Question about Cell Phones
A row of keys on my phone dont work - Cell Phones
    New Friend:
  • 10 Answers
If your phone is damaged by water, be sure you dismantle the break away pieces and submerge them in a bowl of dry rice for at least 3 days. Rice can help extract and evaporate liquids in the surrounding air.
If your phone is damaged physically or was ever dropped, it's possible that a loose connection formed within the device. Considering liquid crystal displays are made of many individual touch sensors, if your "keys" are on the touch screen. That could be why it doesn't work. Verify if that portion of the touch screen works for anything else. If it does, install a new keyboard on your phone or reinstall the existing.
Posted on Apr 16, 2014
Top row keys don't work on iPhone
your digitizer is not working, you need to chane it and itll work fine after that
Dec 13, 2012 | Apple iPhone 3G Black Smartphone
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
Jan 05, 2012 | Nokia 5700 Cellular Phone
My nokia n97 fails to start and its diplay contact retailer plzzz help me out
Note: You may back up all your information on your phone before doing a hard reset
Steps to hard reset your Nokia N97:-
1. Switch off your phone.
2. Press left shift key (first key in the third row), the space bar key and the arrow key (last key in top row) simultaneously.
3. Keeping the above keys pressed, press the power key. Keep all four keys pressed till your phone asks for country details etc.
4. Now you may release the keys, fill in the details and you are done.
Apr 26, 2011 | Nokia N97 Cell Phone
I dont know where the power of ten button is, it is really confusing, when you dont know where it is when doing equations on your homework.
To enter an exponent of ten, use the EXP key in the middle of the bottom row. For example, to enter 1.2 times 10 to the 7th, press
1 . 2 EXP 7
If you want to raise 10 to a value, use 10^x, the shifted function of the LOG key on the top row.
Oct 19, 2010 | Casio FX-260 Calculator
Ok key and bottom row keys on front pad dont work
the problem is as a result of accumulation of dusts underneath these buttons,
However,the solution is to take apart the buttons and apply spirit with the help of a cotton wool.to clean out the button pads,please avoid the use of excess spirit on the cotton wool which may have adverse effect on the panel below the button.
Take care
Aug 03, 2010 | LG enV VX9900 Cellular Phone
Keyboard double letters showing
there is short in the data cable
may be some liquids spill inside it
you have to clean it and if this fail may the keyboard controller on the mother board is corrupted then you have to use external K.B or change the Mother Board
shadi
dont forget to rate my solution
Jan 24, 2010 | Dell 0Y3740 Keyboard
Center key, left, right, up, down, 2,5,8, not
New keyboard membrane required (keyboards often come in one piece, and you can get whole rows failing particularly with liquid damage
Good Luck
Jan 14, 2010 | Samsung SGH-a727 Cellular Phone
In keypad the numbers 4,5 and 6 are not working
there is a cut line between the board, because the 456 a the same line in the outer key, so you need to jumper it , if you dont know let the technician do it, JUMPER
Apr 03, 2009 | Nokia 7610
Rim blackberry curve 8310 nothing works after 4.7 update
First of all what os were you trying to put on the phone? 4.5 Exact version needed. 4.5.081. You can try to unplug phone then replug phone also unplug battery replug batter. then try installation again. make sure os is correct version for phone.
Dec 28, 2008 | RIM BlackBerry Pearl 8100
S510 Keyboard Problem, Keys Dont Work, Everything Else Works,Ect-Mute
I had the same the problem. The cause was a corrupted encryption code. That is why only worked the keys that don't require encryption.
1) Install the Logitech software and restart.
2) The software will tell you to press CTRL-ALT-F12. This procedure resets the keyboard encryption and tells you to enter a new code.
3) If you already had the software installed simply press CTRL-ALT-F12 and follow the above procedure.
Mar 15, 2008 | Logitech Cordless Desktop S 510
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
