Question about Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL USB 9600X2400 6.0IPM * 3747B002
Canon Pixma 560 printer/scanner won't recognize a cartridge I replaced. How do I fix the problem?
    Scholar:
  • 124 Answers
Is this cartridge a Canon cartridge or a generic aftermarket one? The aftermarket ones tend to fail a lot more even though they might be new. Try another cartridge to see if that helps. I feel your pain because I also use aftermarket cartridges because they're 1/4 of the price, but this is a common occurence. Let me know if that helps.
Posted on Apr 24, 2014
old marine
  • 1983 Answers
SOURCE: installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Posted on Apr 17, 2008
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
SOURCE: Canon Pixma iP1600 printer: ink
MY PRINTER WILL NOT RECONGNIZED THE COLOR CARTRIDGE IT IS THE RIGHT ONE
Posted on Oct 16, 2008
realbat2
  • 68 Answers
SOURCE: printer won't accept cartridge
i sure u buy wrong cartridge for your MP450...if u want higher quality, u should buy CL-51 cartridge for colour and CL-50 for black..
fyi, CL-52 can only suitable for IP6210D / IP6220D printer. u can see yourself at this link :
http://www.canon.com.my/section/inkjetPrinter/supplies/
hope this help... ; )
Posted on May 26, 2009
dejoebad
  • 4 Answers
SOURCE: canon pixma ip1700...cartridge cannot be recognized
do a temporary reset. u can found it how to do it.
temporary reset is a procedure before doing a permanen reset (usualy with resetter software)
temporary reset is bypass ur cartridge recognition
here it is :
1. turn off ur printer
2. pull off all cable that connect to printer (2 cable, usb and power cable)
3. press and hold the power button, then insert the power cable (still hold the power button)
4. while u still hold the power button, press the resume buton twice. the release them both.
5. because its a temporary reset. u must do it again if u lost electricity power.
met coba :D
Posted on Jun 03, 2009
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
Canon printer won't recognize new ink cartridge
did you take the shipping tape off of the cartridge? It's usually the one covering the contacts located on the underside of the Cartridge that is inserted into the receiver of the cartridge. Other wise, you may have a bad cartridge, if so, bring it back to where you purchased it and get another one. Chris Chrisab123@live.com
Feb 28, 2012 | Canon PIXMA MP160 All-In-One InkJet...
My new pixma canon ip 2770 cannot recognize the black and colored ink
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Canon pixma MP150 was working normally and today it says that cannot recognize ink cartridge. what can be solutions?
Fix Canon pixma MP150 was working normally and today it says that cannot recognize ink cartridge
May 20, 2010 | Canon Pixma MP500 All-In-One InkJet...
How to fix error code 14 for canon pixma mp145
This usually means that the cartridge is not recognized by the printer. If you are using aftermarket or reloaded cartridges, replace it with an OEM cartridge. Chances are the cartridge is faulty. Return the faulty cartridge to vendor or discard the reloaded cartridge since it is not able to be properly identified by the printer.
Nov 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon printer problem
Scanner not work because printer need recognized both cartridges.In your case color cartridge is defective.Replace it and the message will disappear.
Sep 13, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Printer does not recognize cartridge which was good yesterday
Hi
Tough one here but try removing / replacing cartridge, failing that try new replacement as each cartridges have their own electronic chips. I assume you are using genuine canon carts.
Cheers cbacer
Aug 11, 2009 | Canon PIXMA iP90 Mobile Printer
My canon pixma MP145 showed E5 and wont print anymore
I have been using black and color ink refills for sometime now, but am unable to use my printer since last week. It shows E5 and on the dialogue box is stated that it cannot recognize the COLOR.
Aug 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL USB 9600X2400 6.0IPM * 3747B002 Logo
49 people viewed this question
old marine
old marine
