Question about Frigidaire GLTF2940ES Front Load Washer
The machine was sent to me and the manual is missing. the water continue to the drainer and i cannot wash. what will i do?
It is a Ugine machine heavy duty. and missing 2 buttons
    New Friend:
  • 75 Answers
If it still has a warranty send it back to the sender and either ask for your money back or a replacement
Posted on Apr 16, 2014
catriver
  • 878 Answers
SOURCE: 9 cycle heavy duty 2 speed washer machine
Buba, check the lid switch for proper operation, on a lot of models if the lid switch is bad, no spin, no drain. You said you had the pump checked out. Im assuming that it was removed to check for a sock or other garment lodged in the pump. Other things you can check would be the hose from the pump to the tub, make sure it's clear and the drain hose where it exits the washer. Hope this solves the issue..
Posted on Jun 11, 2006
geemarie
  • 876 Answers
SOURCE: belts slips off
Belt is too loose and probably needs to be replaced.
Posted on Aug 02, 2008
  • 1028 Answers
SOURCE: Please help...
when water is turned back on does it run in without turning machine on? if so fill valve is probably bad if overflowing and washer is cut off and water stops suspect water level control
Posted on Aug 12, 2008
jsrock516
  • 5911 Answers
SOURCE: machine fills and washes but will not drain or
Check your lid switch. If the washer fills, agitates, then stops at the rinse cycle and won't drain, or if the washer does an initial fill, then stops, this is a common symptom of a lid switch malfunction.
This is a very simple and inexpensive repair. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
If the lid switch is found to be defective, it can be purchased at any of the following websites2.gif:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you need assistance with identifying a part number please post back with your complete model number (located on a nameplate along the wash tub rim under the lid). The average price is $25 to $35. Prices vary between these sites, so shop around for the best deal.
I hope you find this information helpful.
NOTE: Frigidaire washers are commonly manufactured by Whirlpool, so these instructions should apply.
Posted on Oct 09, 2009
caroldon
  • 17130 Answers
SOURCE: frigdaire heavy duty washer 13 cycles 2 speed motor. Washer no longer detects the water level. if you have it on small just continues to fill with water and never stops.. Washer flooded gargage. An
This can be due to failure of the pressure sensor within the washer which should output to the processor to cut off the inlet valve when the set water level has reached.
You can test this out by blowing into the tubing and testing the continuity of the switch to confirm if the diaphragm is intact.
click this link: Replacing sensor
Posted on Jul 05, 2012
I have a ugine washing machine iam searching for customer care number of ugine
really hard to find what you want as we do not know where you are located in the world . try searching thru Google
Apr 10, 2016 | Washing Machines
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
I have a Whirlpool washing machine;model AWM5104.I wanted to know how you empty the drainer. I've heard that for some makes of machine,you turn it clockwise but mine doesn't budge!
exactly what do you mean by emptying the drainer?
If you are in the correct category of washing machines there is only a pump that pumps the water out into a drain pump or sink and the hose is higher than the tub edge
to fully drain the tub then simply place the drain hose at floor level or empty into a bucket or other low container.
make a new comment to clarify what it is that you want an answer for.
May 22, 2015 | Whirlpool Washing Machines
Ugine washing machine E11 errer
Hi Rana, I am happy to assist you!
Generally, error code E11 means that your washing machine is taking a long time to fill (or is continuing to fill).
Is the incoming water flow normal? If it is, does the fill water continue to enter your washer? If yes, disconnect power from your appliance. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
If you have checked all of the above, the unit may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Dec 08, 2013 | Frigidaire GLTF2940ES Front Load Washer
Front louding not running . Whirlpool
You need to get inside and clean out pump assembly
Jan 14, 2010 | Whirlpool Washing Machines
Water does not pump out of the tub during the drain cycle
is your washing machine is electronically or manually driven,
if it is electronically then have it chech by the technician
If it is manually then just open up the back of your washing machine and see if the cable stil attched or intact, well if it is , then you'll need to open up the drain pan tube, there might be a small object or dirt that preventing the water to come out, just clean it
Nov 01, 2009 | Washing Machines
Avanty w789SA
its the drainage problem .so either the drainer is getting blocked or the drainer is cracked and got faulty so needs to be replaced.
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Feb 26, 2009 | Avanti W789SA Top Load Washer
Condenser dryer gets hot but cloths not drying and water drainer
Check The Ducting To Make Sure There Is No Obstructions Inside. Find The Outlet Outside Where The Duct Goes And See If Your Getting A lot Of Air. In Some Cases You May Have To Remove The Back Of The Dryer To Remove The Biggest Lint Ball In The World.
This Huge Lint Ball Builds Up Over Time And Quickly For Users Who Do Not Clean The Lint Trap On Every Cycle.
All Of The Above Will Cause The Dryer To Not Be Able To Get Good Air Flow Thus Causing The Machine To Have To Much Back Pressure.
Feb 04, 2009 | Candy DQW150 Front Load Washer / Dryer
Frigidaire GLTF2940ES Front Load Washer Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
