Question about Giagni LL800 Andante Open Trough 1-Handle Lavatory Faucet: LL800-BN S
Our Giagni Andanti model LL800-BN bathroom faucet drips after water is turned off need to know how to make an adjustment to stop drip
I purchased the same model. Hooked it up and it kept dropping after turning the water off. Returned it to Lowe's for replacement. Installed that unit and it drops but not as bad. Called Giagni - they are sending a free replacement cartridge. I asked if it was a problem with that model, she replied yes.
Posted on Dec 03, 2014
    Habit-Forming:
  • 40 Answers
Turn the water off. Remove the handle, usually has an Allan wrench screw on it. Take out the stopper unit and clean it. When you are done tighten it as you can without stripping it, Out it all back together and it should work. Sometimes you need to replace the washers or internal unit itself, but try this first.
Posted on Jun 18, 2014
My bathroom faucet drips. How do I repair?
there is a seal in the valve assembly that is warn they usually dell kits for it from a hardware or home depot store
Sep 11, 2014 | Plumbing
Ll800-BN faucet drips after water is turned off need to know how to make adjustment
More than likely, the cartridge will need to be replaced. I am not familiar with this particular faucet. However, most faucets are very similar in the breakdown procedures.
Be sure, first, to make sure water is turned off at the shut-off valves under the sink. Next, you should find a set screw on the handle; this is usually removed with an allen wrench. The screw is typically located on the handle of the faucet; often times, the set screw is covered by a small plug that is either red and blue, or will match the finish of the faucet.
Once you remove the handle, you may find another screw-typically it is a #2 Phillips screw, or a nut that loosens to gain access to the cartridge. Once you remove that assembly, the cartridge will need to be removed. Also, there may be a slide clip holding the cartridge; if it has that clip, you will find it just under the stem of the cartridge and it is usually found closest to the wall side of the faucet. Manufactures make cartridge removal tools, as sometimes the cartridge can be difficult to pull out. However, more often than not, I use a pair of channel locks. If you choose that method, just be sure you do not scratch the finish on your faucet. Keep in mind, it may take some force to remove the cartridge.
If you order a new cartridge for your faucet beforehand, the new cartridge will come with replacement instructions.
This is a very simple procedure for a handy homeowner to tackle. If you call the services of a plumber, I expect your cost to be anywhere from $75-$125. Again, just be certain that water is turned off first.
Apr 16, 2014 | Giagni LL800 Andante Open Trough 1-Handle...
Faucet won't stop dripping. Does it need replacing?
No it doesn't need replacing gif you turn your water source off and take the faucet apart most of them have rubber O rings in them and you can go to your local hardware store and get new O rings. It is cheaper then buying a new one faucet
Feb 28, 2013 | Furniture
I have a slow drip on my bathroom faucet. how do i repair it. p-f 8" w/separate hot & cold faucets
Full instructions with diagrams here:
http://home.howstuffworks.com/home-improvement/plumbing/how-to-repair-a-faucet1.htm
very detailed and should help you stop that annoying drip..drip...drip
Hope this helps, if so please leave feedback. If not let me know and I'll try and help some more
Feb 03, 2010 | Price Pfister Plumbing
Slow drip of water inside the drum. Don't see no moisture but I can hear it dripping. No Moisture on the floor. Any ideas where it could be dripping from?
Turn the water faucets off and listen for the drip to stop.
If the dripping noise stops,replace the water inlet valve on the washer were the hoses connect.
Enter your model number in the site referenced here for parts.
www.appliancepartspros.com
Jan 24, 2010 | Maytag Washing Machines
To turn faucet handles off
Re seat the tap and replace the washer with a half ball round washer , will close easier.
May 24, 2009 | Plumbing
Leaking forchettes adjustments
Whether it is hot or cold water, just remove your knobs and tighten the screws on the valves. No special tools needed.
Mar 30, 2009 | 2003 Renault 181
Giagni LL800 Andante Open Trough 1-Handle Lavatory Faucet: LL800-BN S Logo
245 people viewed this question
Top Giagni Plumbing Experts
Donni Steen
Tom Chichester
Are you a Giagni Plumbing Expert? Answer questions, earn points and help others
