Question about John Deere Garden
Getting hot why would you remove the wire to the bottom of my carb on my scotts 1642
    Guru:
  • 145 Answers
YOU SHOULD NOT! look up anti diesel valve, this electric soleniod provides a path for fuel to the engine.
Posted on Apr 16, 2014
How do I clean the carborator?
Remove carb from mower. Use carb cleaner and small acid brush to clean outside of carb. Remove bowl from bottom of carb. Clean bowl. Observe bolt that held carb bowl to carb, see if it has a hole or holes thru it. Clean out holes with bread wrapper wire with about 1in of wire. Test float, float down fuel flow, float up fuel stops. Use bread wrapper to clean center port of carb from bottom up thru carb body. Remove float pin float and meter needle, use bread wrapper to clean meter needle passage up thru carb body. Re-assemble carb.
Honda carbs can be purchased new for $14 - $27.
Aug 14, 2013 | Garden
On a 1996 chevy caprice obd code 1642 where are the f/p circuit control 2 and 3
Code 1642 is for a problem with the cooling fan relay.
It could be the relay, or the fan motor, or the wiring.
Feb 14, 2013 | 1996 Chevrolet Caprice
Chain lube
WIILL HAVE AIR PIPES ON CARBS SO NEED TO REMOVE ONE THINK CONCEPT TO OTHER AIR PIPES AND PUT YOURS NEW ONE ON RUN IT TO SCOTT OILER FULL IT UP CHECK IT
May 26, 2010 | 2005 Hyosung GT 650 R
Scotts 1642 riding mower take foot off brake engine shuts off
Sounds like the safety switch in the seat is bad or disconnected. Look under seat to see if anything is unplugged.
Nov 05, 2009 | Briggs & Stratton Garden
I need a diagram of the drive belt on a Scotts 1642 garden tractor. I have an oners manual but it is not in there
I believe this is one of the Scotts mowers made by John Deere. Deere has a parts website that you can access. You enter the model number of your mower, and it then lists the various sections of the mower. It shows diagrams of all the various parts. The drive belt would be shown in one of these diagrams. You can probably figure out the configuration by looking at these illustrations.
A second possibility is to check out www.mytractorforum.com. Join up (it's free), and ask your question. Someone on there has probably done this belt replacement and can either guide you through it or send you a diagram.
Oct 14, 2009 | Garden
Electrical problem with my 1999 Scotts Riding Lawnmower
If the motor is trying to start but won't try removing the engine shroud and cleaning the magnets on the fly wheel and the two little prongs close to the fly wheel. They might just be rusted and not getting a good electric pulse to the spark plug. Also clean the spark plug wire end that goes on the plug. I use fine sand paper or emery cloth. Your choice.
Good luck and let me know if this works.
thanks
roundo4
Sep 02, 2009 | Garden
Getting to the cmos battery
If it's like the Acer that I have,It should be located eather under the memory chips,or the wireless card on the bottom of the laptop.
Aug 28, 2009 | Acer Aspire 1642WLMi Notebook
Primer bulb does not fill or prime when pushed.
the carb is probabbbly clogged alsocheck the fuel filter in the bottom of the tank fish it out with a peice of wire and clean it blowit out with are might be clogeed ? if not take offcab carefully and remove side covers and get you a can of carb claener with a straw and blow out the ports ? good luck
Aug 26, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
