVIC display for approximately 10 seconds
after a single chime has sounded to indicate the next
scheduled oil change interval. The engine oil change
indicator system is duty cycle based, which means the
engine oil change interval may fluctuate dependent upon
your personal driving style.
Unless reset, this message will continue to display each
time you cycle the ignition to the ON/RUN position. To
turn off the message temporarily, press and release the
MENU button. To reset the oil change indicator system
(after performing the scheduled maintenance), perform
the following procedure:
1. Without pressing the brake pedal, push the ENGINE
START/STOP button and cycle the ignition to the ON/
RUN position (Do not start the engine.)
2. Fully depress the accelerator pedal, slowly, three times
within 10 seconds.
3. Without pressing the brake pedal, push the ENGINE
START/STOP button once to return the ignition to the
OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
Source: Owner's Manual page 293
Dodge Charger Owners Manual
Oct 04, 2013 | 2011 Dodge Charger
Reset oil change indicator on 2011 Dodge Charger
within 10 seconds.
OFF/LOCK position.
Oct 22, 2012 | 2011 Dodge Charger
I have a 2004 Yamaha Blaster and I pulled the drain plug too change the oil. It has a reserve box under the seat, how do you drain that oil or does it not get drained. And if not if its low in that box do...
That's not engine oil in that "reserve" box. That's where you put the 2 cycle oil. The bike automatically mixes 2 cycle oil with your fuel. Just put regular fuel into the tank, and 10w 30 into the engine fill port on the motor and put 2 cycle oil into the tank under the seat.
Nov 20, 2010 | Yamaha YZ 250 Motorcycles
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 | Garden
Put the wrong oil in my riding lawn mower. Should
It should be OK, provided no damage was done to the engine when you ran it. Hopefully, you caught it quickly. Just to be on the mechanically safer side, I'd change the oil again. If your mower is equipped with a filter and you didn't change it after the 2 cycle happening, change it, too. If you have a filter, always fill the filter with oil before you mount it if the orientation of the filter allows. Fill the engine with oil. Check and start. There may still be some smoking until you clear the residue out, and you may even have to clean your spark plug(s) a time or two. You should see a gradual improvement in your exhaust plume. If any damage had occurred to your engine, you will likely hear abnormal sounds. If this is the case, shut the mower down immediately and investigate forther, with your local professional.
Best Regards! --W/D--
Jul 11, 2009 | Garden
What is the correct oil/gas mix ratio?
The 2 cycle needs oil and gas mixed while the 4 cycle needs the oil changed every 10 hours of use. 2 cycle is 28:1
Jul 03, 2009 | Mantis 2-Cycle Tiller
I need to change oil in my 05 Vento triton. How do I do that?
follow hose from oil tank disconnect end leading to engine it pours right out use synthic oil either 2 cycle etc based on gine do not over fill tank.
Jun 19, 2009 | Vento Gladiator XLS Motorcycles
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
