Question about Dual XD7600 CD Player
Install a radio but no radio station coming in
    New Friend:
  • 28 Answers
Not trying to be a jerk but did you remember to plug the antenna back in? I had that problem before and it took me about an hour to figure out that when I moved the radio to put it back in the antenna would pop out.
If you need further help, reach me via phone at https://www.6ya.com/expert/andrew_d2df42288260d96e
Posted on Apr 15, 2014
Radio frequently just stops broadcasting and eventually comes back on
Peggy, Is the radio actually switching off or do you just loose the radio station. If radio is shutting off, there must be a bad wire/ plug connection, loose plug, or maybe bad ground.
If loosing station, have Arial/antenna connections checked, maybe upgrade to better antenna. Some stations just do not send out a strong signal which can also cause loss of station.
Mar 29, 2016 | 2009 Toyota Highlander
When I try to find radio station all I get is static. How do I use radio function
You need to have an antenna to have your radio stations come in clear. If you just hear static, your antenna sounds like it's not there!
Feb 16, 2016 | Eclipse Audio Players & Recorders
Radio wont set stations
hi, does the radio go back the standard settings when you turn off the key, if it does than try checking the fuse for the constant power supply as this controls the time memery and the settings for the stations, if not try holding the station button down for 3 to 4 sec
hope this helped
Jun 13, 2013 | 2001 Chrysler Sebring
How to turn on radio
Just press the larger On / Off button, lower left side of clock, select AM / FM band (make sure you install either the am band wire antenatal and the FM antenna (comes with clock) use the rocker arm switches to search out stations and adjust volume by turning knob on the right side of radio, that's it... (0:
Mar 31, 2013 | RCA RP3721 Clock Radio
2007 chevy radio weak signal. Iknow being out of range is not the problem.
it could be a loose antenna is juest come loose from the back of the radio the antenna is for long distant stations
Dec 18, 2012 | Spyder 07-11 CHEVY SILVERADO 1500 PICKUP...
Just bought a car and it had hardwired sirius radio already installed. I called and activated it with Sirius radio and tried to get assistance from them on how to get it to work. They gave me instruction...
The "hard wired" version that you speak of apparently only refers to the power supply.Do you have a seperate display for the Sirius unit? Now, you failed to mention the type of radio (factory or aftermarket); so, if you have to use an "empty radio station" then you have an FM modulator. This modulator could wired or wireless. The wired version interrupts the vehicle antenna wire and the station on said modulator is usually preset to either 88.1, 88.3,88.7, or 89.1. There is no need to power this modulator up, it comes on when then Sirius comes on. One way to check for power is to turn on the Sirius unit and tune your radio to an occupied Fm station. Wait a few seconds and listen to the reception. Turn off the Sirius unit, the reception should improve for the occupied station. If it is a wireless FM modulator it also has preset stations that you can change but, extending the wieless antenna will greatly improve your reception of the Sirius stations.
Sep 17, 2010 | Sirius Car Audio & Video
Radio Station stuck on one station and wont change!
sounds like the radio is locked up.... if the radio requires a code do you have it and know how to install it... if so ... unhook the battery for about 15 minutes and hook it back up... should work ok then...
Robert
Please take a moment to rate this solution thanks
Jan 23, 2009 | 2004 Chrysler PT Cruiser
Car radio
On the face of the stereo is a * button. Push this button then use the numbers on the face of the stereo to go directly to that station. Example, my favorite classical station is 90.7. Push the * then 907. This station will appear in display. Then push and hold for about 5 seconds the preset button you would like this station to be. The stereo will momentarily blink to a different station then come back. Station set.
Oct 20, 2008 | Becker Car Audio & Video
Radio stations
Set the station you want to wake up to in the "AL" preset memory. You can download the manual from the link below: http://157.254.235.130/public/rp3722.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 09, 2007 | RCA RP3722 Clock Radio
Dual XD7600 CD Player Logo
24 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
