Question about Saws
Blade drift issues with Craftsman band saw
My Craftsman bandsaw has a blade drift problem regardless of what blade I use. What can I do to remedy the problem.
rowdy45176
  • 2176 Answers
SOURCE: manual craftsman band saw
I just went to Sears.com and then to Sears Parts Direct (down at the bottom of page under Craftsman tools) and typed in your model number. You can look at this manual online. Good luck
Posted on Dec 20, 2008
  • 2692 Answers
SOURCE: Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Posted on Jan 18, 2009
efs_perpends
  • 1996 Answers
SOURCE: bandsaw blade keeps coming off Rexon BS 10
Unplug the saw and take the covers off the wheels. See if any of them show excessive end play or deflections when gently racking them from side to side. You may need to shim the wheels. Ideally, you want them all to track in the same plane, and you can check this with a straightedge.
There should be a tracking thumbscrew locked with a wing nut or some such on the back of the upper wheel. Put the blade on so it rides in the center of the tire, (move the guides out of the way if need be until you get the blade to track correctly), and turn the wheel by hand to see how the blade rides. That way you can make adjustments before it pops all the way off. By moving the bolt on the back of that upper wheel in or out you adjust the pitch of that wheel and change the way the blade tracks...
After you get the blade tracking smoothly under tension, you can move the guides back into position to support your blade during cuts.
Posted on Apr 20, 2009
FixYaSteve
  • 57 Answers
SOURCE: I have a 12" Sears - Craftsman - Band Saw and the
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Posted on Jun 14, 2010
Testimonial: "Very helpful. My problem is that I have moved, I'm 90 years old and I can't find my manual. But thanks. I'll keep working on it. Foster Williams"
I need a repair manual for a trade master 9" bandsaw model Pr13102
Is it the right blade?
Who makes Trademaster tools? - Canadian Woodworking and Home ...
https://forum.canadianwoodworking.com/showthread.php?...Trademaste...
Feb 15, 2010 - 13 posts - ‎12 authors
Can you get parts for them? Is $250. a fair ... Home Hardware has been sellingTrademaster for a couple of years. ... It's identical to many other models. ... I still own my 14" trademaster bandsaw. ... 02-16-2010, 03:38 PM #9.
Woodworking - Band Saw Setup and Tuneup - YouTube
? 13:04
https://www.youtube.com/watch?v=ZnqsEszw6xM
Apr 12, 2011 - Uploaded by WoodWorkWeb
Setting up a band saw correctly is an important set in order to get ... Woodworking - How to Adjust for Band Saw Blade Drift -Workshop ...
Jan 21, 2016 | Blade Saws
What size blade for a craftsman bandsaw 113247110?
Your band saw uses 10" band saw tires and a 63 1/2" band saw blade. . Get band saw blades on sawblade.com
Sep 03, 2014 | Saws
Blade drift with Milwaukee bandsaw
Worn band saw guides maybe? Or too much tension or change the blade , I use bi metal Haltbar band saw blades of sawblade.com
Mar 26, 2014 | Milwaukee 6238 Deep Cut Portable Band Saw...
Setting the proper tension on a Craftsman 10" band saw model 124.214000.
Hope this blog will help you http://bandsawblog.com/blade-tension/ .
What's your band saw blade? I am using Haltbar blades and never got problems tensioning.
Feb 11, 2013 | Craftsman Saws
Can I use Craftsman 99-3/4 in. Band Saw Blades - 3 pk. on my craftsman 14" bandsaw #124.32607
I think you need a specialist to answer your questions and can give you some options. You may want to give a call to www.sawblade.com . You can contact this 201-450-9810 or visit to their website . Hope that helps.
Dec 27, 2012 | Saws
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
Jun 19, 2009 | Ryobi 9 in. Benchtop Band Saw
Straight cutting with rip fence
when i use my table saw, i use clamps on the fence, i dont rely on the one built in.
Feb 26, 2009 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
Saws Logo
22 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
