Question about AEG Washing Machines
End of life for OKO Lavamat 538?
Hi After decades of faultless service, my OKO Lavamat 538 now can't cope with the start point of its anti-clockwise drum revolution, it has a kind of starting fit and bangs about. This is only during the wash cycles, and almost regardless of load size. Clockwise motion is fine. I paid the call out fee to a repair guy, but he had no idea. Is this fixable do you think, or should I just accept its days are over?
    Top Expert:
  • AEG Master
  • 40,418 Answers
"After decades of faultless service.." The word decades should provide a clue. Appliances don't last forever.
Posted on Jul 22, 2017
  • 878 Answers
SOURCE: washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. back.
Posted on Dec 01, 2006
  • 1073 Answers
SOURCE: Kenmore F/L Washer Model 41743142200 tub loose
you may have a dampening shock that is bad
Posted on May 08, 2008
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
SOURCE: AEG Oko-lavamat 538 manual
Posted on Dec 10, 2008
  • 93 Answers
SOURCE: AEG OKO lavamat 538 - half load must the button be in or out
press it in
Posted on Dec 29, 2009
Testimonial: "this problem has been puzzling me for ages and the machine is such a wonderful old faithful OKO lavamat 538 - thanks for the almost instant answer "
Where is the filter for die AEG lavamat 538 washing machine and how do you clean it?
The only filter/screen I am familiar with is the one in the hoses the supply hot and cold water to your machine. They should be checked once in a while but I have never found much in them.
However, the manual for your machine is located here:
AEG OKO LAVAMAT 538 Operating Instructions Manual
Best wishes,
Aug 24, 2016 | AEG Washing Machines
What means c1 on aeg oko lavamat 74500
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
Aug 20, 2014 | Washing Machines
Drum problem?
You May have solved this but it sounds like the drum bearings have worn out...
Apr 16, 2014 | AEG Washing Machines
I lost the manual and i dont know the various programs
I've downloaded manuals for 2 washing machines and a DVD player from manufacturer's web sites. basically just put the in the details of the machine and you should be able to search for the manual. secondly if that's no good for you there is usually a phone number for services stuck to it some where, (it's on the bottom left hand side of mine) give them a call and ask if they can send you one. Hope this helps
May 16, 2012 | Washing Machines
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
Aug 24, 2008 | Washing Machines
Operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
Aug 03, 2008 | Washing Machines
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
- Turn Off - Press down Prewash and Soaking together. Keep them held down. - Slowly turn the knob clockwise to Gentle Spin - This should reset the machine
If you get a beep instead of a reset, there is a problem. - Keep the two buttons held down. - Slowly turn the know anti-clockwise to Wool 40 degrees - It should now give you an Error Code. - Google for the manual, which will tell you what the error code means
Feb 29, 2008 | Washing Machines
Washing Machines Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
