Question about Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher
Wash cycle dont work
Every cycle works but the wash cycle
  • Official Brand Answer
  • 2,267 Answers
Good Morning Rhonda, this is JK. I understand that your dishwasher will not perform on the wash cycle. From what you described, it sounds as though you may need to replace the timer. This would be the brain behind the dial. Hope this helps!
Posted on Apr 16, 2014
Model 9156200 top loading washing machine
the lid switch may be loose or broken it happens to me it was washing but never rinse i found out that it was a loose switch this switch prevents the rinse cycle from working with the lid open because of the high speed rinse ,some machines dont work at all, a loose switch makes the machine think the lid is open even if it is closed.good luck.
Apr 16, 2014 | Kenmore Washing Machines
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
How long should a wash cycle take?
you dont tell me when this started or was this always the same .adrianxxx
Jul 23, 2012 | Kenmore 44072 Front Load Washer
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Hi, The washing machine that I have has stopped working during a washing cycle and refuses to come back on. This was during a large wash cycle.
first place we start is checking the lid switch to make sure its working slowly lift tub lid lower slow and you should here a click if not its snapped if yes have it checked to see if blown. appart from that it would be an internal fault the capacitors in these machines dont last too long
Nov 08, 2010 | Speed Queen AWS44NW Top Load Washer
Washing machine off balance in one cycle
Make sure washer is on a level surface and all four feet adjusted properly. A slight forward lean may help with this problem as the out of balance switch is at the rear.
Feb 28, 2010 | Washing Machines
Cloths wet when wash cycle finished
sounds like the brushes in the motor need replaced dont know if that would fix the dryer prob but it could be the same prob they both use the same motor
Mar 04, 2008 | Washing Machines
Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
