Question about LG Computers & Internet
Lg lgx11 drives sim
Need to know if my phone call unlock it lg gplg441gb
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Sep 29, 2016 | LG Cell Phones
Tip
LG mobiles Test Menu, secret codes and tricks
Here are some common codes for LG cellular phones and there use. Use these codes at your own risk and note that these codes may or may not work depending on your phone model.
Following are the codes:
LG all models test mode: Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI (ALL): *#06#
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Sim lock menu (LG B1200): 1945#*5101#
Sim lock menu (LG 510W, 5200): 2945#*5101#
Sim lock menu (LG 7020, 7010): 2945#*70001#
Sim lock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select ‘SW Ver.info’
Code to reset phone :
- Phone without SIM
- Select ‘Factory Reset’
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*#
on Aug 05, 2010 | Cell Phones
I have a LGX11 network for many years, and now I need to add RAM to upgrade from XP to WINDOW7. Can I do that?
Unfortunately, the memory on this particular net book is soldered directly onto the main board instead of the removable type so the RAM is not user upgradeable.
Mar 27, 2014 | Computers & Internet
PROBLEME DE CODE LGX11
well what's the problem code?
May 09, 2012 | LG LW20-EV Notebook
Cell phone contacts
Step 1Remove the SIM card from your Motorola phone. The SIM card is a small chip that is located under the battery in your cell phone. After you've removed the SIM card from your Motorola phone, remove the SIM card from your LG phone.
Step 2Insert the SIM card from your LG phone into your Motorola phone. Turn on the Motorola phone.
Step 3Press the "Menu" key and select the "Address Book" option.
Step 4Select "Options" by pressing the right soft key. The "Select Multiple to" option will appear on the screen. Choose the "Select Multiple To" option and then select "Copy to SIM to Phone."
Step 5Remove the SIM card that you placed in your Motorola phone and insert it in your LG phone. After inserting the SIM card, turn on your LG phone.
Step 6Click the "Menu" key on your LG phone and select the "Address Book" option.
Step 7Select "Options" and choose the "SIM Management" option.
Step 8Select the "Copy from SIM" option and choose "Select All."
Step 9Select the "Copy" option. Your contacts will be transferred from your SIM card to your LG phone.
Feb 24, 2012 | LG Cell Phones
Id like to unlock my lgks360 for free but im finding it hard. could you give me a code to do this please?
Only trust best unlocking specialist for unlocking your mobile , it will be the best & safest way for unlocking . In order to unlock your Lg KS360 MOBILE make use of this site wickedunlock ,select the network you need , then get the unlock code here , using unlock code specified in it proceed unlocking your mobile & gain solution .
May 28, 2011 | LG Cell Phones
Need to reinstall LGX11 (model X110)
The best option would be to connect the hard disk to another computer which has an optical drive, load the OS into it and return it back to its native PC. Or as you asked, you can check for other solutions too
http://boshdirect.com/blogs/tech/os-install-without-cd-rom-support.html
Sep 05, 2009 | Computers & Internet
Code to unlock LG Rd 3000.that i can use tata sim on it.
i have LG Rd 3000 of reliance and i want to use tata sim on it. but when i insert tata sim it shows ''insert sim''. plz help me out
Dec 27, 2008 | LG KG800 Cellular Phone
Lg kg800 phone drive me nuts
have you read the instructions and made sure the sim is in the right way
Oct 01, 2007 | LG KG800 Cellular Phone
Computers & Internet Logo
23 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
