How do I take the soap dispenser out of the washer to clean it?
I can't take the soap dispenser out to clean it.
  • 957 Answers
U don't say what washer u have on most front loaders there is a tab lever that u see when u open up the drawer all the way. push down on the lever and pull out. it should slide the rest of the way out.
Posted on Apr 16, 2014
huuum
  • 750 Answers
SOURCE: Clothes are not clean How can I take washer aprt to clean soap dispenser???
Dear carolesergy,
Welcome to fixya
You sad,My clothes get dingier ever week from using my washer especially the towels. They are now Grey and not white
1.Here are some ideas and INFO!
2.How old is your MAH5500B washer and did you buy it new?
3.Do you use HE High Efficient detergent?
4.Do you ONLY put the proper amount of detergent directed to be used by the manufacturer?
5.Using to much detergent will degrade the seal and eventually destroy the bearings.
Which will cause oil to leak out on your clothes and sometimes make gray stains on them !
6.Is there tiny gray oily pieces in the wash and on clothes?
7.Look closely at your rubber seal around the opening. Is this worn or deteriorating away slowly due to bleach or detergent? Is it a gray or black rubber?
Please have patients and bear with me, with all these questions I propose to you here!
I am searching with your eyes for things I have seen in the past about this model"
Here are some reasons this may also happen!
How large of a load can I wash in my Maytag Neptune washer?
* The tub can be loaded completely full with dry, unfolded clothes. However, do not pack the tub tightly. If the load is heavily
soiled it is very important not to overload the washer.
My whites are not as white as I’d like.What can I do?
* Wash white loads using the cotton/sturdy fabric selection. Select the hot wash/cold rinse temperature setting and put 3/4
cup of chlorine bleach in the bleach dispenser. The bleach will be dispensed in the final minutes of the wash providing for
optimal whitening. Maytag recommends a hot water wash temperature of 120-140° F (49°- 60° C).
Also:
*The lint filter in side the machine may be clogging with dirty lint!
*Which means you needed service!
I hope one of these solutions is the reason!
Let me know how you do!
Huuum
Please remember to leave a rating for me!
Posted on Oct 10, 2008
  • 353 Answers
SOURCE: water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Posted on Dec 15, 2009
  • 161 Answers
SOURCE: HOW TO CLEAN SOAP DISPENSER DRAWER ON LG WASHER
On the very back top of the drawer is a lock lever that you depress to relase the drawer. Push it down and pull drawer out. Clean and replace.
Posted on Jan 27, 2010
SOURCE: kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
Posted on Jun 01, 2010
Testimonial: "good to go "
blueextc3221
  • 15935 Answers
SOURCE: We have a Kenmore frontloader pooring water from soap dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Soap dispenser not working. The soap remains in the dispenser even after the cycle has finished.
Sounds as if the line is plugged. Old soap may have collected inside the line and dried up, preventing passage of new liquid to pass through. Call the Manufacturer and ask them how to clean out the line.
Jan 11, 2018 | Dishwashers
Issues with leftover soap and water in soap dispenser when wash is done. Cleaned dispenser and still doing it!!! PLEASE HELP
Remove the soap drawer completely, and wash it in warm water. Clean the roof of the hole where the dispenser drawer is using a plastic pot brush and some hot water. There are holes where the water comes from and they get splashed with soap.
Jan 31, 2016 | LG WM2140CW Washer
Water leaking out of soap dispenser
I have had this happen. I have taken the dispenser tray out and cleaned the area where the water and the detergent will flow into the washer at. This area had gotten some gunk build up, once I cleaned it, it has not leaked since. Now I just routinely look at this and make sure that it is clean. Hope this helps you.
Mar 06, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Washer will not dispense soap from dispenser.
make sure that the soap dispenser if clean and free of residue build up. if this is clean you need to replace the dispencer
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Pressure washer won't pull the from the soap dispenser
Nozzle dirty, clean out nozzle with small diameter wire. Soap dispensing only happen at nozzle low pressure setting
Jul 26, 2009 | Honda Maxus Pressure Washer MX5222
Whirpool washer fabric softener container
i would quit using powder soap and use the HE soap.I would take the soap dispenser out and clean it out and also clean out behind the dispenser.run just water thru machine or try washer magic to clean out the machine.you can find washer magic at most home depots or lowes or even a appliance parts house.
Mar 08, 2009 | Whirlpool AWM8143 Front Load Washer
SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
WFR 2460 Front loader
We went through the whole "clean the soap dispenser" deal and results were the same. Exploratory surgery revealed that the Prewash hose (for lack of better term), which connects from the top of the drum housing to the right side of the dispenser drawer (facing the machine)was completely clogged with gunk. Especially strange since we don't prewash hardly anything, ever. The hose that connects the bottom of the detergent dispenser with the side of the drum housing did have a lot of buildup, but I do not believe it was the cause because this was only happening on the rinse cycle. I also found the flow meter was frozen up.
Jun 27, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
