Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side Refr. water leaks under freezer side. seems to be connected to defrost cycle. water can be mopped up with paper towel. put small pan under fridge but does not capture water. Does not leak every day.
  • 72 Answers
The drain is clogged in the freezer. Take off the back wall inside of the freezer, there is a drain in the bottom, use a turkey baster and hot water to clear all of the ice, pour hot water into the drain, put a piece of weed trimmer line down the hole and try and push the obstruction through, do not use a coat hanger or wire, you will puncture the drain tube and make bigger problems. Finish by pouring more hot water in and making sure it all goes down.
Posted on Jun 18, 2009
Freezer side is leaking water & temp is 25
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 12, 2009 | Jenn-Air JCD2389G Side by Side...
Constantly defrosting freezer automatically and
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Oct 05, 2009 | Admiral 26 cu. ft. Side-By-Side...
Side by side leaking water from under freezer side
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint HSS25GFP Side by Side...
Water leaking out of the bottom of my ge refrigerator.is there a tray that I need to empty? cannot locate one.
Sep 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Leaking water onto the floor from bottom left side of refrigerator
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 23, 2009 | GE Refrigerators
Bottom freezer is leaking, what causes this?
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! Mike.
My fridge leakes water?
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 18, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Have a GE side by side, when it goes through the defrost cycle puddles of water form outside the unit. Drain hole in bottom of freezer seems to be clear.
You have a blockage in your condensate defrost line or the pipe that fill the tray below thr refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate bak into the air inside your home. Or this sounds like you have a blockage in the drain tube, remove panel back of freezer...you may see ice build-up, melt ice with hair dryer, you will see a pan below evaporator, melt ice in pan, dry water up in pan with towel, now you should see drain hole in pan that leads to drain tube, pour some hot water in pan, wait a couple minutes, wipe up water and repeat this step 2-3 times, once you have done this use a wet and dry vacuum cleaner to **** out the gunk or blockage in the drain line. Now it is cleaned out! Put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. Good luck! PS Please don't forget to rate my solution Thanks! Sea Breeze
Aug 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE GSS25JFMWW and am seeing water on the floor of the freezer section. I also noticed that the water that's supposed to go through the drain tube is freezing. I checked the heating element &...
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jul 08, 2009 | GE GSS22JEM Side by Side Refrigerator
Fridgidaire Gallery Series Side by Side Refridgerator
"jennycub" sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. very common problem( easy to detect. water on the floor of freezer compartment) as far as the other posting by" humblerumble", ive seen where the drain tube under the refig has pushed a hole into the drain pan under the refrig, in which case it will only leak after a defrost cycle, with the kickplate removed grab a flashlight and look under the unit for the drain pan as you pur water into the back of the freezer sect to trace water flow
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
139 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
