Question about Dell XPS Computers & Internet
AHCI Port2 Device error and SATA Port3 ST1000DM003. CC49 S.M.A.R.T. Capable and Status BAD come up when trying to install a new HDD on an older Dell xps9000 that a s.m.a.r.t event noted on the old HD
Trying to reinstall win7/64 on a new HDD and windows can't seem to find it. Have dell reinstall disc for w7 and one for drivers and utilities but can't install. Just ran a full diagnostic check and the machine checks out good. Must have done something stupid...... Help?
  • 790 Answers
Enter your BIOS on unit and turn off SMART drive detection
Posted on Apr 16, 2014
frcs68
  • 1605 Answers
SOURCE: Dell Precision 470 Dual Processor
enable "auto" in BIOS for drive #0 and drive #1. you can select IDE or SATA drive. restart the machine.
Posted on Dec 10, 2008
kamal1984
  • 1383 Answers
SOURCE: no boot device available - strike F1 to retry boot, F2 for setup
again check is bios is there set first deviced as cd rom dvd rom?
If it is just clean your bootable windows cd with hand caurchief.
Then check if it not boot with disk then your cd disk of windows is not bootable or faulty.
Please let me know.
Posted on Jun 06, 2009
asingh1225
  • 122 Answers
SOURCE: Dell Inspiron 531 gets me crazy..
hello, sounds like memory issue, I would say if you have more than one stick of memory in it remove one at a time and try it again.
also while you are at it reset BIOS by remove battery from motherboard and/or switching jumper setting.
hope it helps.
regards
Amar Sondhi
Posted on Dec 05, 2009
  • 561 Answers
SOURCE: IDE Device Failed on Dell Dimension
Hi
Thank you for your query
From the error message that you are seeing you are having a issue with one or both of your IDE devices. These devices are your Hard drive or/and your CD/DVD drive
I would not recommned that you tackle it yourself if you have no PC engineering experience
Please book into a reputabe firm for further diagnosis, it may be that you may need to discoonect the IDE drive from the devices and give it a clean or alternativley one of the devices may be faulty
If this has been useful please leave positive feedback/vote/testimonial as
this will help me greatly - Thank you again
Posted on Feb 13, 2010
SOURCE: Hello, Im trying to install
Chek your CPU fans working properley and reinsert memory
Posted on Jan 03, 2011
PC HANGS ON BOOT
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Feb 18, 2012 | Computers & Internet
Hp2200c scanner for windows 7 need drivers
There are no more drivers under W7 for this unit .
If you have W XP install disc , you can install a virtual version of XP on your HDD .
You also can create a partition on your HDD where you can install XP .
Otherwise , i' m afraid you'll need to buy a new scanner .
Regards .
Dec 29, 2010 | HP ScanJet 2200C Flatbed Scanner
Need drivers for windows 7
There are no drivers under W7 for your unit .
If you have the XP install disc , you could install a virtual version of XP on your HDD .
You could also partition your Hdd to install W XP on the new one .
Otherwise , there is no other solution than buying a new device .
Regards .
Dec 27, 2010 | Artec e+48u Flatbed Scanner
Neew canon 3000f driver for windows 7 64 bit
I'm afraid there are no drivers under W7 for this unit .
You could , if you have the W XP install disc , install a virtual version of W XP on your HDD .
You could also partition your HDD and install W XP on the new one .
Otherwise , you 'll need to buy a new scanner that runs under Windows Seven .
Regards .
Dec 27, 2010 | Canon CanoScan 3000F Flatbed Scanner
No boot device available- strike F1 to retry boot F2 for setup utility
you can try this steps to resolve your issue:
1. clean your disc drive with white cloth and alcohol
2. try to re-install the OS
3. if this won't work try to download another boot disk like EBCD
or ask a friend to create you a boot disc and try to boot your computer with it.
- This can rule out or confirm a Bad Windows OS disc, thus let's you install you Windows OS in the process.
4. try to re-install again the OS
May 21, 2010 | Dell Dimension 8400 PC Desktop
Trying to install drivers and utilities disc
First install Windows OS in your PC to make it bootable then the motherboard installer of Dell to install all utilities and drivers.
Jan 28, 2010 | Dell Inspiron 6400 Notebook
Reinstalled Windows XP no ethernet card
It seems that after re-installing windows you have missed the Driver installation for your hardware. If you have a disk (which reads Drivers and Utilities) that came with your computer, You can insert it in your CD Driver and select the Driver for Network adapter. If you do not have a disc, you can always visit the Dell's support site i.e.:support.dell.com and Get the drivers suitable for your hardware by selecting the model or Entering the Service Tag of your Dell computer.
For your convenience I am providing below the link for Drivers for Dimension 4700 Desktop PC as you have mentioned.
Intel (R) PRO/100 Driver for Dimension 4700
Hope you find this information helpful.
Your comments and ratings are highly appreciated. Please do not forget to leave your feedback and ratings.
Thank you for choosing Fixya.
Dec 15, 2009 | Dell Ethernet Card Network Adapter
I am trying to install windows service pack 1. I keep getting an error code: 0x00F0826. Can you tell me what this means and how to fix it? I am running windows vista basic. 32-bit. Thanks.
if there error appeared while windows copying files then disc OS or the DVD ROM might be faulty. Try to test first the ODD if it is faulty. Use the drivers and utilities cd from dell to test the DVD ROM. If DVD ROM reads fine the drivers disc then try the OS disc to a different computer if it can load vista files. if not the OS disc has the problem. If no issues with OS disc and DVD Rom then it might be the HDD.
Oct 22, 2009 | Dell Inspiron 1420 Laptop
Dell hard drive
If you can figure out how to remove the hdd, you can just use the restore discs to reinstall the OS using the windows key on the machine (usually a sticker on the side). You wouldn't need to rebuy a key.
Good luck getting that hdd out!  :)
May 09, 2008 | Dell OptiPlex SX270 PC Desktop
Computers & Internet Logo
677 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
