Question about Gateway Nv75s19u - 6gb - 1 Tb - 17.3" Laptop
Replace Ram Hi, What is the biggest frequency this laptop can handle? I'm wondering if it can take a pair of DDR3 corsair vengance 4GB 1600 mhz
    Top Expert:
  • Gateway Master
  • 26,668 Answers
If you take a look at www.mrmemory.co.uk correct data is there.
Posted on Apr 16, 2014
Can I use Transcend 4GB DDR3 1600 RAM instead of 4GB DDR3L 1333 RAM in BiostarJ1900NH2 mother board
No, Biostar advertises that you should use low voltage memory on this board. My experience that when 1.5 volt memory is installed in a 1.35 volt system, it is not reliable. (Intermittent Crashes.)
Dec 13, 2015 | Transcend Computers & Internet
Does Intel DH61BF motherboard supports 4GB 1600Mhz RAM ?
OK, I was looking for a solution, but hardly got anything that clarify if it's compatible or not. But what I did find out is that if you install a 1600MHz memory stick, this one will clock down to 1333MHz in order for the MB not to crash. Here is a C/P.
Part #: 2xCT102464BA160B • 16GB (2x 8GB Kit) • DDR3-1600 - 1600Mhz - PC3-12800 • CL11 • Dual Rank • Non-ECC • Unbuffered • 1.5V • 16-chip 512Mx8 • Lifetime Advance Replacement Warranty • This 1600 MHz module is programmed to clock down to 1333 / 1066MHz where the system requires it.
Mar 04, 2015 | Intel Computers & Internet
I upgraded my memory to corsair 4gb 1600 ddr3 ram on my samsung rc410 laptop. BIOS is showing the 4gb but windows is not booting up, it is showing blue screen. i have tried in another dell laptop but it...
i would take out all ram , then just put in the 4gig
there is 2 slots for ram
if that is the same then windows may have crashed , try getting into safemode by pressing f8 after bios
Oct 30, 2013 | CORSAIR 4GB - PC12800 RAM, DDR3, 1600MHz,...
Can I add 4gb more RAM
see:http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=5295969&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c03536888-9%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
probably no, 32 bit systems have an under 4Gb limit. looks like 2 memory slots 1,2,4 and 8Gb supported.
Memory upgrade information
  • Dual channel memory architecture
  • Two 240-pin DDR3 DIMM sockets
  • Supports DDR3 DIMMs
    • PC3-10600 (1333 MHz)
    • PC3-12800 (1600 MHz)
  • Non-ECC memory only, unbuffered
  • Supports 1 GB, 2 GB, 4 GB and 8 GB DIMMs
  • Supports up to 4 GB on 32-bit* systems
  • Supports up to 16 GB on 64-bit systems
Aug 29, 2013 | HP Pavilion P6 Intel Pentium Processor,...
How do I add ram to my acer aspire 5742
Please note: Never touch the gold pins of the memory chips and earth yourself out before you start to discharge any static build up. Installing the RAM is just a case of unscrewing the relevant plastic panel on the base of the laptop, gently pulling apart the white handles that hold the current RAM chips in place, slide out the old and then slide the new chips into place making sure that they go in the same way round as the old ones came out. Gently push down on the RAM chip once its seated correctly and you should hear the white handles click when the module is in place.
There looks to be several different variations on the 5742 model so I'd recommend finding out the exact laptop model number and amount of RAM currently installed before purchasing an upgrade. From what I can tell your model comes with either 3Gb or 4Gb of DDR3 SDRAM 1066 MHz with the motherboard accepting a maximum of 8Gb but you really need to make sure that you've got exactly the right type of RAM or your laptop won't even get to the BIOS after installation before it starts beeping at you.
You should also be aware that specific versions of Windows have a maximum memory limit so you could go to the trouble and expense of installing a pair 4Gb modules only for the operating system to use just 4Gb. More info on 32bit and 64bit operating system memory limits can be found at this link.
Apr 12, 2011 | Acer Computers & Internet
I have an asus m4a88t-v motherboard with an AMD phenom II x6 1090T processor that I just built. When I turn it on, it powers up but nothing shows up on the display. There are no beeps from the motherboard...
make sure the battery in mother is good and double check fuse. what it is you have a 3x2gb corsair is over loading your mhz ram get a higher battery for higher performance and see what happpens.
Feb 17, 2011 | ASUS 3 Motherboard - M4A88T-V EVO/USB
Hello, ddr3 ram
hi
thank you for using Fixya
boss frist of all you have to chack you PC is supporting DDR3 then only you go for new RAM
May 14, 2010 | Corsair Memory (CWC1001003)
Ram assurance
The schematic layout of the P5VDC-MX on the user manual shows that there are 4 DIMM banks, set as 2 X 2 rows, 2 DDR2 and 2 DDR.
The user manual explicity states:
I am running different frequency modules without any problems. With the info above provided by ASUS, it may be possible that a fix could be available with a BIOS update. Otherwise, you can opt to use a lower capacity RAM along with your 1GB Corsair.
Hope this helps.
Jun 24, 2009 | ASUS P5VDC-MX Motherboard
Ram
Your motherboard can take DDR or DDR2 RAM modules.
Crucial says: "Each memory slot can hold DDR PC2700,DDR PC3200,DDR2 PC2-5300 with a maximum of 1GB per slot." No sense getting 4GB since the max is 2GB.
You can get higher speed RAM (PC2-6400) because it is backward compatible.
I would go with the 2 X 1GB Corsair from the ones listed.
Or consider the options on Crucial's site. See this page:
http://www.crucial.com/store/listparts.aspx?model=P5VDC-MX
Two 1GB modules of DDR2 PC2-5300 run about $34 US.
(PS. Your 450W power supply will handle about anything.)
Jun 03, 2009 | ASUS P5VDC-MX Motherboard
Purchasing RAM
DDR3 modules can transfer data at the effective clock rate of 800–1600 MHz using both rising and falling edges of a 400–800 MHz I/O clock. In comparison, DDR2's current range of effective data transfer rate is 400–800 MHz using a 200–400 MHz I/O clock, and DDR's range is 200–400 MHz based on a 100–200 MHz I/O clock.
decide urself, depends onur system support and ofcourse ur buying capacity.
DDR3 is better
Oct 30, 2008 | Computers & Internet
Gateway Nv75s19u - 6gb - 1 Tb - 17.3" Laptop Logo
27 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
