Question about bigfishgames.com
Monitor resolution get a message that bigfish games cannot support my monitors resolution
  • 28 Answers
If it's an old monitor you may be time to upgrade.
Posted on Apr 15, 2014
Trying to download/play games but get this message: Input not supported - then my computer FREEZES and I have to reboot. This a brand new Dell Computer (but not monitor - monitor is 6 years old).
This is cause the game you are trying to play is configured to play in a high resolution but your Monitor not supporting this resolution. If you havent try to play older games, try to play an older game and see if this is happening again. Thanks. Please Rate my Solution.
Apr 28, 2011 | Acer AL1916W 19" LCD Monitor
When I attempt to play a video game from my computer, a message pops up in the middle of the screen that says "input signal out of range." the game functions normally, but the message stays in...
It is because the game want to feed the video resolution that is higher than the monitor can support.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
You need to lower your PC video resoltion to the native resolution of this monitor, but your game may not display properly.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 28, 2010 | Hannspree HH251H 25" LCD Monitor
Best resolution for gaming
Native resolution for this monitor is 1680x1050 @60Hz for best pictures, if your needs to run at higher resolution then it will not work, you will get format not supported message on the screen.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 01, 2010 | Acer AL2016W 20" LCD Monitor
Frequency out of range
the monitors resolution range is only to 1280X740 or 780
and your video card may also need an upgrade.
The game may require a higher resolution that is not compatible with the the devices mentioned.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
Hanns-g JC199d monitor displays 2 messages periodically
install an AGP card into an AGP slot because internal display card does not support high resolution because of insufficient memory . use 8X AGP card for better result . then you can see high resolution ,3D games ,and movies .
Apr 17, 2010 | Hannspree HANNS·G JC199DP LCD Monitor 19...
Acer al1716 monitor input not supported
You get the message because the game try to run at the PC video resolution that you monitor cannot display/support. You need to run your game at native resolution of the monitor.
Mar 25, 2010 | Acer AL1716 17" LCD Monitor
Make sure Resolution is 1440 x 900......
hello,
did your monitor support 1440X900 resolution. if yes then go to desktop properties then change the resolution to 1440X900 then play the game.
if not support then remove the game from your pc.
ramesh
Nov 29, 2008 | Envision 19" Widescreen Flat Panel LCD...
Monitor out of range when a game is booted up
The maximum resolution for the MV540 is 1024X768 @60Hz refresh. The other monitor isn't giving you an error message because not all monitors have that feature, but both the monitors are unable to display whatever data the computer is sending. If the display is normal until you start the game, then the game itself is setting the resolution to something out of the monitors' range. You'd need to set the game up to play at a setting the monitors could handle. I've never played WoW so I have no idea if the game offers a way of selecting the resolution. The game may simply require more graphics capability than your monitor can provide. Most systems now are using 17 or 19-inch flat screens or CRT's, and they offer more resolution and refresh rate options.
Jul 29, 2008 | Compaq MV 540 15" CRT Monitor
VA520 Resolution Message
Have you tried via the Control Panel/Display function?  The driver provides the means but Windows provides access to those settings.
May 24, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
bigfishgames.com Logo
Top bigfishgames.com Computers & Internet Experts
David Payne
David Payne
Gareth Cockram
Gareth Cockram
Are you a bigfishgames.com Computer and Internet Expert? Answer questions, earn points and help others
