Question about Vizio Televison & Video
Cant cut vizio tv off manually
Menu is up but no button on remote works and cant even cut off manually....tv is 2 weeks old from costco
    Top Expert:
  • Vizio Master
  • 44,161 Answers
Return the TV for replacement
Posted on Apr 16, 2014
VOTIT
  • 2071 Answers
SOURCE: VIZIO REMOTE CODES
JUST TRY THIS PROCEDURE;
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 02, 2008
  • 5 Answers
SOURCE: vizio plasma tv turned off..won;t turn back on
This sounds like the main power board went bad. If this is still under warranty, contact 1-877-MYVIZIO and they will have it repaired for you. if not, let me know and I will guide you to the right part.
Posted on Oct 20, 2008
jerryg50
  • 1689 Answers
SOURCE: remote stop working
You should verify if the remote has failed. Contact the support for Vizio, or ask your dealer where you can buy original replacement accessories.
Visio Tech Support:
http://www.vizio.com/support.aspx?id=1586
Most of the time, we've seen the remote fail. Sometimes we are able to service the remote. Sometimes, the IR LED and or the crystal fails in the remotes. If it is more than this, it is impossible to have internal service parts for most remotes. It takes service experience to be able to change these parts.
On rare occasions the IR remote sensor and remote processor area in the set can have a failure. It is best to try another remote to verify this before sending the set for service.
The most common causes of failure of a remote controller is dropping, rough handling, getting food and drink inside, or putting the batteries in backwards.
Jerry G.
Posted on Apr 26, 2009
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Posted on May 25, 2009
antn
  • 15 Answers
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Posted on Jun 11, 2009
I have a 42 inch Vizio tv, 7 years old. The menu button will not work although other buttons, like volume button does. Why would menu button not work?
I have a similar issue with my 10 year Vizio 42", it is the infrared receiver in the TV that is the problem (tried other remotes).
Dec 02, 2016 | Vizio Televison & Video
My 6-month old tv is making intermittent 'buzzing" sounds. It was a Christmas gift and I don't have any paperwork on it but it did come from Costco. What should I do? Thanks so much.
Humming usually begins when the backlight setting is low. For some sets setting the backlight anywhere from 95 to 100 works. Most wok at 100. So turning it up should get rid of the problem. You can follow the 5 steps below to change the backlight setting.
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Jun 15, 2011 | Vizio 42 in. LCD TV
Cannot remove the 'store' settings from 55 inch vizio bought at costco today When i push the "OK" button on the remote it 'thinks' that I'm pushing the 'menu' button and gives me the 'menu'...
Unplug the set for 20 minutes then plug it back in and turn it on. You should see a setting that says HOME____STORE on the screen. Make sure you high-lite HOME. Then continue on.
Dec 27, 2010 | Vizio XVT553SV 55 in. LCD TV
I have just bought the 42 Inch Vizio from costco and it worked fine for two weeks and then the remote stopped working. Also the DishNetwork remote which I used to control the TV and the DN 622 can not...
We're sorry to hear about Vizio TV remote, but we would be happy to help you with getting your DISH Networkremote to control your TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Vizio TV; here some of the codes we currently have: 505, 598, 627, 520, and 766. Press the pound (#) button. To check that the code works try severaldifferent functions on the remote to make sure it will properly operate the TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 07, 2010 | Vizio VO47L 47 in. LCD TV
Vizio 47" Costco hdtv has red floating areas!
After posting this problem we did call Vizio. They sent out a repairman (had to wait over a week) who fixed it by: Replacing the LVDS cable and the main board. (Just like somebody on this blog wrote somewhere!) We also had just previously called our cable company who came out (also free) and checked our system only to find the cable running around the house to the tv needed replacing as it was sending zillions of errors. The red flowing problem (called "red pixilation") was due to the Vizio LVDS cable and main board being faulty from the factory.
Just want you out there in web land to know how to get your similar problem fixed!
Jun 10, 2009 | Vizio VO47L 47 in. LCD TV
Vizio remote control not working
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 32 inch now shows mostly only green and red colors
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD
Nov 30, 2008 | Vizio L32 32 in. LCD HDTV
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Vizio LCD
Pretty good chance the logic board is defective. all remote and manual command go trough the logic board via a micro prosseor. If that is bad the set gets false commands. If the run number is the same on that model they probably all have the same problem.. Get another brand not made in China.
Jun 20, 2008 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
