Question about Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile Transceiver Amateur Ham Radi
I have a yaesu ft2900 ham radio when i key the mic it turns off then comes back on help
What do i do i can't use the radio like this each time u key the mic radio goes off then comes back on help
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
You have all the making of not enough power to operate the radio and it shuts down to protect itself. Hook the power leads directly to the battery terminals and keep the leads as short as possible. The more wire you have the more resistance and the more resistance the less volts your radio can see. Also be certain you have a good ground connection
Posted on Apr 19, 2014
When I key the mic up it turn off and then comes back on
Have you tried to look at mic pins where the mic connects to radio?. it will be at the end of mic connection..look in there and see if the copper pins have spread apart. you will be able to tell by looking at the other pins. if one is spread apart it wont make a good connection and shut things down. be sure when you screw this back on to radio it is tight., if you dont have copper pins just straight pins check to see if the straight pins are not loose. if they are you will need to solder them back tight.other than that it could be your radio..hope this helps.
May 28, 2016 | Radio Communications
Why is humming coming from speaker when mic is keyed?
this is strange as most times if a proper transmit key is depressed , then the radio switches from receive to transmit , the mfg know this would cause some great squeal from receiver /transmitting so close to a receiver so the part that is the receiver is muted to keep this from happening , id say there is some fault in the part that does this muting of receiver
Apr 13, 2016 | Radio Communications
Ft 2900r when I push then talk button on mic it shows error on all channels even with second mic
Sounds like a programming error. Does it work properly in VFO mode? Did you try a reset?
Jan 10, 2015 | Yaesu Ft 2900r Vhf Mobile 75 W Two Way...
How to get up/down functions on hp508 ham mic to work with icom 718
The IC-718 requires a 470Ohm resistor for the down button and grounds pin three with the up button directly. That isn't standard on the hp508 mic. It is designed so that the up/down buttons work for kenwood radios, and they are completely different. The kenwood uses pin three for down and pin 4 for up and they use a different pin for ground. You could make a special cable with the resistor built in and the correct pins connected to the up/down buttons and that would work.
Oct 10, 2014 | Radio Communications
Replacement mic.
Check with "Ham Radio Outlet" online. They should have a replacement.
Feb 22, 2014 | Yaesu FT-726R Transceiver
Yaesu radio
You will have to contact Yaesu parts for this, or Ham Radio Outlet may have them:
Ham Radio Outlet World Largest Supplier of Amateur Radio Ham Radio...
Dec 03, 2013 | Radio Communications
CB is in transmit mode with no mic connected
Got a short either at the mic socket or the keying circuit--try first to disconnect leads at the socket one at a time.
Jun 12, 2012 | Radio Communications
External mic for ft 50 yaesu purchase
Yaesu offers the MH-34B4B Speaker Mic or the MH-37A4B Earphone Mic for the FT50 HT.
Speaker Mic (Heavy / Standard Duty)
Earphone Mic (Light Duty)
Any ham radio store should be able to obtain these - if they are still in production / stock by Yaesu. Ham Radio Outlet aka "HRO" has stores nationwide and can ship direct.
I hope this helps!
Jan 26, 2012 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
My radio is a Galaxy DX 98. It squeals when I key up
change "MIC" to a factory,or turn back Mic gain. Mic can short out or may have too much gain(power mics). Use standard dead Mic that was designed for radio. If that does not help,it may be inside radio, wires on MIC connectors need soldered again(make sure they don't touch th eothers.
Apr 23, 2011 | Radio Communications
Radio squeals part time and meter only goes up half way when keyed up
you have a Microphone problem.. change your Mic. Mine done the same thing when Mic wires shorted together inside of the handpiece. Also, when it doesn't match the Ohm impedence. you can buy a replacement Mic at www.copperelectronics.com or Radio Shack.
Mar 31, 2011 | Radio Communications
Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile Transceiver Amateur Ham Radi Logo
189 people viewed this question
Top Yaesu Radio Communications Experts
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
