Question about Bosch B36IT71SNS (20 cu ft) Bottom Freezer French Door Refrigerator
I can't find the serial number on my Bosch B26FT70SNS fridge and it needs repairs. I called Bosch and they said without the serial numbers no one will look at it. The fridge freezes all my food. Help..
abhishek33
  • 1239 Answers
SOURCE: the bottom of my fridge is frozen alonge with the fridge food
Hi sir
it bis thgermostat problem,(heating element),,,so the heating is not done properly by thermostat,,so u should check iot,,,
thank u,,,please rate it,.,,,
Posted on Jun 30, 2009
rablack66
  • 48 Answers
SOURCE: fridge too cold
most likely related to thermostat.
Posted on Nov 13, 2009
Toad tool
  • 33 Answers
SOURCE: bosch fridge keeps freezing all food
put some beers in there
Posted on Dec 15, 2009
SOURCE: I have lost my instuctions for this Bosch
Problem solved went to Currys and looked at the instruction book in there!!!!!!!
Posted on Jan 11, 2010
candgbabu
  • 53 Answers
SOURCE: Find the serial number on a bosch fridge
check the back bottom side or bottom front panel.
Posted on Mar 29, 2011
Condensation on the fridge
The veggie draw should be able to control the moisture with the sliding lever on it.
Do you leave your food uncovered while it gets to room temperature? if not that may be your problem sealing it before it does.
Oct 26, 2015 | Bosch B26FT70SNS VitaFresh Refrigerator...
Why doesn't the water inlet valve shut off completely?
http://www.repairclinic.com/PartDetail/b129p3/Bosch-Freezer-Water-Inlet-Valve/00649626/2000566?modelNumber=B26FT70SNS%2f04&ss=a3b129d1144601&mr=1
Sep 15, 2015 | Bosch B26FT70SNS
Where is the serial number found on a 1999 cabrio distributor?
There was only one distributor number used by VW for all 1999 Cabrios (US market), all references below are for US models only. (for Canadian market there were some different ones). The VW part number is 037 905 205 T, these were made by Bosch. Bosch did possibly supply a some different numbers to VW (Bosch number 0 235 520 066 replaced by 0 235 520 065) but both had the same VW part number and used the same repair parts. There is no serial number for the distributors, just part numbers. The original distributor will have the VW number as well as one of the Bosch part numbers stamped into the body of the distributor. The distributors rarely had to be replaced, as most parts to repair them are available. The ignition hall unit (sensor) is replaceable in the 037 905 205 T distributor. I am a independent parts distributor for VW and Audi vehicles and also a Bosch warehouse distributor. I have the hall unit in stock for this distributor, mail order price is $121.70 + shipping (and + sales tax if shipped within Alabama). I can also install the hall unit in your distributor (if needed) if you send me your original distributor. To replace the hall unit the distributor has to be disassembled and if done improperly the distributor can be made unusable. Call me or Email me if you need more information. 1888VWPARTS vwparts@bellsouth.net
Nov 27, 2012 | 1999 Volkswagen Cabrio
My new Bosch B26FT70SNS fridege which i got delivery yesterday morning compressor motor won't turn off. Since yesterday afternoon around 5pm until now 11am. More than 18 hours continue running, the...
HI JAMES.ummmm new bosh...should work.if not and motor running cont.then it sound to me like is out of refrigerant or motor faulty.check condenser unit.should hot.if cold call under warranty or replacement i would say.good luck Ali
Jun 30, 2012 | Refrigerators
Rust spots appearing on the front doors of my Bosch refrigerator
Stainless steel does rust - or at least that is the theory.
There is in fact two types of stainless steel; the original categorised austenitic which is instantly recognised due to it being unable to attract a magnet due to the absence of iron. Austenitic is relatively expensive and difficult to work but adding iron in various quantities to the alloy produces a cheaper, lighter metal that looks good and is easier to work while still providing some resistance to corrosion. The more iron that is added to the ferritic type of stainless, the lighter, cheaper and easier it is to work but the corrosion resistance is substantially reduced.
Cars have been fitted with stainless steel exhaust systems of the ferritic type for many years and although they last a long time they soon show surface rust and sometimes will rust through.
I expect your fridge wipes are either acid or alkaline that are suitable only for austenitic and good grades of ferritic and Bosch have used a particularly poor grade of stainless. I expect fridge magnets stick very well...
Mild discolouration could be removed with a mild abrasive cleaner though that would tend to ruin the brushed finish. Clearly future cleaning should be carried out with a neutral ph cleaner and the surface protected with a hard wax polish.
I suggest you check the cleaning instructions in the Bosch instruction book. If you feel you have done nothing wrong you might be able to claim from your household insurer as accidental damage. It would be a good idea to inform the manufacturer of the cleaning wipes...
May 27, 2017 | Bosch B26FT70SNS
Mar 29, 2011 | Bosch Refrigerators
I need a new door seal
Im afraid without the model number, which is located inside or outside on the back of your refrigerator, unless the model number tag/sticker/plate was removed or is not readable, finding the correct part would be extremely difficult.
Jun 28, 2010 | Bosch KUL1444 Compact Refrigerator
Will not cool. Electric is on and there is a strong amonia smell.
TURN THE FRIDGE OFF AND DO NOT USE!!!! Your cooling unit is leaking!!!! You will need to replace either the cooling unit or the entire fridge. There is usually about a 400 dollar difference in the two. Check your model number and serial number of the fridge and call your local dometic dealer to see if it is under recall. You may be able to have it repaired for free. If you provide me with the model, serial number and serial number of the cooling unit (located in the rear through the door on the tank assembly), I can provide you with this information.
Again, TURN THE FRIDGE OFF and DO NOT USE!!!!!
Let me know what happens,
Jeff
Jul 03, 2009 | Dometic Refrigerators
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Bosch B36IT71SNS (20 cu ft) Bottom Freezer French Door Refrigerator Logo
253 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
