Question about Health & Beauty
Bf522dm Err Just reads Err
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
I keep getting Err after replacing battery
my scale keeps reading err when I step on it
Jun 01, 2014 | Homedics Digital Scale
Lexus 2001 is 200 6 disc stereo error 1 code shows when trying to play cds
Error 1 - "disc is dirty, damaged, or is inserted upside down"
I quote other solution comments:
I've been getting the Err 1 and Err 3 for a while now, my headunit needs replacing but I haven't had chance yet...
I've found that the cold weather makes it worse as the CDs get that cold they are covered in condensation so the CD has trouble reading them..
In my experience when you get an Err 3 it's basically knacked and needs replacing and Err 1's can sometimes be read problems - what's the disk like?
Mine has started giving Err 1's on brand new CD's (not CDRs) so she's probably having trouble focussing....
If the car is less than 5 years old the headunit should be covered under warranty (ie free).
Hope helps.
Apr 02, 2011 | 2001 Lexus RX 300
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Err message nikon f-100
Read pages 99-101 of the manual. There are numerous err messages referenced. Some blink others only have the E of Err blink and the like, all with different solutions. If you cannot find the manual call Nikon Film 1-800-645-6687.
Aug 10, 2010 | Nikon F100 35mm SLR Camera
1999 Chevy Lumina won't play any CD, display reads 'ERR'
Hi:
Unfortunately, the ERR is a disk read error, and usually caused by the laser being out of alignment. It seems in my experience that An aftermarket deck is a cheaper solution than having it repaired.
Nov 20, 2009 | 1999 Chevrolet Lumina
My coffee maker reads err rr 2 and then err 4
Probably, the unit is short circuited from water flooding over the electrical boards. :(
Nov 05, 2009 | Kitchen Appliances - Others
OBD-II read ERR from my 1998 Dodge Grand Caravan 3.8
Visit http://www.troublecodes.net/OBD2/
Aug 24, 2009 | 2001 Dodge Caravan
CD will not read or play....ejects ;;ERR message flashes Help
try different KnownGood cd and if still an issue your head unit needs repair internally .(not worth it)
Nov 24, 2008 | 2000 Chevrolet Silverado
Replaced radio with one from same model year. Displays Err 01.
this generally means the laser is either dirty or the cd player is shot, err 01 is a disc reading problem. Try cleaning lens with cleaning disc first if this does not help i would replace the unit with another. i would recommend replacing it with a cheap aftermarket stereo.
Nov 18, 2008 | 1997 Saturn SL
Health & Beauty Logo
23 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
