Question about Perfect Fit Industries Llc Home
Soft heat warming throw quit
Soft heat Lux.micro fleece elect.heated warming Throw,When turned On,lights up about 3-5 seconds later light goes out,does not heat,purchased 12/12/2011
    Top Expert:
  • 42,979 Answers
The heating element may have failed.
Posted on Apr 16, 2014
I want to know if my throw is under warranty. I think I probably registered it as a gift, probably two years ago, a Christmas gift. Serial #D105VT07176010612B86112.
Hi Judith
your heated throw has a 5 year warranty! Warranty is covered on this page, specs are on the bottom link.
http://www.sunbeam.ca/en_CA/service-and-support/product-support/product-faqs/bedding/warranty/bedding-warranty-faq.html
Sunbeam Velvet Plush Heated Throw Mushroom Sunbeam Canada TSV8WS R772 26A50
Dec 02, 2015 | Sunbeam Fleece Throw Electric Heated...
I cannot get the f to come off so I can get the blanket on
Sometimes unplugging the blanket from the wall plug causes it to "reset"
Feb 27, 2015 | Sunbeam Fleece Throw Electric Heated...
My lights inside my fridge won't turn off. It was fine this afternoon and now it's not. It's not even 3 years old. The heat from the bulbs is making the top 2 shelves too warm and I have already been...
Your Refrigerator light door switch may be broken or damage.
1) Check manually Press the button on hand. Light off or not.
2) Light not off - replace the switch.
3) Light off - Door position or alignment not correct.
Mar 26, 2011 | LG LFX25960ST Stainless Steel French Door...
Receiver smoked, sizzeled and then quit
Throw on a couple of shrimp it and let us know when they're ready. You need a pro to look inside it.
Mar 19, 2010 | Yamaha RX-V2400 Receiver
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
I've owned this saeco vienne de lux for about 3
Hi
When was the last time you descaled the machine? Scale will build up inside the boiler and insulate the water from the heating elements. The thermostat is on the outside by the heating elements so it gets hot but your water is warm. There are other things but check this first.
Nov 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Microwave does not heat but light goes on and the table turns
The klystron tube that provides radio (micro) waves to the enclosure is not working. Problem could be (and most likely is) the high voltage power supply that feeds the klystron tube. Alternately, it is the tube itself. In this society (throw away), it may be less costly to just find another microwave on sale or on Craig's list and replace yours.
The klyston is very expensive and the power supply replacement is labor intensive.... sorry.
Sep 28, 2009 | Maytag MMV4205 Microwave Oven
Home Logo
96 people viewed this question
Top Perfect Fit Industries Llc Home Experts
john h
Tom Chichester
Are you a Perfect Fit Industries Llc Home Expert? Answer questions, earn points and help others
