Question about Mongoose Exile 26 Men's Full-Suspension Mountain Bike
On my Mongoose i tred to fix a rear flat and when
On my Mongoose (26") i tred to fix the rear (flat tire)and when i finished it worked for less than 100ft and i need help fixing the rear correctly
    Scholar:
  • 119 Answers
1. You need to make sure the tube doesnt have more than one piercings [inflate the tube and, using a bucket of clear water, immerse it and observe any air outlets. if you have a pen or marker, mark them] 2. Make sure the valve of the tube really is tight enough. If it isnt, use a valve spanner to tighten it, but make sure you dont do it too hard, or else it will snap.
3. You'll need to check the tyre for any sharp objects that could have got stuck in it and are causing new punctures 4. You need to make sure that both the tube and patch are course enough to be glued to each other when you apply the contact adhesive to them. 5. When you apply the adhesive, depending on the brand, you wont need to 'immediately stick the two surfaces together, let a bit of fresh air dry them a bit, [this would imply waiting for minute or 2] then patch things up
Posted on Jun 18, 2009
How to change back innertube on 26" mongoose estes bike
First turn the adjuster on the rear brake handle all the way in and make sure the slots on the adjuster and set nut are lined up, pull the brake cable out and leave it attached to the lever to open the rear brake pads, loosen the bolts on the tire and pull the derailer up to remove the tire, remove the dustcap from tube and using a flat tool (Wal-Mart has tire tools for $1) take one side of the tire bead out of the rim, pull the old tube out, place the stem of the new tube in the hole and put the cap on, tuck the new tube in the tire trying to keep it flat as possible, push the bead of the tire back into the rim. before inflating the tire, put it back on the frame while pulling the derailer up to get the chain back on the cogs( they will adjust later) tighten the bolts and inflate the tire to desired pressure (between 35-60 psi)
Jul 05, 2014 | Mongoose Cycling
Rear tire for Mongoose D40r
Rear tires can be found on amazon for various prices, take a look: Amazon com Mongoose rear tire. I hope this was helpful. Cheers
Feb 16, 2014 | Mongoose Sycamore Women's Comfort Bicycle
My 06 nissan frontier with flat tire light on even all tire are 35psi or more .
Step 1:
You could have a bad tpms sensor in one of the tires here's how to check it
Step 2:
Reading TPMS codes and clearing them
There is a simple procedure to perform a self diagnostic and clear the codes.
1) Turn IGN switch to ON.
2) Locate the TPMS warning check connector. It is a single loose wire with a connector located under the dash next to the steering column. It may be bundled with the OBDII diagnostic connector.
3) Using a suitable piece of bare wire inserted into the connector (a paperclip will do), momentarily ground the wire to the chassis.
NOTE: If you are uncomfortable doing this, then don't. You could damage your vehicle if the wrong wire is grounded.
Step 3:
4) The TPMS low tire pressure warning light will blink error codes as follows:
5sec. ON - 5sec. OFF
Long (1 sec) blink = First digit (2 blinks = 2)
Short (0.2 sec) blink = Second digit (ie 3 short blinks = 3)
There is a 2 second pause between multiple codes.The cycle will keep repeating starting with 5sec. ON
Codes:
15 - Front LH tire pressure drops to 26 psi or less.
16 - Front RH tire pressure drops to 26 psi or less.
17 - Rear RH tire pressure drops to 26 psi or less.
18 - Rear LH tire pressure drops to 26 psi or less.
21 - Data from front LH transmitter can not be receive.
22 - Data from front RH transmitter can not be receive.
23 - Data from Rear RH transmitter can not be receive.
24 - Data from Rear LH transmitter can not be receive.
31 - Checksum data from front LH transmitter is malfunctioning.
32 - Checksum data from front RH transmitter is malfunctioning.
33 - Checksum data from rear RH transmitter is malfunctioning.
34 - Checksum data from rear RH transmitter is malfunctioning.
5 short blinks - System is OK.
5) To clear the codes, turn the ignition OFF.
Feb 27, 2013 | 2006 Nissan Frontier
Trying to assemble mongoose back tire and chain
I am sorry I could not find a manual for your Mongoose.
I will suggest you go to the following website
http://www.youtube.com/watch?v=2j1gSwhsVN8
You can find numerous videos for your bike repair.
in Youtube
Bud
Sep 24, 2012 | Mongoose 26" Mens XR-75 Mountain Bike
I have a Mongoose Dual Suspension Mountain Bicycle 26 inch that I purchased approx. 2007 and I need the rear wheel axel and bearing assembly. Where would I be able to purchase these parts?
It's prabably easier to buy a whole new hub. And for ablout another $20 you get a whole new tire. You should do that. Have a bike shop do it because it can be tricky.
Jul 24, 2011 | Mongoose Domain Dual Suspension Mountain...
Bought a 26" Mongoose Detour
For the gear problem.Find the shifter.Use a pair of pliers and loosen the nut where the cable is passing through the shifter.Now withe the pliers pull the cable tight.Very tight.Spray the shifter with WD-40.That should fix it.
For the front rim,tighten all the spokes.Pliers will work,but a spoke too; will make the job faster.
May 16, 2011 | Mongoose Cycling
Just got my Mongoose 26" Vanish about a week ago.
Fix it. Flats are a fact of life. Learn to deal with them. carry a pump, a tube and a patch kit.
Google "fix flat tire bike" for how-to's. Always try to determine the cause of the flat prior to removing the tube or you may just get another one.
Feb 27, 2011 | Cycling
My bike got a wobbly tire basically right when i bought it
The cheapest way is to buy a new tube to see if that was the problem. Sometimes tubes can inflate bigger at one area than others. If not check to see if the rim is true, meaning that it is not bent, if so replace. It could also be the tire.
Feb 21, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Removal of sprocket and gears from rear tire for replacement
A special sprocket removal tool is required usually only $20 to $30 bucks at a decent bike shop.
Jan 29, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Mongoose Exile 26 Men's Full-Suspension Mountain Bike Logo
225 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
