Question about Canon ImageRunner 1600 Copier
I have a canon imagerunner 1600 copier we have vertical strips
Our copies are coming out with about 2 inch vertical strips in the middle of the page
  • tlpsavi Jun 18, 2009
    I have cleaned the small glass and the main glass. It happens when we use the feeder and when we place it directly on the class
  • 76 Answers
If you are using dadf ? try to clean the small glass on the laten cover
Posted on Jun 18, 2009
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
Canon np 3030 copy problem
print something from the Menu or report (do not make a copy) if it comes w/ the problem. Could be dirty laser glass or toner empty. if it comes normal, It's a dirty dOCUMENT SCANNER.
Oct 20, 2012 | Canon imageRUNNER 1600 Laser Printer
I HAVE DEGITAL COPIER IR 1600 THE PROPLEM COMING IS BLACK COPY IN REAR SIDE PLEASE HELP ME
it is very possible the dark line on your copies are being caused by the drum. it will all depend on how many copies are on it but without seeing one of the copies the best guess i can make is the drum.
Jun 10, 2010 | Canon ImageRunner 1600 Copier
What causes a line down the middle of copied pages
There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on.
May 24, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
When it copies, the copy comes out landscape and i can not change the paper select option to show portrait. also, it cuts off the bottom of the page as well
Kindly change the direction of the original. If at present you are keeping it horizontal way change it to vertical. You will get the correct print.
May 19, 2010 | Canon imageRUNNER 4570 Copier
Blurry bottom 2 inches of copy from IR 1600
Take a Normal,reduction and an enlarged copy(at any ratio) of a Newspaper in different size papers. Then check whether the blurred position is at the same position or not.If it is at the same position, check scanner for its free movement, there may be an obstacle which will not allow the scanner to move freely resulting in blurred copy. or else let me know.
Dec 27, 2008 | Canon ImageRunner 1600 Copier
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
56 people viewed this question
old marine
old marine
