Question about Zenith Televison & Video
Im unable to reprogram the channels on zenith tvs
I have been trying to reprogram the channel set up on zenith tvs, i have the off brand installers remote ( Anderic RMC 12352 ). i know the remote works cause i programmed other zenith tvs ( different model?) but the H27D35DT, H27C35DT and H27E35DT the remote doesnt give me the menu option
    Top Expert:
  • Zenith Master
  • 35,601 Answers
Maybe Zenith changed the codes.
Posted on Apr 16, 2014
Does the Zenith A27B33W need a digital converter to get broadcast television? (not cable TV)
Turn on your Zenith TV and try selecting channels. If you see channels such as 10.1, 52.2, etc. displayed, they are digital. If you do not see digital channels displayed, you will need to purchase and install an A/D converter (set top box).
Feb 23, 2015 | Zenith A27B33W 27" TV
Sony trinitron kv32-s15 remote willnot change channels, but, will change on/off and volume.Also, manula channel up/down willnot work
Try to change channels by manually entering the numbers on your remote. If this works then you need to reprogram your channels.
Aug 21, 2010 | Zenith ZN110 Remote Control
Remote not working properly
Have you tried putting new batteries? Do that first if it still doesn't work. I would get a universal remote.
Jan 22, 2009 | Insignia Digital-to-Analog Converter for...
Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
May 26, 2008 | Zenith SC652 Remote Control
Zenith h32h38dt 32
The "H" model Zenith TVs are hotel/motel sets designed that
a roomer cannot access the menu feature. Your best bet would
be to purchase a name brand universal remote which has the
menu button feature or order an original Zenith master remote
which would not require programming. Once you have a workable
remote which will allow you to access the on-screen menus you
should be able to program the channels.
Hope this helps,
CaseyBee
Feb 27, 2008 | Televison & Video
TV channels
If cable is hooked through cable box with a coaxial cable, then turn tv to ch 3 or ch 4 as appropriate.
If cable is hooked through any other type of cord (red/green/blue or red/white/yellow) use the AV+ or Source button to change your source to Av1, AV2, HDMI, or however you have the cable box hooked to TV (I am assuming your TV is a Philips).
Feb 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Zenith Television
Some of the older sets were just that way. It is best to have the cable plugged into the tuner before you plug the set back up. It should automatically find all available channels upon being plugged in and turned on... will help to know the model of the set.
Feb 24, 2008 | Televison & Video
Programminng Channels
try hitting channel 00 , on older zeniths that will take you to input mode. hope this helps
Sep 15, 2007 | Zenith C27A24T 27" TV
Concierge series 25" wont stay on channel 3
If Im not mistaking , some of Zeniths TV sets cannot be unplugged or disconnected from the wall. It will delete the memory and I guess the default channel is Channel 52.. I didnt know you disconnect the set in the ? you asked before. To stop this simply plug the set into an always on wall receptical and turn on the cable then the TV set. your going to need to do this order of operations as I know Zeniths will detune and you wont get any color sometimes if you turn on the TV then the cable. Sorry nothing you can do short of getting another set. Good Luck
Jul 30, 2006 | Zenith C27A24T 27" TV
Televison & Video Logo
64 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
