Question about Whirlpool Refrigerators
Water in refridgerator compartment - Whirlpool Refrigerators
  • gary
    gary Apr 16, 2014
    This is a Wirlpool Gold top freezer model # GR9SHKXKQ00 MFD 06/01
    Problem Solver:
  • 12 Answers
It would be helpful if you could give the make and model of your refrigerator. But with some fridges there is a funnel at the back under the freezer. It is connected to a plastic tube that runs down the inside of the back of the fridge. When that tube becomes blocked, it causes water to overflow the funnel.
If you find that this little funnel has water in it, here is the solution: You can usually find a very long pipe-cleaner (about yon yard or one meter) at specialty stores. Remove the funnel, take the pipe cleaner and ream the pipe. Replace the funnel and that should solve your problem.
If your fridge does not have this drain, then there are other possible causes. To really tackle this properly we would need to know the make and model. Cheers.
Posted on Apr 16, 2014
  • William M. T. Apr 16, 2014
    Thank you for the model number. This fridge does not have the funnel method. I suggest you follow Jimbo460's method.
    I can't believe that they edited out reem (sp in order to bypass censors).
3 Suggested Answers
  • 51 Answers
SOURCE: water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 09, 2009
hiltonjug
  • 612 Answers
SOURCE: Kenmore Refridgerator leaking water into
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Posted on Sep 01, 2009
There is water in the refridgerator
You have a disconnected defrost drain pan. You will need inspect the ceiling of your refrigerator compartment and find the drain hose going from your freezer to your fridge then the drain pan. Sometimes this is molded into the plastic at the back of your fridge and it simply leaking out the joint. Start by defrosting your freezer, then pour water in the freezer itself while checking the ceiling of the fridge for water traces. Keep a wet/dry shop vac handy or a mop to keep up with the excess drainage. Then reattach the hose to the little drain nozzle when you find it.
Mar 13, 2010 | SUMMIT Professional FF1615SS Refrigerator
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
Sep 01, 2009 | Kenmore Refrigerators
I have the same problem with my Kenmore refridgerator
To completely clean a frig of bad smells you will need to remove the back cover of frig and freezer compartment to access all areas. I operated a used appliance store for years and had all manner of stinky refrigerators to deal with so what we did was take out all panels and clean out with bleach and water solution. This took care of most odors. Hope this helps.
Jul 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
May 23, 2009 | Kenmore Refrigerators
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Water drains from freezer compartment into refridgerator
Jan 09, 2009 | Refrigerators
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Refrigerators
Refrigerators Logo
201 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
