Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
How to remove the icemaker from whirlpool refrigerator model #WRF990SLAM00
fridgetech
  • 473 Answers
SOURCE: Whirlpool icemaker
Need to check the heater on the ice maker with ohm meter to see if it shows resistance. If no resistance then replace the whole ice maker. If resistance is good then the best thing to do is replace the ice maker module and thermostat (bimetal).
Posted on Oct 06, 2007
woodchuck789
  • 4070 Answers
SOURCE: Whirlpool
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Posted on Oct 03, 2009
jyackle5
  • 8197 Answers
SOURCE: How do I remove the icemaker?
To remove the Ice maker you need to remove the 2 screws that are circled in red on picture below.
Posted on Mar 12, 2010
jumptrout51
  • 3361 Answers
SOURCE: the icemaker in my whirlpool refrigerator won't
Here is your manual:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f6bad9d0e44bf81d852573e900695d73/$FILE/8178689%20%28Icemaker%29.pdf
Posted on Jul 11, 2010
  • 2699 Answers
SOURCE: We have a whirlpool refrigerator
that model number doesn't come up?did you check the fill line that fills the ice maker to see if it's froze up?get a hair dryer and a screw driver,stick the screw driver into the fill line,you might have to remove the ice maker,if the screw driver hits ice blow the hot air into the hole and keep the screw driver in the line,the screw driver will heat up and help get the ice out.you can pull the fridge out and heat the fill line with the hair dryer on the back of the machine where the fill line connects in the back up top.if there's no ice there make sure water is coming to the fridge,also you can jump out the ice maker to manually check it to see what's happening to it,i'll look up a link and send it to you,just copy and paste it and it will show you how to jump out the ice maker and how to jump out the water valve,you'll have to pop off the front white cover of the ice maker,get a piece of wire to stick into the holes to jump it out.
Posted on Jun 05, 2011
How do I remove the ice maker from my whirlpool wrf532smbw?
We would recommend having a local certified technician in your area properly remove your icemaker. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 01, 2017 | Whirlpool Refrigerators
Need to remove my icemaker from refridgerator
What is the complete model number of your unit?
Dec 04, 2012 | Whirlpool Refrigerators
How do I remove the icemaker? on a Whirlpool refrigerator model ED5vhgxml10 ?
Mar 11, 2010 | Whirlpool ED5VHGXM Side by Side...
I have a Whirlpool refrigerator with an ice maker and when the icemaker is filling with water it leaks from the front of the tray into the ice storage bin.
1. icemaker is not level. (check and re-level)
2. icemaker has a crack in the mold.(replace i/m)
3. Water level set too high.(remove front cover and adjust water level screw counterclockwise)
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Replace selenoid and water is still not going to ice maker
Did you pour about 2/3 cup of water into the icemaker and did it dump ? If you did pour water into the icemaker , and it did not dump the cubes , then the icemaker is bad . If it did dump , so you replaced the water valve , then the fill tube directly at the icemaker is frozen with ice . It will need to be removed ( fill tube at icemaker ) and the ice cleared out by hot water . On some models , behind the refrig , 2 screws hold the fill tube in place . Remove the tube , and clear the ice . When reinstalling , have someone guide it from inside the freezer , to where it mounts on the icemaker fill cup .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker froze up and I want to remove it so that can thaw it out
there is 1 screw on the back right hand corner of the icemaker remove this screw then remove the wiring cover that this screw held in place. the icemaker will then slide straight out you will then unplug the icemaker at the wiring harness and be able to completely remove icemaker. thanks for using  fixYa peyton
Feb 17, 2009 | Whirlpool GS6NBEXR Side by Side...
I have a Whirlpool side-by-side refrigerator and I can't get the icemaker front panel off to install a new icemaker kit in order to fix the frosting around the icemaker chute. How does the icemaker front...
according to the model number that you listed in the heading it just shows a cover door that slides out and down and is attached to the top freezer shelf. is this correct? If so pull one side of the slide and it will release the cover.  Now if your talking about removing the dispenser cover on the fron of the freezer door there are 2 slots on the bottom of the cover that you insert a flat tip screw driver and carefully pry the cover off. hope that helps Peyton
Jan 27, 2009 | Whirlpool ED5VHGXM Side by Side...
Whirlpool Ice Maker Won't release ice
Jetguy77,
I have a 1993 year (16 years old now) Whirlpool side-by-side with icemaker, Model ED22PW. I have had similar problems with the icemaker - water goes in, freezes, but ice does not eject from tray. It has happened to this unit 2 times since 1993. It turns out the problem is not the thermostat. It is the icemaker motor module. The icemaker has a small synchronous (clock) motor that rotates the ice ejector. When it goes bad, the ejector does not rotate, either because the module timer had failed or the motor itself has failed. The solution is to go to your nearest applinace parts dealer and by a new "icemaker motor module" for Whirlpool Model (your model here). Mine cost $58.85 the last time I replaced it in 2006. To install the new module, you will need to remove the icemaker from the refrigerator. Mine has 3 screws that attach it to the side. Also unplug the power & control cable. The water tube slides out when you pull the unit forward. When you get it out, it is then easy to remove the motor module and insert the new one. You may have to reset the timer on the module to get the tray to fill completely.
Jan 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Broken ice maker in whirlpool side by side refrig model no.ed2ghgxmq00
1. Check freezer temp. Above 5 degrees? Icemaker will not start. 2. Make sure there is water coming to the refrigerator from the supply line. 3. Is the refrigerator clean underneath? Fan running? Dirty refer bottom can cause high freezer temps, see #1. Ideal freezer temp is -5. Icemaker and valve should be checked by a service tech.
Jun 26, 2008 | Whirlpool ED2FHSS Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
191 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
