Question about Pioneer Car Audio & Video
Bluetooth connection pioneer deh-6600bt
Just got my pioneer deck. Setting up Bluetooth is easy, getting my music to play is another. For a long time I couldn't get it to even play any sound from my phone, then it would play the music but no details (track name, artist, etc). Jumped in my car the next day and it connects perfectly with all the information without me having to press a single button. But now it won't do that. Am I doing something wrong or does it not like to work well with the galaxy s3?
SOURCE: bluetooth phonebook transfer
you will find your answer here on pg. 33, Alan
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287543DEHP790BTOperationManual0328
Posted on Mar 01, 2008
  • 15 Answers
SOURCE: Changed car battery and now Pioneer DEH-P7700MP doesn't work
check behind radio for inline fuses . useually on red and yellow wire's . most likly blew one . or fried radio all together . most likely just fuse , thats why they are there
Posted on May 25, 2009
  • 87 Answers
SOURCE: wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Posted on Jun 02, 2009
SOURCE: Pioneer Bluetooth
The Code to activate it is 83423
Posted on Jul 19, 2009
SOURCE: i bought a used pioneer deh-p7900bt, i cant use
As an owner of the 7900 i'm assuming your talking about Error-80
If this is the one, turn the ignition on, using a pencil or similar item press the button just to the left of the eject button. this will completely reset the internal flash memory. Once it turns back on hold the dial in until you get into a setup screen. rotate the dial counterclockwise to "BT Memory"
press the dial to the right and it should come up with "reset?" now press the dial. 99% of the time it will say error but it still completes. Now turn the stereo back on and press the phone button. pair your phone to the stereo and viola you're all set.
Posted on Aug 09, 2010
I have purchased 2 of these speakers. I want to Bluetooth connect them to my iphone. How do I do this and get music from both speakers?? Thx
If you have purchased Speakers with Bluetooth Connectivity capability you can do this by switching on the speakers and on your iphone use the Bluetooth Pairing Option from Bluetooth settings to establish connectivity and play music to hear from speakers
Jun 15, 2015 | Audio Players & Recorders
Why is bluetooth not available anymore
Is bluetooth on at your phone? Pair your phone again with unit, refer manual page 11.
Jul 29, 2014 | Pioneer Car Audio & Video
Why pioneer deh-x6500bt wont turn on now?
Axle and Music system are interdependent of each other.
Check fuses and wiring of music system.
Jun 18, 2014 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
Pioneer DEH-X6500BT amp & speaker problems
Depending on the car and your setup sounds like the amplifier is not wired properly or an issue with adjustments on your deck itself. More info on your sound setup would be helpful.
Dec 28, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
Pioneer Model: DEH-P8400BH
Press and hold the source button until the CD Receiver turns off. Press and hold the center of the volume knob top bring up the settings menu rotate the volume knob until Clear memory is displayed and then press the center of the volume knob Clear memory YES will be displayed, press the center of the volume knob to confirm. The display will change from Clearing to Cleared
Aug 07, 2012 | Pioneer Deh-p8400bh Cd/mp3/ Receiver W/...
How do u set clock on deh p3000 pioneer
This was copied from the Pioneer support site:
Clock adjustment is performed in the "Initial Settings" menu. Please follow the instructions below to access time setting.
Press & Hold [OFF]
Pres & Hold [Muti-Control] until "Clock Set" Appears
Turn [Muti-Control] to choose setting
Press [Muti-Control] to enter setting
Time Setting:
Press [Muti-Control] to select time setting mode
Press [Muti-Control] to select time segment. Each press will select one segment of clock
Turn [Muti-Control], or click up/down to adjust time segments
Available functions:
Clock Set, Warn Tone, AUX 1, AUX 2, SW Control, Ever Scroll, BT Audio*, Pin Code Input*, BT Ver Info*
*Available only when bluetooth adaptor is connected
Feb 24, 2010 | Pioneer DEH-P3000 CD Player
Just wondering if Pioneer DEH-P4000UB cd player
no it does not have built in bluetooth but you can get a optional bluetooth kit Pioneer CD-BTB200
Jan 02, 2010 | Pioneer DEH-P8500MP CD Player
Automute car kit for Sony Ericsson OEM HCB-300
I am having the exact same problem with my vauxhall corsa and my pioneer deh-6000ub its so annoying it works with the manufacture stereo soon as i connect my pioneer in it doesn't come alive (the HCB-400)
Mar 13, 2009 | Sony -Ericsson OEM HCB-300 Bluetooth...
Pioneer DEH-P9800BT with Nokia N95 8GB via Bluetooth
Sometimes the call is diverted to the phone, so the deck stops playing. Happens to me too
Jun 20, 2008 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Car Audio & Video Logo
53 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
