0316825 does not accept
    Top Expert:
  • Computers & ... Master
  • 21,472 Answers
What is the problem?
Posted on Apr 16, 2014
Eula not accepted
Hi Anonymous,
I should think you should have sorted the problem.
Regards.
Jun 16, 2014 | Xerox Phaser 6100/BD Laser Printer
Front Wheel Allignment
On these LH body cars, camber is not adjustable. Neither is caster. Those angles are preset by the suspension geometry. However, specifications for them ARE published. Generally, if either of those two parameters are out of spec, then it's likely something is worn or damaged and needs to be replaced.
The only adjustable parameters are to the front and rear toe but specified as "Total Toe" - see note below.
The alignment specs are as follows ...
ALIGNMENT SPECIFICATIONS AT VEHICLE CURB HEIGHT
A. FRONT WHEELS
  1. CAMBER
    Acceptable -0.6° to +0.6°
    Preferred +0.0°
    Side to Side Differential
    Acceptable 0.7° or less
    Preferred 0.0°
  2. TOTAL TOE - Specified in degrees. See Note Below
    Acceptable 0.4° in -to- 0.0° out
    Preferred 0.2° in
  3. CASTER* (reference angle)
    Acceptable +2.0° -to- +4.0°
    Preferred +3.0°
    *Side to Side Caster Difference not to exceed
    Acceptable 1.0° or less
    Preferred 0.0°
B. REAR WHEELS
  1. CAMBER
    Acceptable -0.6° -to- +0.4°
    Preferred +0.1°
  2. TOTAL TOE** - Specified in degrees. See Note Below.
    Acceptable 0.2° out -to- 0.4° in
    Preferred -0.1° in
    **TOE OUT when backed onto alignment rack is TOE IN when driving.
  3. THRUST ANGLE
    Acceptable -0.15° -to- +0.15°
Note: "Total Toe" is the arithmetic sum of the left and right Toe settings. Positive is Toe-in. Negative is Toe-out. Total Toe must be equally split between left and right wheels. Left and Right Toe must be equal to within 0.02° (2 one hundredths of a degree).
Courtesy RJK & Concorde Shop Manual
Mar 08, 2014 | 1994 Chrysler Concorde
My next question is if the original key wont start the car how do i get a vats key
you measure the ohms on the resister in the key using a digital multimeter. once you get the value you go to the dealer and ask for the number key that matches the resistance, get the key cut.
1 0.402 (acceptable range .386-.438)
2 0.523 (acceptable range .502-.564)
3 0.681 (acceptable range .650-.728)
4 0.887(acceptable range .850-.942)
5 1.130 (acceptable range 1.085-1.195)
6 1.470(acceptable range 1.411-1.549)
7 1.870(acceptable range 1.795-1.965)
8 2.370(acceptable range 2.275-2.485)
9 3.010 (acceptable range 2.890-3.150)
10 3.740(acceptable range 3.590-3.910)
11 4.750(acceptable range 4.560-4.960)
12 6.040(acceptable range 5.798-6.302)
13 7.500(acceptable range 7.200-7.820)
14 9.530(acceptable range 9.149-9.931)
15 11.801 (acceptable range 11.320-12.290)
Oct 09, 2012 | 1998 Cadillac Eldorado
Can anyone tell me how to block messages from a particular sender on my daughters' Sony Ericsson W205? Thank you!
  1. Flip open your cell phone and go to the phone's menu.
  2. 2
    Select "Settings" and scroll down to "Calls."
  3. 3
    Select "Manage Calls" and then choose "Accept Calls."
  4. 4
    Choose to accept "All Calls," "Calls from a list" or "None." If you choose to accept calls from a list, you will have to create your list of accepted callers. This is easy. You will just scroll through your contacts and select numbers you want to accept
hope this helps
John
Jan 06, 2011 | Sony Ericsson Walkman W205 Cell Phone
My msi pm8pm mb doesn't accept 1gb memory pc667 its accept only 256mb pc533, what i need to do to accept 1 gb memory, pls help me!!!!!! tnx!!
Your MB can take a max of 2 GB RAM. And it has to be DDR SDRAM. So, please ensure that it is compatible. Then only would it accept the RAM SIMM else it may damage the mother board. or the RAM itself.
Oct 13, 2009 | MSI PM8M-V Motherboard
Hi my vista operting system not accepting the sd card, initialy it was accepted now not accepteing. Let me know your suggestions. With Regards, Narni
Narni, this may sound simplistic, but have you rebooted the PC? Also, how is it not accepting it? Is it telling you there is a problem or is it just not responding to you inserting it?
Jan 25, 2009 | Computers & Internet
Won't accept the code for starchoice receiver
some receiver can accept several codes. did you tried all of them?
Oct 09, 2008 | One For All URC-3021 Remote Control
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
