Question about Wenger Swiss Military Alpine Diver Stainless Steel Water Resistant Swiss Military Alpine Diver Wenger Alpine Diver Black Dial w/ Stainless Steel Bracelet 70996 Watch for Men
Need correct replacement battery
Please let me know which would be the best longest lasting battery for my watch
    Problem Solver:
  • 19 Answers
The watch movement deters which battery the watch needs it is very important you do not put a battery in that doesn't suit the watch as it can short out the circuit however you can get the correct size in a gold seal quality which should not leak, also the older the watch, the more demanding the watch becomes on the battery as the movement components start to experience wear and tear
Posted on May 10, 2014
Cote D' azur watch
If you are unsure about what to do or how to do it, many jewelers will replace you watch battery for a reasonable price.
Nov 20, 2013 | Watches
Prc 200 needing battery replaced every week!!! i
Your watch is draining the charge on the battery. It is possible that you have a bad coil or circuit block that is causing the battery to die. An acceptable battery should last you at least 9 months to a year. You need to send your watch in to the manufacturer to have them fix the motor.
Oct 05, 2013 | Tissot Watches
I don't know what size battery to buy to replace the one in my Ann Kelin watch, it says Y121E
mcdevito75 Here, Your Ann Klien watch may take a 364 or 371 battery, Best Bet is to look for a small watch repair shop in your area, the $15.00 cost is worth it as you would have to remove the back of the watch then un screw the hold for the battery, your time and effort really isn"t worth it, plus the new battery will last a year maybe even longer.
Feb 09, 2011 | Watches
I have a geneve quartz 14k gold mans watch dont no how to take apart to put battery in.
mcdevito75 here, Battery usually lasts 1 year and longer, even if you did change the battery yourself now, you"d forget for a year or even longer next time battery needeed to be changed, I know I did. Add to this you can easily destroy your watch with in-correct handleing. BEST BET, look for a small watch repair shop in your area for this battery change $10--$15.00 and peace of mind.
Oct 26, 2010 | Geneve 14K Gold Ladies Diamond Panther...
The back of my watch has never snaped cclose all the way allowing moisture in, I am also having problems with my battery life. my battery only lasts a few vweeks what could be causeing this and how can i...
Thank you for contacting FixYa.
First of all, unless it is stamped or it is in the manual, I cant tell you what size battery, nor can a watchmaker unless they take measurements of the watch area.
You have a nice watch. My BEST advice is to take to an authorized Geneve watch dealer or to send direct to them (contact them first).
http://www.raymond-weil.com/EN/Swiss-Watch-Company/After-Sale-Service.html
Best regards. Jewel
Sep 21, 2010 | Geneve 14k Gold Watch with Diamond Bezel...
I need to replace the battery in my parsifal watch. The battery was replaced last year so maybe there is something wrong with the watch? What type of battery does this watch require as I'd like to...
Let me be honest with you. Dont. If you dont know what your are doing to change a battery, you will do more harm then good. And once that happens, you will lose your RW warranty.
My best solution is to take to a certified local RW dealer and if you dont know who is in your area, check this link:
http://www.raymond-weil.com/EN/RW-Geneva/Contact-Us.html
Best regards
Aug 17, 2010 | Raymond Weil Watches
The second hand jumps forward every 5 seconds but the watch still keeps time OK.
You need to replace battery.
Q/A from swiss army website.
Q. How do I know when the battery needs changing?
A. In select models, the battery end-of-life indicator signals that the battery should be replaced within two or three days. When the battery is low, the second hand stands still for 2-4 seconds, and then speeds up to the correct time. This indication will last for approximately one week, and then the timepiece hands stand still.
Jul 02, 2010 | Swiss Army Wenger Victorinox Swiss Army...
I need a replacement battery for an original navy seal model (3000)? Does anyone know what type and size is in these watches? Other than sending it to luminox has anyone successfully found a replacement?...
If anyone opted out to replace battery2_bing.gif in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries2_bing.gif, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help. In your particular case I do not see the reason why you should find the battery, because any decent watchmaker has many different batteries in stock. All you have to do is to find your closest watch repair shop and ask watchmaker to replace the battery. No need at all to send it to Luminox, as this job can be done at any watch workshop with the same precision and quality. In addition you will save money for shipping and pay less for battery itself.
Rate me, plz.
Jan 29, 2010 | Navy Seal Luminox Dive Watch
Need to replace the watch battery.
All battery driven watches are sensitive, not just the Chase-Durer.
Even the cheap ones, as the movement can be damaged or destroyed by the static electricity (touch of the bare finger).
Extra care is not needed to replace your watch battery, just you have to follow some simple, but very basic rules.
If you are ready to do it yourself- let me know and I'll guide you throgh all the steps (by asking me questions on this site).
Ifyou are not, then I'll let you know the best place to do that at nearest shop possible.
Jan 23, 2009 | Chase-Durer Blackhawk Mach 3 Alarm...
Wristwatch
The phrase, "Fabrique en Chine", is French for, "Fabricated (made) in China".
Your watch, like many of the low cost watches that are sold all over the world is made in China. They have many hundreds of these watch factories turning these products out by the millions, and badging them with all kinds of names on them.
Enjoy the watch while it keeps time. When it breaks, it's time for a new one.
I go through low cost watches like crazy. The longest I can have an average watch before busting it is about 3 to 6 months. I found the best make for keeping time and lasting the longest was the Timex. I sometimes manage to get more than a year out of this make. Either I am slowing down, or their watches are very strong!
Jerry G.
May 13, 2008 | Watches
Wenger Swiss Military Alpine Diver Stainless Steel Water Resistant Swiss Military Alpine Diver Wenger Alpine Diver Black Dial w/ Stainless Steel Bracelet 70996 Watch for Men Logo
345 people viewed this question
Top Wenger Watches Experts
Ansel Alberto
Ansel Alberto
Terry
Terry
Are you a Wenger Watch Expert? Answer questions, earn points and help others
