Question about Directv R10 TV Receivers and DVRs
DVR-R10 stops recording with 10-15 mins left
DVR-R10 randomly stops recording with 10-15 mins. left in the show. I have only noticed the problem at night. There are no power issues or signal loss. No conflicting recordings. DVR continues working normally just stops recording early.
    New Friend:
  • 113 Answers
If it's your cable box DVR, you need to call your cable provider to reset your cable box.
Posted on Apr 16, 2014
  • 27 Answers
SOURCE: Reciever Not Recording
Turn off the receiver, unplug the receiver, wait 30 seconds, plug it back in, and go through the setup again. This hard restart clears the memory and restarts the DVR software(clears any software glitches) This should fix this problem assuming that your satellite signal is good. Check that during the resetup. Most transponders will show between 70 to 100 signal strength. (Minimum is 70 for error free reception) Several transponders will show 0 as they are dead on the satellite, and not a receiver problem) If your satellite signal is in the 70's or less, you either live in Maine or you may need to realign the dish or something is blocking the signal like a tree or bush growing that is partially blocking the signal causing the signal to drop out(partial recordings)
Posted on Mar 09, 2007
  • 86 Answers
SOURCE: Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Posted on Jan 22, 2008
  • 5 Answers
SOURCE: Direct TV DVR Recording Problem
call tech support & ask them to hit your box to reset it, in the meanwhile unplug it for 15 seconds
Posted on Apr 25, 2008
  • 51 Answers
SOURCE: DVR recording problems
i am not terribly familiar with these systems but there are probably two sattelite in ports on the back of the receiver, one is a line for watching one program or recording, the other strictly for recording, one of these inputs is probably no longer receiving signal
Posted on Aug 07, 2008
  • 86 Answers
SOURCE: My Directv DVR receiver will not stay on it is blinking yellow??
Unplug it from the power for about 30 minutes and then try again. If it still doesn't work I would call DirecTV and discuss getting it replaced.
Posted on Mar 19, 2009
My box randomly turns off and flashes 8888.
same problem here. stb turns off randomly and displays 8888 and locks itself. usually if your press the select button 4 times and turn the stb on again it works but you will have to wait 20 min for it to get the channels or dvr. still no permanent solution though
Aug 30, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
DVR-625 deleted almost all timers, stopped recording shows
Unfortunately the hard drive is failing and you will need a new one.
Thanks for using Fix Ya.
Jan 16, 2010 | DISH Network DVR-625 DTV Receiver /...
Doesn't stop recording
Make sure there is no time overlap on any of the programs you have on the recorder.
That is the most likely problem
Aug 19, 2009 | DISH Network DVR-625 DTV Receiver /...
Our Dvr will only record on the channel we are watching. I cannot watch one show and record another? It says I have to be watching the channel I want to record?
for the dual tuner, if you are unsure what this is... please look at the back of the satellite box and see if you have 2 sat in cables. if you do, then you need to reprogram your satellite. if you do not have 2 sat in cables then you would need to contact dtv to get this installed.
Mar 29, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Can't watch anyother shows while recording another
Check the back of the DVR to make sure BOTH cables from the dish are properly connected to the receiver. Make sure they are properly tightened. It sounds like one of them has come loose, because if the receiver only has one working cable coming in from the dish it can only do one thing at once- you can only record one show at a time with one cable. You can also go into the receiver's setup menu and run a system test, which will help you diagnose the issue.
Feb 08, 2009 | Directv (R10) DTV Receiver / 70-Hours...
How do I know if my Directv HR22-100 HD receiver is dead?
one last thing you can do, if it doesnt work the dvr is dead. reset the dvr and wait for the hello screen and then the screen will go black. when it turns black, hold the down arrow (on the front of the dvr) and the record button for at least 5 secs. this will re-format the hard drive. if it doesnt work the dvr is dead
Jan 02, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Apr 22, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Pioneer DVR 640 H
You may have CDs stored in the Jukebox taking up space- if so delete them.
You may have images stored in the photoviewer - again, delete...
Have you done any disc backups, and forgot to delete the backup file? Goto bottom of copy menu for disc backup, then in the disc backup menu, choose delete backup file.
Jan 04, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
How to read dvr messages
From the R10 user's manual:
From time to time DIRECTV may send you messages about updates to your service and other important notices. These messages are important, useful, and easy to find. When your DIRECTV® DVR receives a new message, a message icon ( ) appears on the channel banner and in DIRECTV Central.
To read a message:
1. From DIRECTV Central, select Messages & Setup.
2. Select Messages.
3. Select the message you want to read.
Use the CHAN DOWN button to see text that does not fit on the screen. When you are finished reading a message, select Done or Delete Message. Selecting the message icon in the channel banner will take you to your list of messages. The message list will display “No Messages” if there are no messages to read.
You can download the full user manual for your R10 here.
Oct 19, 2007 | Directv R10 TV Receivers and DVRs
Directv R10 TV Receivers and DVRs Logo
137 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
