Question about Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50"
Solenoid how do you know when solenoid is bad?
    Filmmaker:
    Uploaded 5 video answers.
    Problem Solver:
  • 9 Answers
Try watching this video
Posted on Apr 16, 2014
A 4l60e transmission how do I no if i have a bad 3-2 downshift sol on a 1994 chevy Pick up
Albert, Have truck scanned for trouble codes. To test a transmission solenoid, use hand held ohm meter. Instructions in second link below, the attached links are informative on the different procedures used to test solenoids.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test shift solenoid 4L60E
http://etereman.com/blog/general-motors-transmission/how-to-diagnose-a-bad-solenoid-in-your-4l60e-transmission
Shift Solenoid and Tests GM 4 3L 5 0L 5 7L
How Can Tell If My 4L60 Transmission is BAD
May 20, 2016 | Chevrolet Cars & Trucks
I have a 2007 Dodge RAM 1500. Where is the shift solenoid located.
All the shift solenoids are in the transmission. You will have to remove the oil pan from the bottom of the transmission to access these. All the solenoids are on a package/ housing. They come off as a unit. You can replace these one at a time, but you really need to know what your looking for. It could be a bad solenoid , bad wiring in the transmission, bad connection at the plug going to the transmission, bad wiring going to the transmission. Computers will pop out a code, but you have to check everything that is related to that sensor/ solenoid.
Aug 03, 2011 | 2007 Dodge Ram 1500 Quad Cab Sport
I'm getting a lot of fuel vapor fumes inside the car. How do I know if its the solenoid? Will a bad solenoid effect gas mileage?
A bad fuel pressure regulator will.Pull vacuum line off of it and if fuel runs out of it than the diaphram in the regulator is bad.
Apr 20, 2011 | Ford Taurus Cars & Trucks
Gear shift solenoid bad
not an easy one to repair if you are a novice. it may not actually be the "shift lock solenoid". there is a small switch on the right side of the shifter assembly, which i have found bad connection at, which fixed the shift lock solenoid malfunction. not an easy one to fix if you dont know what you are doing.
Nov 18, 2010 | 2008 Nissan Rogue
Starter solenoid replace , when do I know it's the solenoid, and not the starter motor itself ?
If the solenoid goes bad, the starter will spin freely creating a loud noise. If the starter is bad, you generally here a click noise (the solenoid kicking out but the starter not turning)
Apr 14, 2010 | 1999 Isuzu Trooper
Auto door lock will not lock or unlock drivers door in 2003 Ford Explorer.
I would check the fuse next to the dash. When you open the cover it will have a list of fuses. You are looking for "DR LCK".
You may also have a bad solenoid which does the work, or a bad relay.
If fuse is good you will have to see if you have 12 volts to switch.
If yes then you will have to take door panel off and inspect solenoid, see if you have 12 volts when switch is operated, if yes, and solenoid is not operating replace bad solenoid.
Please let me know what you find.
Feb 10, 2010 | 2003 Ford Explorer
Ice maker not working
Cause could be the solenoid valve which controls water flow into the ice maker.
Could be bad solenoid, bad relay for solenoid, clogged solenoid valve, corroded electrical connections, etc.
More info? Let me know...
Charlie
Aug 14, 2009 | Refrigerators
98 Jeep Grand Cherokee - will not start - starter solenoid clicks once when engaged but starter will not turn engine - plenty of voltage (14V with jumper cables connected) going to solenoid - with screw...
The starter is bad. Solenoid is good, the starter itself is bad. You can remove it and take it to Schuck's/Chief's/Kragen/NAPA, they will test it for FREE. You can't beat free!!!
Jul 16, 2009 | 1998 Jeep Grand Cherokee
The washer will not call for cold water.
if all water supplies are clear, yes faulty switch. make sure you checked the screen on the water supply, both ends.
Jun 14, 2009 | Kenmore 24902 Top Load Washer
2000 Kia sephia starting problem
The problem could be a few things. First, you could have a bad starter. You could have a bad solenoid (device on the starter that "makes the contact" between the battery and the starter. Finally, I have seen bad cables between the battery and the starter. If you have access to a multimeter, you can test the resistance of the cable between the battery and the starter solenoid. It should read almost zero ohms. If the cable is heavily corroded, it could be much higher and would prevent the starter from operating. (this is very unlikely though) I would lean heavily toward the starter or the solenoid. Let me know if you want to know how to test the solenoid.
Dec 27, 2008 | 2001 Kia Sephia
Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50" Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
