Question about Micca EP350 G2 1080p Network Digital Media Player with 7.1 HD-Audio,
Firmware for Micca EP-350 discontinued
My Micca EP-350 is discontinued, but I need the firmware for my player. I need a help
  • John Smith
    John Smith Apr 15, 2014
    Mi Player box is EP-350 only, not EP-350 G2!!
How do I update the firmwear on my Olin Bluray OBDP-1000?
  • Here is the page that offers the ready support for the Omni BluRay model OBDP1000 http://www.olinlivenow.com.au/support/product-support-information.aspx?PartNo=OL-OBDP1000 I tried 3 times to access firmware from the and it only brings up the manual. Being a discontinued item you will need to contact them and see if Omni can offer a firmware update for you. I am sure they can it is just not ready available because it is not "the newest item" for them.
  • Hope this helps. Thank you for choosing FixYa
Regards, Tony
Jun 13, 2011 | Sony BDP-S300 Blu-Ray Disc Player
I have a BDP S-350 blu-ray player that just started having a problem playing a couple of blu-ray discs that I get from Netflix. The disc will load and start then will stop playing after about 10 seconds....
I'm sorry for the difficulties you're experiencing in playing the new Blu-ray disc in the Sony Blu-ray Player.
In most cases, the issue might be with the Java content on the new Blu-ray discs is making these issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is).
Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6385&os_id=99&mdl=BDPS350
I'm sure, installing the firmware update should resolve the issue. If you need any further clarification/assistance, please let me know.
Thanks for understanding.
Jun 01, 2011 | Sony BDP-S350 Blu-Ray Player
I have a memorex MVBD2510 and it will not recognize all blue ray dvds. Some error codes say t conttact the manufacturer and others just say unknown disk
I also have a 2510. This model has been discontinued. There is a firmware update. You need to go to:
http://www.memorex.com/en-us/Discontinued-Products/Home-Entertainment/Blu-Ray-and-DVD-Players/Blu-ray-Disc-Player-HD-1080p/support/
And download the firmware instructions and the firmware download. You will need to burn a CD-R.
The instructions can be confusing.
Dec 24, 2010 | Memorex MVD2022 DVD Player
Where can I find Recovery tool. It's not shown on iRiver web site
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Sep 30, 2009 | iRiver H10 MP3 Player
Garmin 205 W has been discontinued and webupdater
I find that hard to be true. The manufactuer just came out with updates for the Nuvi 3xx and 6xx this month (Aug 09) and those models are older than your Nuvi 205W. When you mean updates are you referring to firmware or maps? Either way, even the discontinued models are still being supported with firmware & map updates.
If you are having trouble getting your unit updated, please let me know and I can help you with this.
- Jim
Aug 26, 2009 | Garmin nuvi 205W GPS Receiver
Firmware for e-studio 282
I need firmware becuas the machine in errer f 103 i chage the HDD
than HDD need the softwer Pleas Give me a free softwe side
Feb 05, 2009 | Toshiba e-Studio 350 Copier
MMP9008 Wont turn on
I'm having the exact same problem, and I'm 99% certain I know how to fix it. Unfortunately I need the cd that came with it, and I don't have it. On the cd there should be a folder with some files to re-install the firmware on the player. It might have "stmp" in the name but I'm not sure. Assuming the cd does have those files, you want to first install the drivers that come in that folder. Then on the mp3 play, keep it unplugged, hold the on switch in the "On" position, and while keeping the switch held, plug in the usb cable to the player(make sure the other end was already plugged into the computer.) What this does is force the player to be detected by windows as a recovery device. Those drivers you installed were for this new setting. Once that's done you can run the firmware installer/updater from the cd, and it should re-install the original firmware. Then just unplug the player, wait 30 seconds or so, and then turn it on as normal. That -should- get it working again. If it doesn't, you might have to plug it back into your computer, the normal way, and format the player's hard drive. You'll lose whatever music and videos you had on it, but it might need to be formatted after a firmware re-install.
If I'm right about the cd having the firmware update(and I should be), and assuming my post is helpful, you might consider putting those files into a zip file and emailing it to me at polign at yahoo dot com so I can fix mine too. I've searched the internet for hours, and no once has it for download. I'd really appreciate it. And if you don't happen to have the cd, then I guess we're both out of luck.
Good luck fixing yours.
Nov 30, 2008 | Memorex Audio Players & Recorders
Undeletable video file
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Dec 10, 2007 | SanDisk Sansa e260 MP3 Player
I donĀ“t find sRP-350 Firmware
On this link; http://www.samsungminiprinters.com/support/Drivers.asp About half way down are all the drivers/firmware available for your printer (version 3.1.5) Hope this helps - please post again if you need more info :)
Mar 29, 2007 | Samsung SRP 350 Thermal Printer
Acer mf-350
It sounds like you may have deleted the firmware install on the device..contact the manufacturer and get the firmware updated...
Feb 15, 2007 | Acer MF35 MP3 Player
Micca EP350 G2 1080p Network Digital Media Player with 7.1 HD-Audio, Logo
225 people viewed this question
Top Micca Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Micca Audio Player and Recorder Expert? Answer questions, earn points and help others
