Question about Epson Perfection V500 Flatbed Scanner
1. grinding during scanning...more
This scanner has done 1000's of slides and negative strips. It now (occasionally) grinds and stops...also randomally scans at a very low size 44kb. Fixable or is it time to buy another?
SOURCE: scan colour slides
Hunted in the back of the wardrobe and found the original software. Val
Posted on Oct 15, 2008
SOURCE: Epson 4490 There is a Grinding sound when I scan
Check the lock position underneath your lid-located in lower right corner. The lock on the transperancy unit tranportation needs to be unlocked (moved to the right).
Posted on Dec 08, 2008
mohanchennai
  • 490 Answers
SOURCE: Lines through negative scans
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Posted on Dec 16, 2008
buffalonyman
  • 1865 Answers
SOURCE: Grinding Noise in my scanner
Try cleaning the guide bar that the scanning head rides on, apply a thin film of lithium grease on the guide bar
Posted on Apr 15, 2009
  • 526 Answers
SOURCE: grinding noise
The most common problem is that the pulley breaks, you might be able to see it through the glass. looks where the belt goes, and see if the pulley is broken.
also, some people forget to unlock the locking mechanism when the unit gets moved, the locking switch is on the side.
Posted on Dec 02, 2009
Will not recognize 5th image on negative strip because 4 and 5 overlap (slight double exposure). How do I scan 5th image?
I inserted my negative holder in backwards on my Nikon 5000 35 mm scanner. Then I could get the last (5th) slide scanned. But I can not get the scanner to work on my new IMac because of no working driver. Silver Fast has no drivers for the Nikon 5000
Jun 16, 2011 | Nikon Super Coolscan 5000 ED Film Scanner
Tip
HARMAN FL8385 CD CHANGER TRAY ALIGNMENT
We've all done it, or one of our youngsters do it for us... knock the multi disc tray out of sync with the drive gears.
With multi disc trays, the CD drive has to move out of the way during disc change and tray loading. Occasionally a disc jams, someone forces the tray movement, and you hear the GRIND, GRIND, GRIND of slipping gears.
Most designs have a switch-hit gear setup that's self correcting for small adjustments but occasionally the mechanism slips beyond self correcting.
Here's the process to open up and fix the tray alignment for Harman's FL8385 CD Changer.
http://www.keepandshare.com/doc/view.php?id=1660661&dn=y
3.7mb PDF.. (I'll try to shrink the filesize later)
on Jan 06, 2010 | Audio Players & Recorders
HP OfficeJet 6110 (4 years old) makes short grinding noises during printing. Occasionally the printer stops and asks to have the door opened and the jam cleared. The problem is gradually getting worse....
Try first to clean the encoder strip. It's the clear strip behind the printhead. Either use a Q-tip dampened slightly, or small towel. Don't apply too much pressure though, it can come off and they are hard to put back.
Jul 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Nov 28, 2008 | Epson Expression 1680 Professional Flatbed...
Sharp AL-1340 Scanner hangs up, grinding sound, with E-7 code
The scanner rails will dry out. Try a drop of oil on the rod the scanner travels on. There are two bushings that slide along the rod/rail. Good luck.
Nov 10, 2008 | Sharp AL-1000 Copier
Grinding noise
There is usually a slide type button somewhere around the outside of the scanner and it usually has a lock & unlock sybol on it. You may want to make sure that it is slid totally in the unlock position because it could be getting caught inside once in a while if the button is say half way between lock and unlock... Hope this helps...
Sep 24, 2008 | Panasonic KV-S2026C Pass-Through Scanner
COLORED SLIDES
do you have the optional film adapter? The optional Film Adapter (B81317) lets you scan negative film strips and slides
Jan 11, 2008 | Epson Expression 10000XL- Photo Scanner...
Scanner making grinding noise
Please open and apply oil on roller rod as some rust have accumulated on it prohibiting it move.
Jan 01, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Grinding
Could be front slides that act like a bearing to support front of drum or rollor bears in rear of drum.. wheels that supposrt drum in back
These pics may help some
http://www.pcappliancerepair.com/model-display.php
Nov 03, 2007 | Amana ALG643RB Gas Dryer
Distorted Scans
it could be your not scanner in a high enough resolution. I believe negatives have a 1000 dpi.
Oct 31, 2007 | Epson Perfection 4180 Photo Flatbed...
Epson Perfection V500 Flatbed Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
