Question about Ricoh Aficio SP C242SF - multifunction fax / copier / printer / scanner color
Ricoh Aficio SP C242DN fuser replacement - Ricoh Aficio SP C242SF - multifunction fax / copier / printer / scanner color
SOURCE: Have a Ricoh Aficio 3025
ERROR SC 548
Posted on Nov 07, 2008
  • 9 Answers
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Posted on Dec 16, 2008
  • 86 Answers
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
SOURCE: Replace Fuser error not clearing
Fuser PM reset
1. Hold the 'up' and 'down' arrows together for 5 seconds or longer.
2. Release the arrow keys and press the 'enter' key.
3. Select '2. Engine' - Then go to option '7.'
4. Go to SP7804-016 (PM Counter Reset>Fuser) and execute. Shows results=OK
5. Turn the machine off and on.
All done.
Posted on Mar 28, 2009
Ickoajnc
  • 183 Answers
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Posted on Jan 13, 2010
Fix sc 545 RICOH Aficio SP 4100N PCL
Do a fuser reset.
SP5810 in service mode. Reboot machine.
If that did not work, replace fuser.
May 29, 2015 | Ricoh Aficio SP 4100N Laser Printer
Sc 542 code
fuser fault code. replace parts on fuser assy thermostat try first will need to reset code after parts replaced could be heater lamp or last board problem
Aug 13, 2014 | Ricoh Aficio SP C242DN Laser Printer
Procedure 5810 error sc542
Dirty thermistor in fuser unit. Clean it and reset by entering SP Mode and then turning it off.
Reset error SC542
Because this is a fusing error and the fuser lamps use AC voltage, this repair is best left to a certified Ricoh tech.
Wouldn't want to start a fire.
How to change feed roller on RICOH Aficio SP C242DN ?
1. remove all the cartridges.
2. remove the waste toner bottle.
3. rear cover
4. left cover
5. paper feed clutch
6. close the top cover and front door.
7. pull out the tray.
8. stand machine with the rear side facing the table.
9. slide the paper feed shaft to the left side.
10. remove the paper feed roller.
Jul 09, 2014 | Ricoh Corp Aficio SP C231N Laser Printer
How to change feed roller on RICOH Aficio SP C231N
You would need a technician to help out with the stuff.
Ricoh aficio SP c231n prints ghosts images
sounds like fuser is bad with wrinkling also or two different problems drum assy blade fail and fuser assy failed
Jan 02, 2013 | Ricoh Corp Aficio SP C231N Laser Printer
Ricoh Aficio SP C242SF - multifunction  fax / copier / printer / scanner   color Logo
375 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
