SOURCE: HP Media center 1170m
Hello Moneymakey, have you sorted out your machine's problem? I had the same problem on my HP t350.uk machine but with different
symptom. But later on, the machine occasionally ran into a freezing
state, not responding to any input. So a
few days ago, I turned off the machine, and did some connection checking on the
motherboard. But this time, the flashing never stops flashing, even after I
have unplugged almost everything. The flashing stops only after I unplug the power to the
motherboard. By manipulating this power cable to the motherboard, I can manage
to turn the flashing to the constant flashing, but the machine still can’t be
turned on. I was just wondering this event sequence would inspire any
useful trouble shooting thoughts Dr Q Mei
It first appeared one year ago when my daughter switched off the machine
(everything was fine up to this point) at night. The next day, the machine
could not be started but she noticed the machine's power supply light was
flashing. It was in this state for a few hours as she does not know what to do.
Then suddenly the flashing stopped and machine can be started and everything returned
to normal.
Then about half a year ago, I turned off the machine to add some
memory (from 512mb to 1.5gb) and could not start the machine while the
power supply light was flashing. My daughter told me the trick but it did not
work after a few hours. So I left the machine connected to power over night.
Next morning, the flashing was gone and everything returned to normal.
SOURCE: no power at all
I am having the same promblem I think does your light flash on and off on power light, mine does I am going to trouble shoot the board on monday at my company I work for I am a tech at a company that repairs other lcds this big and bigger but not for vizio so if i find anything I will let you know if you want?
SOURCE: no power
Bring your Tv to Micro Electronics
1515 Britannia Rd E, Unit 12
Mississauga Ontario, L4W 4K1, CANADA. ask them to chek it out, they are the best, they will let u know is it possible to fix or not, how much its gonna cost you, if its fixable and can get the parts you will get the tv in ur hand next day. call them 905-565-6595
SOURCE: Plasma TV-power light does not come on
Hello!
most probably the fuse inside the circuit blown out, You should open the back of the tv to become circuit board visible. But this hard when novice do it.
To be sure that everything will be alright i would rather suggest you to bring the tv to the nearest service center. maybe warranty work for that.
best regards,melnavz
SOURCE: Kenwood AR 404 burning w/ open flame.
You are literally playing with fire. Obviously the unit is in dire need of service! Please, take unit in for check out by a pro/tech
