Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Bar nuts possibly over torqued CS-310
I bought a preassembled Echo CS 310 and noticed that the clutch cap nuts (holds the bar) were very tight, perhaps over torqued at the factory. When I started to removed the nuts the stud seemed to turn with the nut. I took it to a dealer because I didn't want to turn the nut and perhaps strip something internally. The tech at the dealership was able to remove the nuts successfully. Is anyone experiencing this?
  • 3 Answers
SOURCE: Purge pump removal
By studying an exploded parts diagram found online, I determined that it snapped out the top before the bracket slid out the front.
Posted on Jan 30, 2009
  • 9 Answers
SOURCE: The starter rope on my echo chainsaw model CS 280E
i believe its a non servicable part and a replacement is required. its a simple swap out
Posted on Apr 22, 2009
SOURCE: how do I remove the clutch assembly from an Echo Cs-400 chainsaw
Turns out there is a reverse thread on the clutch hub (the "Y" shaped piece). I poked around some on the web and got some ideas, but they called for a special tool that it made by echo that fits in around the legs of the hub, and once you've prevented the crankshaft from turning by blockiing the piston, it turns (clockwise) with a wrench. I didn't have that tool, nor did I want to spend $19.95 to buy one, so I stuck a plastic toothbrush handle into the exhaust port to block the piston from moving, and used an open-end wrench just wide enough to fit over one of the legs in the "Y" shaped clutch hub. Then I took a large crescent wrench and closed it over the open-end wrench, right down next to the hub. So, if the saw is lying on its side, with the clutch facing up, the open-end wrench is inserted straight down straddling one leg of the clutch hub, and the crescent wrench is positioned horizontally gripping the bottom end of the open ended wrench to provide a "handle" for leverage. Holding the saw securely somehow (I used my elbow), left hand gripping the open-end wrench and pushing it down into the clutch so it won't slip out, I used my right hand to provide the clockwise motion on the crescent wrench as a lever/handle. Clutch popped free after a few seconds of pressure.
Hope this experience helps someone.
Posted on Jun 14, 2009
dontbother10
  • 2220 Answers
SOURCE: trying to replace gear on echo cs 440 chain saw
The IPL for a model 400 Echo can be found here:
http://www.echo-usa.com/pdf/documentation/CS400_C090_11_081007.pdf
It should not matter but please verify this fits your serial number.
From the IPL your saw has an outboard clutch. Use this the following as a guide. I didn't see any special tools on the IPL.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
    Lou
Posted on Sep 13, 2009
dontbother10
  • 2220 Answers
SOURCE: Need replacement crankcase for Echo CS-750EVL chainsaw
There are 2 complete CS-750EVL saws on my local Craigslist.
Try here for Echo IPL:
http://www.echo-usa.com/pdf/documentation/CS750EVL_010185.pdf
If not your saw:
EchoUSA
http://www.echo-usa.com/documentation.asp
Type your model number into the search window.
Good Luck
Lou
http://seattle.craigslist.org/see/tls/1571477399.html
http://seattle.craigslist.org/tac/tls/1571683044.html
Posted on Jan 27, 2010
Do you have instructions and/or a video showing how to replace the sprocket and clutch assembly on a Echo CS 310 chain Saw
not on an echo but they are pretty much all the same.....go check out my youtube channel and look up clutch themowermedic1 on yt
Jan 12, 2013 | Garden
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
Echo cs-310....how to put chain on after it became lose....also how to tighen when it becomes loose.
At the right side take out the panel that hide the bolt that has a large groove.When unbolt move froward the chain holder and tight the bolt but not too tight just go further until you can test it by hand making the chain to move freely but stable.Reverse the procedure.
Post / thumbs / testimonial are welcome!
Nov 12, 2010 | Echo CS310 14" Bar Length Fully Assembled...
How to install bar and chain on cs 310 echo
A CS-310 OM follows:
http://www.echo-usa.com/pdf/documentation/CS310es1112_042310.pdf
There is a very good, model specific, procedure beginning on page 12.
There are 2 listed based on serial number I think, you can download the other and an IPL here:
EchoUSA
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 21, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
The chain on my Echo saw is moving very slowly to not at all
Your centrifugal clutch needs to be replaced or your chain guide (bar) is pinched.
Mar 14, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Need size of guide bar nut on model cs-330t
I went here, typed CS-330T in the search bar and found 6 IPLs. None of them list or display bar nuts. Odd!
EchoUSA
I suggest you take your saw into your local NAPA Auto Parts store. You might also contact Echo and suggest they add bar nuts to their IPLs for the benefit of the next guy. HTH
Lou
Feb 10, 2010 | Echo Garden
CHAIN AND BAR KEEPS LOOSENING UP AFTER 3 TO 4 CUTS. RESET TENSION AND BAR AND LOOSENS AGAIN AFTER 3 TO 4 CUTS.
Are you holding the nose of the bar up as you tighten the bar nuts?
You loosen the bar nuts and gravity pulls the bar down. You check the chain and the tension is correct, tighten bar nuts. Begin a cut and the bar slowly moves upward (no matter how tight the bar nuts) and the chain becomes slack.
19d6408.gif Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
One more likely possibility, is the chain isn't being oiled.
Checking chain lubrication
Aim the tip of the bar at a light colored surface about 20
cm (8 inches) away. After 1 minute running at 3/4 throttle
you should see a distinct line of oil on the light surface. HTH
Lou
Oct 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Echo chainsaw clutch cs 370
the nut is part of the clutch bell housing just spin the bell counter clockwise and hold the flywheel or you can buy a tool that goes in spark plug hole its called a "dead stop"
Jun 06, 2009 | Poulan Pro Chain Saw 46cc 20"
How do you replace the chain drive sprocket on an Echo CS-440?
you need to replace the clutch, you woould pull the side cover off and remove the bar and chain. then you remove the nut holing the clutch on( the clutch and sprocket should be on piece) take it to your local saw shop and grab a naw one.
Mar 18, 2009 | Garden
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
89 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
