Question about KitchenAid Architect Series II KSSC48QTS 48" Built-In Side-By-Side Refrigerator with In-Door-Ice Dis...
How to remove water dispenser pad from kitchenaid KSSC48QTS refrigerator
Am trying to fix the Water Dispenser Pad as I have to press the pad real hard to dispense the water, but don't know how to remove the cover or get the Water Pad out to see why its not working like it used to. Someone said it has a thin strip on the back of the pad that needs to be reapplied to make the connection.
fridgetech
  • 473 Answers
SOURCE: KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve.  The water valve is on the back of the fridge at the bottom.  You will see the water line going into it.
Posted on Oct 12, 2007
fridgetech
  • 473 Answers
SOURCE: the Water dispenser is leaking water
It's either a bad water valve or the switch in the dispenser is stuck.
Posted on Oct 20, 2007
SOURCE: No water dispensing to the icemaker. Water does dispense through the door dispenser. KitchenAid ksbs25fkbl00
Unplug your refrigerator and leave the freezer door open for 2 hours (The food in the freezer will only partially thaw).
The line supplying the water to the ice maker has frozen...this will un-thaw it.
Posted on Jul 01, 2008
SOURCE: Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
Posted on Aug 02, 2008
SOURCE: KitchenAid KSBP25FKSS Side by Side Refrigerator Ice & water dispenser ondoor not working
I had the same problem and had to have the entire door replaced. I thought it was a random thing since sometimes it would just start working again, but finally it just stopped for good. The wires that
are below the door on the left hand side (you can see them better when the lower front piece is removed) were severed and they can't be put back together without replacing the door. My repair guy (the refrig. was still under warranty) told me it was a design or installation defect and that he has seen it time and again. Evidently, when they install the wiring, they don't leave enough room to stuff the wires out of the way of the closing door and eventually, it severs them over time.
Posted on Feb 02, 2009
Water dispenser leaks
Refrigerator Water Dispenser Leaks?
Refrigerator Water Dispenser Leaks show that the refrigerator's water system has a problem. To fix this problem, open the filter compartment and pull out the filter and push it back in so that it is secure in place. Push compartment cover until it clicks.
try to check this video.
May 13, 2014 | KitchenAid Superba Architect KSCS25INSS...
Dispenser pad not engaging
Hi; is the refer. still under warranty. Ask the people You ordered the part from. Also sounds like the touch pad has been pushed too hard or to many times over the years and might need to be replaced...alpharome416
Feb 26, 2010 | LG LRSPC2031 Side by Side Refrigerator
No ice comes out when pad is depressed.
does your auger turn? thats what pushes the ice doun the shoot. if not replace the auger
Oct 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid refrigerator water dispenser not working
you may need to replace the water inlet valve. it is a dual valve, one side for water and one side for ice. part #2304833. see the attached breakdown #10. perhaps this will help.
Oct 26, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Water will not flow out of dispenser
This is common when the water filter needs to be replaced. GE recommends:
Water filter clogged. Replace filter cartridge or remove filter and install plug. Air may be trapped in the line: Press the dispenser arm for at least two minutes.
Dispenser is LOCKED. Press and hold the LOCK CONTROL pad for 3 seconds.
The water line may be turned off or disconnected.
Sep 07, 2009 | GE Refrigerators
Replace water dispenser pad
1st (DISCONNECT THE POWER)then pull the tray at the botom.you will find 3 torx screws .then just push up on the frame and remove the ribbon conector.then 4 screws and pull and your there.
Jul 23, 2009 | Refrigerators
Maytag lock and filter change
to reset the change filter light:
Press hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 sec.)
Dispenser lock:
to interrupt power to the water and ice dispenser so it cannot be used , press the lock pad 3 times within 10 seconds.
Jan 21, 2008 | Maytag MSD2454G Side by Side Refrigerator
No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
Nov 12, 2006 | Amana ARS9265B Side by Side Refrigerator
KitchenAid Architect Series II KSSC48QTS 48" Built-In Side-By-Side Refrigerator with In-Door-Ice Dis... Logo
63 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
