Question about Samsung SpinPoint 3600RPM 1.8" 5.0mm HS081HA Parallel ATA Hard Drive
Need connector Need to find a usb connector for this hdd to use as an external for my pc
    Master:
  • Samsung Master
  • 752 Answers
I found this possibility
http://www.startech.com/HDD/Enclosures/18in-USB-to-Micro-SATA-Hard-Drive-Enclosure~SAT1810U2 - I am sure you can buy this in other countries, perhaps through Amazon or other retailers. I am sure there other manufacturers of similar products besides Startech.
22.April.2014
Posted on Apr 22, 2014
My Toshiba 1Tb External Hard drive Light Isn't coming on!
It sounds like the usb port on the drive itself is shot. You can actually take apart the case and pull just the harddrive out and use a hotswap usb harddrive reader and get to your files again
Dec 11, 2013 | Computers & Internet
Have just been given the Toshiba Hard Drive PX1396U-3T01, number 2978109s. No install instructions, or paperwork. He is now overseas. How do I install the HD, or get a driver?
Your Toshiba PX1396U-3T01 external HDD is USB-attached, so you'll need to acquire a
standard USB cable to accomplish the physical layer attachment. USB cables do not have
the same connector at each end - the system (computer) end has a USB "A" connector (flat-shaped), and the device end (HDD) has a USB "B" connector (square-ish shaped).
There is no software (driver) needed for this external HDD - support for USB-attached external
drives (either HDD or flash drives) is built into WinXP, WinVista and Win7.
IF your version of MSwindows doesn't want to recognize the Toshiba when you plug it in, try
START > Run > then type in "diskmgmt.msc"
then select the command "Rescan disks."
If you're running Mac OS or Linux, repost including your OS (operating system) info.
Aug 15, 2011 | Computers & Internet
I have a maxtor 500 external hard drive when i plug it to the mains it goes to start up for 10 seconds then dies. Any ideas?
External Hard drives usually draw more current (power) from the PC's USB port and some times even the power being provided by PC's USB port is too less for HDD. In both cases the HDD tries to start but will eventually fail. To cater this you need to buy USB cable with two USB connectors at PC end. Plugging both the connectors to the PC will draw required power from the PC and your HDD will work fine. Also try to connect your HDD to some other PC and see if it works their or not. farhanwaheed.jpg
Jun 20, 2011 | Kitchen Appliances - Others
Hi.. i need help.. my external hdd transcend store jet 320gb have problem... when I conect HDD to pc blue led blink just one time and hdd stop working..
Check that the USB cable can provide enough power to the hdd. Check that the USB port is powered. Older USB slots may not have enough power to run larger external HDDs, there you may require separate power to be plugged into the hdd. Are you using the original USB cable provided with the external HDD?
Feb 28, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Unrecognized
some proble was in USB socket of your external HDD...poor contact...
try to use another HDD enclosure to use with you HDD..
that problem occur due to pluging in and out several times...maybe the connector was damaged...hope it helps..
or try another PC again...some problems are not detected due to virus in PC...
May 25, 2010 | Western Digital Passport WDXML800UE...
External HDD
I have 2.5" HItachi 120GB and the same problem !!
Nov 16, 2007 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Maxtor One Touch External HDD not being recognized by PC
Try to use other running usb connector or check the HDD inside the external if is plug it will.
Nov 01, 2007 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
PC won't recognize external usb HDD
You may not have installed the HDD correctly in the case... I had the same problem with my Thecus N1050 enclosure, the green power light on the enclosure would come on and the drive would spin up but my PC would not see the HDD!!??... I thought, becuase i could hear the drive spinning that i had it installed correctly but this wasn't the case, when i removed the enclosure again and FIRMLY pushed the HDD into the connector (all the way in) and connected it back up to my PC, it recognised it instantly. Hope this helps!
Jul 25, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Samsung SpinPoint 3600RPM 1.8" 5.0mm HS081HA Parallel ATA Hard Drive Logo
54 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
