Question about Linex International Linex X 615 Power Workout Tower
I need the sizes & quantity of the nuts & bolts
    Top Expert:
  • Linex Intern... Master
  • 35,762 Answers
Linex probably can tell you what ships with your tower.
Posted on Apr 16, 2014
What size socket do i need to fit axle nut on a 2007 dodge caliber?
I told you already 22mm. It was a guess, but it was right!!
http://www.oreillyauto.com/site/c/search/Spindle!s!Axle+Nut/01232/C0362.oap?year=2007&make=Dodge&model=Caliber&vi=1433273
Dodge Caliber 2007, Front Spindle Nut by Dorman®. Thread Size: M22-1.5. Packaging Quantity: 5. Packaging Type: Box. Dorman's Spindle Nut is manufactured for high corrosion resistance and a long service life. Depending on the...Direct replacement for a proper fit every timeHigh quality steel construction more details on -
https://www.carid.com/2007-dodge-caliber-driveline-axles/dorman-spindle-nut-31531756.html
axle nut on 2007 dodge caliber Google Search
Jan 22, 2017 | Dodge Caliber Cars & Trucks
What size screws and bolts are required for Jardine crib model DA832BC? I've misplaced them.
I suggest you measure the holes the screws have to go through. Where nuts and bolts are used the hole will be slightly bigger to give clearance and similarly where a hole is threaded for a bolt or setscrew, sometimes called a machine screw.
If the hole is 5.5mm or thereabouts the bolt will be a 5mm and if it is 6.5mm the bolt will be 6mm and so forth.
Common sizes of bolts for furniture and appliances are 4, 5, 6, 8 and 10mm and your local hardware store should be able to provide you with small quantities of those you need though there will be a limited number of different lengths available. It is usual practice to buy a little longer than you need and shorten them to suit by using a hacksaw and cleaning with a file or grinder or a dedicated shear.
There are three sorts of nuts in common use and although plain nuts are commonly used with plain and/or locking washers, anything that moves or if kids are around a stiff-nut such as a Nyloc nut should be used.
If the end of a bolt is exposed and might snag the clothes or flesh of a passerby it is customary to fit a domed nut to cover the sharp exposed end.
Self-tapping and wood screws are a different matter. If you need information about these then please come back and ask again.
Feb 04, 2015 | Baby Gear
My oil pan threads are stripped and it is leaking oil how do i fix it
Toughy;I take it some or all the bolts just turn clockwise pretty easily? Bunch or options-cheapest(no Gaurantee & to best)You can try some new bolts(better thread on them-Look at a couple bolts anywat-see if the meet is off the bolts-If the bolts are messed you mite get away with new ones and new gasket & or sealer-tou can clean holes real well-pack with JB-Weld the tap out & install new bolts(NOT recommened-POOR Odds)Drill & tap to next size-very skilled process,Drill & install nut zerks?put in new/probable same size bolts-PRO.....Machine shop would be 1st place I would recommend & they will probably recommend 1 or 2 of the above-Good Luck; John T
Oct 05, 2014 | Cars & Trucks
What is the bolt & nut size holding the rotor on the 2006 malibu ?
remove 2 phillips screw, unbolt caliper bracket w/ 17mm socket, use push bolt (12mm) to remove rotor if cannot be removed by hand
Nov 23, 2013 | 2006 Chevrolet Malibu
I need to know what size sockets I need to remove the lower nuts on struts I don't want to remiove wheel and not have the right size tools
You have to remove the wheel to work on any vehicle
You need to own a full set of metric wrenches & sockets,
before you start- not ask what size a bolt is- your going to
need as well as use every tool you buy over the rest of
your lifetime
Even if someone knew the answer you provided no vehicle
or what part or bolts your going to be working on
Buy some tools,good ones Snap-on or Mac Tools
& do the job with some tools worth owning & using
Feb 26, 2013 | Cars & Trucks
Nuts an bolts for little angles swinging crib
what is the size of the bolts? Pls provide the length of the bolt if available or else if bolt is not available, pls provide with the size of the hole and the length of the holes that the bolt has to pass through. This will determine the size of the Bolts and nuts.
Jan 17, 2013 | Little Angel Baby Care
Need bolt size for gas tank strap
You could take out one other bolt and visit the dealer or some Bolt & Nut store. They will match.
Oct 20, 2009 | 1995 Ford Contour
Looking for the correct size bolt for tranny mount.
Good work discovering the missing bolts. You didn't say if it's a manual or auto tranny,Check out the below site for a great diagram of the mounts and bolts, and the prices are good for OEM parts. Let me know if this doesn't help.
www.hondapartscheap.com/southbay/jsp/prddisplay.jsp?hidSwitch=&hidIrno=&catcgry1=CIVIC&catcgry2=1998&catcgry3=4DR+LX&catcgry4=KA5MT&catcgry5=MT++++++ENGINE+MOUNTS&vinsrch=no&ListAll=&prdrefno=&act=&count=0&quantity=0
Aug 10, 2009 | 1998 Honda Civic
I have a 1999 Durango that had an exhaust leak on cylinder 8. the manifold bolts were so badly corroded, I had to cut the heads off and unscrew the studs... except for #8 cylinder... the bolts were both...
It can be a daunting task. You'll need to center punch them as deeply as possible. Use left handed cobalt bits starting with the smallest possible bit & work your way up to about 3/4 the size of the bolt & try an easy out. Don't break the easy out!! If the easy out fails,continue drilling to the proper size for a heli-coil & install one. Use anti-sieze on the new bolts. If this fails,hate to say it,remove the head & try a drill press.
Jul 13, 2009 | 1999 Dodge Durango
Linex International Linex X 615 Power Workout Tower Logo
65 people viewed this question
Top Linex International Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Linex International Exercise and Fitnes Expert? Answer questions, earn points and help others
