Question about GE Profile PEB1590 1.5 Cu. Ft., 1000W, Countertop Convection/Microwave Oven, Convection Cooking
Cooking with convection oven
Are you supposed to use the turntable when using convection oven
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
You do not have to remove the turn table, but I use the metal rack when cooking with convention.
Posted on May 02, 2014
SOURCE: Oven died while using convection feature
Thanks for the help !! It turned out to be the oven cavity TCO which is in the upper l/h corner under the grill.. I ordered the part which cost me $21.50 incl shipping.. It's not a big deal to change.. I'm just a little ticked off because I've only used this oven 3-4 times.. It was manufactured in July 2003 (I've had it in storage for two years untill my kitchen renovation was done).. If it's acting up now what else am I in store for ?? Well thanks again !!
AMT
Posted on Oct 23, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: I recently bought a microwave/convection
GE Customer Service is here, and they should be able to help you.
They may refer you to the Answer Center.
Posted on Aug 12, 2008
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Posted on Aug 14, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker Microwave Oven Model
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 02, 2008
heatman101
  • 43501 Answers
SOURCE: GE model # SCA2001BSS03, microwave/convection
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Apr 23, 2011
Turntable will not rotate and food will not heat up.
If it is not cooking and the turntable will not turn, this sounds like the secondary interlock switch is bad. Almost always this failure is caused by opening the door when it is in a cook cycle. Pushing the stop button before you open the door will prevent this in the future..
Nov 04, 2013 | Dacor DCM24 Convection/Microwave Oven
Glass turntable in tricity tmc209 says "microwave only" What do I use for convection or combi cooking? Does turntable still need to rotate for convection cooking?
definately dont use the standard glass plate for convectional 'oven' cooking, as it will shatter. i have had TWO plates shatter so far before realising they should only be used for microwave cooking.
Aug 15, 2010 | Microwave Ovens
My Dacor DCM24 microwave/convection oven is brand new and won't pop popcorn--old or new, large or small bag, with twice as much time as is on the bag, power on high. Doesn't work with the popcorn button...
Are you cooking it this way, as shown in the owner's manual?
"Use an overturned 9 or 10 inch oven proof glass pie plate on top of the
turntable when popping bagged microwave popcorn.
You can also use a paper plate in a pinch, but as always, never leave a microwave unattended while it's cooking, since some paper products can have impurities which will allow overheating and possibly fire.
This is a convection oven, so it has a metal turntable tray.
Microwaves cannot penetrate the metal from below like it would on a standard microwave's glass tray, allowing for even heating.
If you've lost your owner's manual, you can get it here.
Oct 21, 2009 | Dacor DCM24 Convection/Microwave Oven
Sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
May 29, 2009 | Sharp R-1871 Convection Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Clicking sound sporadically
That particular skillet is just too heavy a load for the turntable system to handle.
I would suggest a lighter skillet or a different container, otherwise, the motor or shaft or both will be damaged.
It is of course perfectly okay to put metal in a microwave (after all, that's what they're made of!) but you just have to do it only according to the instructions in the owner's manual.
And as you know, metal in convection mode poses no problem at all.
You just need to use a lighter or different container.
Jan 04, 2009 | Sharp R-1480 Microwave Oven
Rack in microwave
You should not have any metals in the oven when the microwave is on. If you are just doing convection cooking, the metal rack should be in so that what you are cooking is raised up so the hot air can surround what you are cooking.
Apr 04, 2008 | Kenmore 63672 Convection/Microwave Oven
GE Profile PEB1590 1.5 Cu. Ft., 1000W, Countertop Convection/Microwave Oven, Convection Cooking Logo
149 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
