Question about Refrigerators
Burner won,t stay lit on lp
Igniter is working and i get a blue flame but after 15 or 20 secs and releasing very slowly flame goes out. is it possible it could be a thermocouple
  • 93 Answers
SOURCE: Dometic rm 2652 fridge works on a/c. i get a check
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Posted on Mar 15, 2009
SOURCE: Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Posted on Nov 17, 2009
  • 15 Answers
SOURCE: norcold refrigerator burner will not stay lit
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Posted on Jan 29, 2010
SOURCE: i have a norcold 3163
I have the same model refrigerator in my 1999 Eurovan. Before you leave for your trip, if you haven't used the refrigerator for some time make sure it will light before you leave and run it for awhile. This will help insure it will light when you are camping. A good trick I learned is to light one of the burners on the stove for a minute before you switch the refrigerator to propane. That seems to help. Also, don't release the ignitor button on the refrigerator until 15 to 20 seconds and then do so VERY VERY SLOWLY . One other trick is set the cooling dial in a different position than the "Start" position. If that doesn't work then turn it back to the Start position. Sometimes it takes several times to get the refrigerator to light but once it is it will stay on.
Posted on Feb 01, 2010
  • 1416 Answers
SOURCE: I have a Dometic DM2652
hello,
what this indicate is that the thermostat is weak or bad which will need a replacement with a better one you can order for this from the below site, if you could not fine purchase it from your local technician around
pplmotorhomes.com
americanrvcompany.com
makariosrv.com
www.dotech21.com/ENG
The recommended fix is to replace the thermostat . You can generally find replacement parts at these websites:
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an thermostat is not a difficult repair and can be accomplished bythe average do-it-your self offer. If you decide to order the part and wishto repair this on your own
thank you and thanks for using fixya.
Posted on Jul 06, 2010
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
My rv fridge will lite but goes out as soon as the ignition cycle stops
You didn't state the Brand or Model of your refrigerator but it sounds like your flame sensor isn't working.
rv refrigerator won stay lit YouTube
Oct 14, 2014 | Heating & Cooling
Laars pool heater's burner wont stay lit
Check the burner, the holes may be plugged, especially at the beginning of the season. Same happens to the pilot light tube. Spiders love to make nests inside those small holes clogging everything up.
Aug 13, 2014 | Teledyne Laars Pool & Spa
Some burners don't work
this is a gas fireplace & everything is on low flame high flame it just won't stay lit
Jul 01, 2012 | Brinkmann Charmglow Stainless Steel LP...
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
My 30,000 btu Blue Flame gas wall heater wont stay lit, pilot light stays lit but the blue flame went out and had smell of gas I shut off the gas supply but, dont know what is the problem thanks, marty
you could have a overdraft problem causing your flame to go out. check your draft setting at the burner and make sure it's not open too wide. If it is, simply close it it slowly and make sure that the flame remains totally blue.
Nov 27, 2010 | Heating & Cooling
My furnace lights but only stays lit couple sec can hear a click then goes out
Sounds like it is not proving flame, to check you need a meter that will read DC microamps. without knowing the brand I can't say what you should be looking for. Trane furnaces need at least 1 DC microamp to prove presence of flame. Usually you will see 2 - 2.6 or so, but it depends on what the manufacturer specs to prove flame. At minimum you can pull the burners out and clean them really good (especially the cross-over wings) because if the flame doesn't roll down to the sensor fast enough during the trial for ignition it will recycle and eventually lockout. If it stays lit longer than 20 sec, it most likely is proving flame and cycling off on high limit because the blower is not coming on. The typical blower on delay is 45 sec from the time flame is proved to when the blower is energized
Nov 02, 2010 | Coleman Heating & Cooling
Igniter keeps going out on LP dryer
Look at the gas control box. Inside this box has a valve to open the gas so it can sustain the burner. This valve is control by the voltage of dryer sensor. This thermocouple is near the ignitor.. If this fails, there would be no voltage to open the valve. Here is how it looks like: 7f43321.jpg
Jan 08, 2010 | Amana ALG331RAW Gas Dryer
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
