Question about Triumph Academy Sports 400T Treadmill
Treadmill triumph 400t has error E1
Runs for about 15 seconds And e1 error code come up and machine stop.
    New Friend:
  • 3 Answers
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
Posted on Apr 16, 2014
Triumph 400T belt won't turn, and get E1 error message
You have to check the Speed sensor of the tread. IF the speed senor is faulty this problem can occur. Normally in all treadmills E1 denotes the speed sensor error.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Triumph Academy Sports 400T Treadmill
The wire on the back of the tridmil triumph 400t came off and it want light up and you can here that it's on but it is not running.
Triumph™ 400T Treadmill ' Academy
www.academy.com > ... > Cardio Equipment & Machines > Treadmills
Rating: 3.4 - ‎67 reviews - ‎$259.99 - ‎Out of stock
The Triumph™ 400T Treadmill features a 1.50 CHP motor and the AEROsoft™ cushioning system.Missing: motorcycles
Triumph 400T Treadmill - YouTube
? 0:31
https://www.youtube.com/watch?v=TZdf5fIAVMU
Jan 4, 2012 - Uploaded by Academy Sports + Outdoors
Visit Academy Sports + Outdoors or academy.com to view theTriumph 400T Treadmill which is featured at a ...Missing: wire ‎back
Triumph - 400T - TM397B - 2011 - FitnessRepairParts.com
Dec 26, 2015 | Triumph Motorcycles
My treadmill runs for 9 seconds and stops and shows E1
Might be the power supply. That's about all I can think of. It runs but gets hot very fast and shuts down
Nov 24, 2014 | Triumph Academy Sports 400T Treadmill
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
E1 code on treadmill
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Test it for open or faulty+ clean it, and tight vbery well the connector, see the diagram adjust it
Try to run the software calibration for troubleshooting and diagnostic too.
God bless you
Mar 22, 2013 | Triumph Academy Sports 400T Treadmill
Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jan 23, 2010 | Horizon Exercise & Fitness
Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Jun 07, 2009 | Exercise & Fitness
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Triumph Academy Sports 400T Treadmill Logo
1,539 people viewed this question
Top Triumph Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a Triumph Exercise and Fitnes Expert? Answer questions, earn points and help others
