Question about Danby DPAC13009 Air Conditioner
The remote is not communicating with the AC, Both function but wont get along. Is there any way to reset the remote??
    New Friend:
  • 84 Answers
Try to use the bottons on the a/c unit first if it functioning well,if it is good then the culprit is your remote control needs to repair.some models also are having tiny holes ,some at the back and some are at on front.dont use any metallic materials to switch the miniaturised built in bottons instead use some made of woods and coconut stem and plastic forms stick to resetting the remote
Posted on Apr 23, 2014
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
Is this a thermostat problem or system failure?
it sounds like no communication from stat to board. cable connections
Jun 03, 2014 | Dometic Rooftop RV Air Conditioner
Ac wont turn
Do you mean the invertor does not run?
Dec 01, 2013 | Computers & Internet
Ask com lg ac window unit control panel stopped working
Hi Gina, Try turning off the unit at the electrical panel. turn off switch, wait 15 min. turn switch back to on position. Turn on AC unit. Hope this helps.
Oct 21, 2013 | Heating & Cooling
My LG Remote control AKB35551201 STOPPED WORKING
I have lg ac with fan control in remote. Model no. LSA5NF5VFC1.AN48DV1(ll) so i want new remote of my lg ac along fan control.
Jul 31, 2013 | LG Heating & Cooling
MY SAMSUNG SPILT AC 1 1/2 TONS SLIVER NANO TECHNOLOGHY TYPE IS NOT RESPONDING AND A GREEN LIGHT ALONG THE I HR SYMBOL IS FLASHING ..! WHAT DO I DO?
It means, someone set the timer to start the unit after one hour. To cancel, simple remove battery from remote and reset it. And also power of the unit and reset it. Now start your unit with remote.
Dec 16, 2010 | Samsung Heating & Cooling
Insignia remote wont work
sandraw, try disconnecting the tv from the ac outlet for a few seconds(20-30) and reconnect and then try your remote, in your description you do not mention if this remote is the original equipped remote that came with the tv, but i am guessing it is since it is a fairly recent model. You also don't mention if the tv works with the function keys(pow,volup/dn,chn up/dn etc)this also might point out to wether there is damage to the ir preamp board, a bad preamp board would also impair the overall function of the remote as well as the customer selection from the built in function keys. hope this helped and please leave your positive feedback, if i answered your question.thanks!
Aug 28, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
A.c. wont turn on
seems new board is needed.
Oct 07, 2007 | Heating & Cooling
Open Questions:
What is the best physical configuation exhaust/drainage to use with dehumidifier mode to avoid room temperature increase? There are 2 drainage outlets on this model top and bottom. However the user manual doesn't mention about the top one. In AC mode, if I don't connect any drain hose, the unit fills up fast and stop. When the exhaust vents are connected outside required for AC mode only, I cannot use the bottom drainage hose because I have no drain nearby. Therefore I use the top drainage and add a bucket beside the unit. This setup works fine for hours in AC mode without intercuption and the bucket fills up with water fast. However the rooms gets too cold below 20C/68F while still quite humid +60%. But if I switch to dehumidifer mode with the same setup, the unit only runs for a few minutes, then stop completely for another 5 minutes, then turn into FAN mode which blows very humid air for another while and then turns the compresssor back ON for another 5 min. and the loop start over. After hours of operation, the bucket nearly has any water and the room humidity is the same if not worst. I thought the compressor was defective so I tried the dehumidifer mode without the exhausts vents connected outside and the bottom drainage hose as suggested in the user manual. This setup works continuously but does not remove much humidity vs. the amount of heats it generates. The unit has AUTO Mode which switch between AC and dehumidifier mode. So there must be a way to keep the same physical installation exhaust and drainage for both these mode, is there? Thanks
Jul 30, 2016 | Danby DPAC13009 Air Conditioner
See all Danby DPAC13009 Air Conditioner Questions
Danby DPAC13009 Air Conditioner Logo
113 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
