Question about Black & Decker Vacuums
Need battery for db225 (discontinued), do other models' batteries fit?
Battery was discontinued but dustbuster still works, are there any other batteries that will fit?
  • 37 Answers
SOURCE: We have a B&D Companion
this will probably be hard to find and you will see that it may also be cheaper to just pick up a new one. a batt pack will most likely be $25 to $30. when its such a throw away society many companies dont put out much for replacement parts.
Posted on Sep 25, 2008
SOURCE: how do i open the B&D dustbuster chv9600 to
There are screws in the handle of it, the battery is also in the "Base" handle simply locate all the screws, and unclip the case halves with a flat blade, and the battery is inside.
Posted on Mar 03, 2010
SOURCE: How do I remove the battery in a Dustbuster
That model looks similar to my DB200. Instead of the screws, the underside has a latch/panel that you remove. Place a screwdriver in the two slot-like holes that face each other (one at a time) and the 'door' should pop out. Mine was a little stiff and I broke one of the retainers inside. Shouldn't be a problem. Sourcing a replacement battery 'pack' is what I'm doing now.
Posted on Jan 30, 2011
  • 34 Answers
SOURCE: I need a black and
I have bad news. That part is no longer available; check out the info here:
http://www.ereplacementparts.com/black-and-decker-fve9610-dustbuster-parts-c-4167_8887_8911.html
I actually have exactly this kind of dustbuster, and I was able to renew the battery pack, but I had to do it by using eight individual cells and soldering them together. The size of cell (I think it's called a sub-c) is not common to consumers, but is fairly common to battery pack manufacturers. Quite honestly, your dustbuster with no battery is worthless, even when it was available, the pack was $46.46 as a spare - probably more than the thing is worth. Buy a new one from wal mart! If you really, really want to look at getting a new pack for this one, then your only option is to find a specialist battery store (I know there's one in my city) that can 'remanufacture' them. Basically, they take the old pack, and rip out the old cells, and put in new ones. They have the special equipment to weld the connections without frying the cells too, and they have access to Sub-C cells, of course. It'll be expensive. Good luck, you're gonna need it. Sell it at a garage sale; it looks nice.
Posted on Feb 05, 2011
  • 7 Answers
SOURCE: Do I need to replace the battery as my dustbuster
Yes the battery is most probably the problem. you can check is the voltage of the fully charge battery is same as what is stated on it, if not you definitely need a new battery
Posted on Mar 05, 2011
Need a replacement battery for chv1210 dustbuster 12v
SORRY we do not source things for people search google Google
Nov 29, 2017 | Vacuums
My 9.6v DustBuster doesn't hold a charge
Does the charge light come on when you plug in the charger? If not, the charger or cord is probably bad. If it seems to charge but you're not getting as much time as you used to, the battery probably needs to be replaced. Check your warranty and call dustbuster or go online to purchase a new battery. Another alternative, especially if it is out of warranty is to take the unit to a Batteries Plus store and have them replace the battery.
May 01, 2017 | Vacuums
B&D Dustbuster model CHV1400 TYPE 1 not working (no recharge). Does it pay to replace battery or not? If yes, how do I open it up, and how do I replace battery? Price? Where do I buy it?
Sorry to say but the battery pack is 3/4 the price of a newer dust buster. The other solution is the have some one rebuild it. But I would buy a new one. Don't waste you time.
May 06, 2011 | Black & Decker Vacuums
Do I need to replace the battery as my dustbuster does not seem to have a lot of power and therefore does not pick up as it used to?
Mar 05, 2011 | Black & Decker 15.6 Volt DustBuster Vacuum
I need a black and decker dustbuster manual to know what kind of batteries to buy. I recently got this dustbuster at a garage sale. The charge/wall mount says it is a 9.6volt FVE9610 Type 1. Help? Joan...
Feb 05, 2011 | Vacuums
How long do i have to charge a dustbuster? I purchased one at a garage sale and it does not seem to be working. The owner said that it was working..
if its not working at all it has a fault that could be anywere if it is working but with little suction then the batery is no good replace the battery
Jun 25, 2010 | Black & Decker AV1200 DustBuster Handheld...
DUST BUSTER 7.2 POWER LASTS FOR UNDER ONE MINUTE??
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=859375
Generic problem for all Vacuums
Posted by bettedxx on July 31, 2008
DUST BUSTER 7.2 -- POWER LASTS FOR UNDER ONE MINUTE??
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The problem that people have with dustbusters is that when they 1st get them they need to say train the dustbusters to extend the battery life, the process is simple – when you 1st buy the dustbuster then you charge it up the 1st time and then you turn it on and drain the battery down to nothing, and then recharge the dustbusters again, and by doing that you have a larger battery life and it will run longer – but dustbuster and vacuums like that do not tell you and when people buy the item they just turn it on for a minute or two and then the battery does not get a “memory” as per how long it should run. By doing this the dustbuster will last and run longer and will have fewer problems. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 31, 2008 | Vacuums
CGV9600 Batteries
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=28044&tid=6872
I hope the above link works. Replacement parts are available through DeWalt.
Also note, they now have a 12-volt version of the same vac. The price is about twice what you will pay for the replacement battery for your 9.6V model, but it may be worth it for the extra power.
Dec 02, 2007 | Black & Decker CFV9600 DustBuster Bagless...
Vacuums Logo
56 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
