Question about Saws
Blade drift My craftsman band saw will not cut a reasonably straight line. The blade tends to drift to the right even when using a fence or other guide system.
2 Suggested Answers
  • 4 Answers
SOURCE: straight cutting with rip fence
when i use my table saw, i use clamps on the fence, i dont rely on the one built in.
Posted on Feb 26, 2009
Dose not cut in a straight line wonders
First question: What are you cutting? Are you cutting wood? If you're using fence, I need you to make adjustments on it . The nature of the band saw is to drift either left or right being parallel with the band saw fence. Is the blade tension too tight or insufficient? Check your manual for correct tension or you can just see in the tension gauge on your saw. Please this blog on how to check the correct blade tension . What is your feed and speed rate? Make sure the you're not feeding the wood too slow or too fast. Are you using new blade? Your blade is may be dull or low quality. I purchased my blades on www.sawblade.com . Their Haltbar 201 Series works great on general wood cutting.
Last question, have you taken up time to tune up your saw? See this blog for your reference.
Sep 11, 2013 | Craftsman Saws
Ryobi 9" Band saw blade
The problem might be blade drift, feed & speed rates. Are you using a fence? Do you have a good blade? I had pretty good luck with my Haltbar blades of www.sawblade.com . Does your blade track properly? Check this blog site . This might help too.
Jan 23, 2013 | Ryobi Saws
Got a coronet band saw and it is not cutting true
I am not familar with the Coronet saw and there are alot of reasons your saw may not be cutting true.
- Mark a straight line appx. 1" from the edge on a 2 foot board, using the fence cut the board. Does it stay on the line? if not this is called "Drift"
-Most fences on band saws have a drift adjustment. To adjust mark a board the same as before but this time don't use the fence and saw it down the line about half way, turn off saw with the board in the saw, now slide the fence next to the board. you will see a gap on one end or the other adjust fence to the board(i.e. drift adjustment) now you saw will cut true.
NOTE- on saws that don't have this adjustment you may have to shim the fence to fit.
-If you go to You Tube and look up band saw set up they will cover this in detail.
I hope this helps
Shop Dog
Nov 18, 2010 | Saws
Unable to make a straight cut with saw. Tried adjusting tension, lowered blade, made sure blade aligned properly and did not feed too quickly. HEEEEEELLLLLLLLLLLPPPPPP! Thanks in advance.
Hello, I think that the problem you are having is called "drift" . each blade will cut different than the last. The way I was taught to cure this goes as follows.
-take fence off off table(or just move over)
-get a good square piece of material appx. 1x3 and mark a straight line about 1/2" from edge the full length of the board.
-with out the fence cut the board along the line appx. 1/2 the length.
-shut off saw WITH board in it.
-use a angle finder along the edge of the board, set angle finder
-remove board and put the fence back on.
-now slide the angle finder up to the fence, you should see that the angle is different than the fence (this is the DRIFT ), adjust the fence to the angle finder( I know that the smaller saws usalley don't have this adjustment ) you will have to find a way i.e. shim etc.
This is a very common problem but once you get the idea it is a easy fix
Remember: A guy taught me and I taught you, pass it along thats what we do.LOL
Hope it helped.
The Shop Dog
Oct 23, 2010 | Ryobi 9 in. Benchtop Band Saw
I can't get this saw to cut straight or square I
Band saws pull to one side on straight cuts, it's a function of the blade torque. My 14" saw pulls to the right. There's nothing you can do to stop this, you have to be aware of it so you account for it on free cuts and know to put your fence on that side so the wood pulls into the fence instead of away from it. Squaring the blade to the table is easier. Do not go by the tilt angle guide. First make absoutely sure all of your blade guides and bearings are properly alligned so they aren't pushing the blade out of line. Use a square to get it close then: using a 4" x 4" block of wood, make a light cut in the wood only deep enough to mark the wood from top to bottom. Turn the block over 180 and try to make a cut in the previous cut mark. If the cuts line up you're there. If you get a V or X you have to make adjustments to the table making sure you tighten the trunion locks tight. I had one of these, it's not a high end saw so don't expect a lot from it.
Aug 23, 2010 | Ryobi 9 in. Benchtop Band Saw
New table saw, timber runninig off away from guide, saw blade running its own line,do i need to reset the guide.
The guide is called a fence. The fence should be positioned to the right of the blade. When using the fence, the largest part of the board goes between the blade and fence. Fences are typically have some relief toward the end, so you don't get the blade cutting on it's way down, and then cutting again on it's way up.
Apr 22, 2010 | Craftsman 10" Table Saw
Cutting straight
this is usually caused by a dull blade or you need to carefully re-adjust the blade guides
Aug 12, 2009 | Ryobi 9 in. Benchtop Band Saw
Band saw blade wanders.
cut freehand. A bandsaw blade will always run off to one side or the other, even using a fence.
The rip fence is intended for re-sawing only, and very thin strips
Jun 28, 2009 | Ryobi 9 in. Benchtop Band Saw
Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
Jun 19, 2009 | Ryobi 9 in. Benchtop Band Saw
Straight cutting with rip fence
Feb 26, 2009 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
Saws Logo
23 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
