Question about Giagni LL800 Andante Open Trough 1-Handle Lavatory Faucet: LL800-ORB
Ll800-BN faucet drips after water is turned off need to know how to make adjustment
    Scholar:
  • 35 Answers
More than likely, the cartridge will need to be replaced. I am not familiar with this particular faucet. However, most faucets are very similar in the breakdown procedures.
Be sure, first, to make sure water is turned off at the shut-off valves under the sink. Next, you should find a set screw on the handle; this is usually removed with an allen wrench. The screw is typically located on the handle of the faucet; often times, the set screw is covered by a small plug that is either red and blue, or will match the finish of the faucet.
Once you remove the handle, you may find another screw-typically it is a #2 Phillips screw, or a nut that loosens to gain access to the cartridge. Once you remove that assembly, the cartridge will need to be removed. Also, there may be a slide clip holding the cartridge; if it has that clip, you will find it just under the stem of the cartridge and it is usually found closest to the wall side of the faucet. Manufactures make cartridge removal tools, as sometimes the cartridge can be difficult to pull out. However, more often than not, I use a pair of channel locks. If you choose that method, just be sure you do not scratch the finish on your faucet. Keep in mind, it may take some force to remove the cartridge.
If you order a new cartridge for your faucet beforehand, the new cartridge will come with replacement instructions.
This is a very simple procedure for a handy homeowner to tackle. If you call the services of a plumber, I expect your cost to be anywhere from $75-$125. Again, just be certain that water is turned off first.
Posted on Jun 29, 2014
Our Giagni Andanti model LL800-BN bathroom faucet drips after water is turned off need to know how to make an adjustment to stop drip
Turn the water off. Remove the handle, usually has an Allan wrench screw on it. Take out the stopper unit and clean it. When you are done tighten it as you can without stripping it, Out it all back together and it should work. Sometimes you need to replace the washers or internal unit itself, but try this first.
Apr 16, 2014 | Giagni LL800 Andante Open Trough 1-Handle...
Thermostatic valve does not turn
followt this steps and fix it. God bless you
  1. Turn off the water supply and open the faucet handle to relieve water pressure.
  2. Carefully pry off the trim cap with a small screwdriver or putty knife.
  3. Remove the locknut with an adjustable wrench, then lift the spindle out of the faucet.
  4. As needed, remove and replace the O-ring. Before reinstalling, coat the stem lightly with plumber's grease.
  5. As needed, remove the retaining screw and pry out the washer. Install an exact-replacement washer and tighten it.
  6. As needed, inspect the seat and replace if damaged.
  7. Install the valve and tighten, then reinstall the handle and test.
Nov 28, 2013 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
New Faucet drips for several seconds after it is
some of these new faucets are "soft off" which means the will drip or run for a second or 2 before the water stops. I know this can be annoying, but it is how some of them are made
Aug 01, 2010 | Price Pfister RT6-B0XX Georgetown Two...
The water pressure for the hot side is less than the water pressure for the cold side. what can be done to correct this?
one of supply tubes partly blocked,turn off water supply ,disconect coupling for tubes underneath,
remove screen on faucet and blow out with air this
should remove obstruction replace in reverse and recheck pressure
Nov 01, 2009 | Kohler K-10416-BN Fort½ Single Control...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
Feb 26, 2009 | Kohler K-10416-BN Fort½ Single Control...
No water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Dec 25, 2008 | Plumbing
Tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Nov 09, 2008 | Banner Faucets Pro Series M580 Single...
Giagni LL800 Andante Open Trough 1-Handle Lavatory Faucet: LL800-ORB Logo
220 people viewed this question
Top Giagni Plumbing Experts
Paul Carew
Tom Chichester
Are you a Giagni Plumbing Expert? Answer questions, earn points and help others
